Results 1 to 22 of 22
Thread: 1997-2003 eurovan parts
  1. 01-14-2012 10:10 PM #1
    What do you need?? No ash tray no driver or passenger seat no carpet. Ask and I'll let you know. Will be gone by Wednesday. Does have sunroof.
  2. Junior Member
    Feb 11th, 2011
    CT
    83 x1/9, 83 gti, 89 golf, 87 QSW, 88 QSW, 99V70XC
    01-15-2012 09:49 AM #2
    I'm looking for the battery cover in the engine compartment. It mounts vertically and is inserted into the front of the guide piece and separates the engine compartment from the battery area.
    I believe its called "battery cover upper" P/N 7D0915437. If you have it how much do you want for it with shipping?
    You can see an exploded diagram of what I'm looking for at the link below.
    http://netfev.org/rialta/vw/parts/20...an%20Parts.pdf
    Look under Electrical systems there you will find the battery mounting battery protection cover section which will have exploded diagrams and associated part numbers.
    Thanks
    Apr 26th, 2000
    Columbus, Ohio
    '99 Eurovan Westfalia Weekender
    01-15-2012 11:01 AM #3
    How much for the fresh air intake filter cover, if the covering material is intact, shipped to 43201?
  4. 01-15-2012 01:45 PM #4
    Hi there,
    A few items:
    1.Rear Hatch Door Pull Strap
    2.Cigarette lighter
    3. Plastic piece above front passenger kick area
    4. Cover for rear Air Conditioning Access
    5. Whatever insert DIN plastic piece that goes above ashtray
    6. Wall mounted cup holder
    Pictures here:
    https://picasaweb.google.com/eilopez...eat=directlink
    Shipping to 91801 Alhambra, CA.
    Thanks
    -eric
  5. 01-15-2012 10:05 PM #5
    Ill check figure $10 to $15 per item and I'll ship in one box USPS flat rate figure $20 to $25 for shipping let me know and I'll let you know what's there.
  6. 01-15-2012 10:07 PM #6
    Sorry no battery cover it's gone
  7. 01-16-2012 12:56 PM #7
    Sounds good on the shipping. Let me know what parts you have from my list and I can send paypal straight away or whichever method of payment you prefer.
    I forgot one more thing, if it's an MV model, I'm also looking for the table's telescopic pole (with locking insert that holds the table up).
    Thanks again,
    Eric
  8. Member vwbugstuff's Avatar
    Mar 27th, 2004
    NW Chicago 'Burbs
    2012 CC "R"-Line, 2003 Eurovan, 1979 Westfalia, 1978 Superbeetle Convertible, 1998 New Beetle
    01-16-2012 06:01 PM #8
    Passenger side foglight shipped to 60103.
  9. 01-16-2012 09:40 PM #9
    Foglights are gone sorry good luck
  10. 01-16-2012 09:41 PM #10
    No telescoping pole I needed that in my other van sorry
  11. Junior Member Tim J's Avatar
    Mar 8th, 2002
    Centerburg, Ohio
    '02 EV, '87 Scirocco 16v
    01-17-2012 09:39 AM #11
    I am in need of the following:
    -Driver side mirror assembly if it is a powered version
    -Front Grill (upper)
    It is for an '02. Shipped to 43011
    Thanks
  12. 01-19-2012 08:26 AM #12
    I need:
    • Arm rest hardware
    • Passenger front door power lock actuator
    Please send price and availability.
    Thanks!
  13. 01-19-2012 10:56 PM #13
    The latch actuator I actually have. The armrest piece you need is $10. At following website Gowesty.com under misc. interior parts that's your best bet man for only 9.95 you can get new ones I did too because I had armrest that would not lock into place. I hunted high and low and finally took them apart and pound it's an easy easy fix. You,l need a screw driver to pop cap off and a long Allen wrench or torques bit on a screw driver unscrew it and I'll bet anything it's that dam cheap part in there and the tab broke off from to much weight being out on it. How about $35 shipped on actuator.
  14. Junior Member
    Jun 8th, 2011
    NJ
    2002 Eurovan, 2001 Eurovan, 2006 Sprinter, 1961 Thunderbird
    02-01-2012 01:46 AM #14
    Still have van?
  15. 02-08-2012 07:06 PM #15
    Passenger side mirror, just the glass?
    08 Audi A4 Avant S-Line
    01 Eurovan MV
  16. 02-16-2012 10:28 PM #16
    Quote Originally Posted by thevwcabrio View Post
    There are a few things I would like to look into if you still have it.
  17. Member Lil red roket's Avatar
    Jan 28th, 2004
    WAY too many and counting...
    04-03-2012 01:55 PM #17
    ECM for 2002 24v Eurovan shipped to 43571?
  18. Member Hippie_J_Simpson's Avatar
    Nov 23rd, 2004
    Brandon, Florida
    '87 16v Jetta Coupe, '99 EuroVan, '03 GTi
    04-04-2012 12:30 AM #18
    How about the head rest for the middle row and rear row?
  19. Member gtiboy66's Avatar
    Jan 1st, 2000
    Toms River, NJ
    1978 Rabbit, 82 Jetta, 58 AH Sprite, 67 Morris Woody
    04-10-2012 08:59 AM #19
    Looking for a passengers window motor
  20. Member Fluffy's Avatar
    Aug 25th, 2008
    Virginia Beach, VA
    01 Audi S4, 04 Touareg, 71 VW Beetle
    04-19-2012 12:39 PM #20
    I need a cooling fan, 380mm . I dont care if the motor is locked up or not as long as the fan is intact
  21. 04-21-2012 01:20 PM #21
    Do you have the front cupholder that is located at the bottom of the center console?
  22. 05-10-2012 10:13 AM #22
    I'm looking for the sunroof motor, got it?
