Closed Thread
Page 1 of 2 1 2 LastLast
Results 1 to 35 of 57
Thread: FS: 1992 Golf VR6 Turbo...400+whp
  1. Member seL's Avatar
    Jun 8th, 2004
    92 Golf VRT, 09 Elantra, 09 Wrangler Sahara Unlimited, 11 GMC 3500 HD Duramax
    01-14-2012 10:48 PM #1
    Looking to sell my satin Atlas grey mk2 Golf VRT.
    My email address is lespal@gmail.com
    This car has been well taken care of, no expense spared, nothing but 94 octane on the diet either.
    Tons of money and time has gone into this car, nothing but the best for it, OEM everything aside from the wheels and drivetrain/turbo mods. Everything is done properly, no hackjobs; anyone who has seen this car or knows me can vouch that it is not a ****box.
    Motor
    - 1998 OBD2 VR6
    - P& P, valve job, fully rebuilt head
    - valves, guides, lightweight I&A followers, etc.
    - Cat cam HD valve springs
    - VR rad, Flex-a-Lite “Scirocco” slim fans and shroud,
    - newer low km bottom end (has about 110k on it)
    - ARP head studs
    - C2 9:1 stainless steel headspacer
    - Samco hoses all around
    - lightweight p/s pulley
    - new seals/gaskets all around the motor
    - new timing chains/tensioners/tensioner bolt less than 8k ago
    Turbo setup
    - the car makes 344whp on 13lbs and 407whp (377 torque) on 19lbs with room for more
    - Kinetic VR6 exhaust manifold
    - Garret t3/t4 (the same one that comes with the Kinetic kit)
    - C2 Motorsports #42lb software for OBD2, latest and greatest version
    - 6 x Bosch greentop 42# injectors
    - 4” billet MAF housing
    - 3” stainless steel intake
    - Forge 007 diverter valve
    - custom short runner intake manifold
    Fuel setup
    - intank Walbro high flow fuel pump
    - inline Walbro 255lph fuel pump
    - custom wire relay harness for inline pump
    - custom dual feed fuel rail made from solid billet stock
    - braided fuel lines
    - all AN fittings used
    - Mallory manually adjustable FPR
    - The fuel setup is pretty unique in itself. There is plenty of fuel to support upgrades and the dual feed rail is an added bonus.
    Intercooler setup
    - custom air to water core/tank built to fit in the engine bay
    - reservoir is built into the core so no running lines the length of the car
    - cooler for the water is mounted in front of the rad
    - high flow pump mounted on custom bracket on transmission
    Transmission
    - Peloquin LSD
    - 3.67 ring&pinion
    - bolt kit
    - Competition Clutch Stg 4 from Kinetic Motorsports. 6 puck sprung disc ceramic.
    - new OEM VR6 transmission mount
    Exhaust
    - 3” turbo back stainless steel, mandrel bent setup with 1 muffler and a cat.
    - both Bosch O2 sensors are recent
    Suspension/Brakes/Wheels etc
    - VR6 sub frames & axles
    - 11.3" VR big brakes, 5 bolt. Brembo vented rotors with PBR ceramic pads
    - new OEM brake master cylinder
    - rear VR discs w/ e-brake cables
    - Corrado master cylinder, booster, etc.
    - Koni fully dampening and height adjustable coilovers
    - JOM adjustable upper strut brace
    - OEM MK3 rear strut brace
    - ABD front 25mm/rear 28mm sway bars
    - Autotech lower front tie bar
    - BFI stg2 Delrin front/rear upper motor mounts
    - BFI stg2 Delrin solid front/rear lower motor mounts
    - Polyurethane control arm bushings
    - Keskin KT-1 16x7 & 16x9 with custom rivets (spikes)
    Interior/Gauges
    - Recaro SRD seats on lowered rails
    - Tekniq quick release steering wheel system
    - CLEAN non smoker interior
    - black carpet
    - mk3 rear center console
    - MKIV knob
    - custom Italian leather handbrake and matching shift boot (black with silver stitching)
    - black headliner, black carpet, black c pillars, black sun visors/sunroof crank & plate
    - VR cluster with black face gauges
    - AutoMeter dash-mounted oil PSI gauge
    - AEM TRUBOOST boost controller/gauge
    - Innovate DB wideband controller with gauge
    - MFA wiper stalk (gives oil temp, driving time, etc, not pictured)
    - OEM black leather door cards and rear cards with chrome stripe to match the dash
    - 2x Alpine Type S 5x4.25 speakers
    - 2x Alpine Type S 6x9 speakers (not cut into rear parcel shelf)
    - JL 8" 8W3 DVC sub
    - Kenwood amp for the sub and a Rockford Fosgate for the speakers
    - Alpine iPod/iPhone deck
    Last summer I completely rewired the stereo and made up a false floor for the trunk. It looks nice and tidy and the amps/distro block all sit on an amp rack mounted against the back seat. The car was painted a couple of years ago and looks the same way you see it in the pics.
    Looking for a straight sale. I have absolutely no interest in a trade of any kind. The car is currently being stored in Ontario and I am now living out West. That being said I am a motivated seller but will not give this car away.
    Asking price is $12,500 as is without the Keskin wheels. If you want the wheels, we can work out a price on them. Seriously interested buyers are encouraged to email me directly as the price is negotiable within reason.
    Please note this is a Canadian car, so if you are outside of Ontario you will have to arrange something to pick it up or pay for shipping.
    Email is the best way to get a hold of me, however I do check my PMs regularly so that works too. My email address is lespal at gmail dot com
  2. 01-14-2012 10:52 PM #2
  3. 01-14-2012 10:53 PM #3
  4. Member SC420's Avatar
    Jun 25th, 2009
    91 VW Golf/Audi TT
    01-15-2012 12:50 AM #4
    wat colour is this car?? satin finish??
    The Sleeper From HELL 13.72... alls I need now is some LSD.....
  5. Member seL's Avatar
    Jun 8th, 2004
    01-15-2012 01:07 AM #5
    It's atlas grey with a satin clear coat.
  6. Member nortonator's Avatar
    Jan 5th, 2012
    Alberta
    2005 Audi B7 S4, BMW 325i, VW Corrado VR6
    01-15-2012 02:01 AM #6
    u got a dyno sheet? and interior shots and lowest price youd take.
  7. Member prometheus_'s Avatar
    Oct 6th, 2009
    pickering, ontario
    88 jetta coupe
    01-15-2012 03:01 AM #7
    ffs les
    it's not costing you anything, ship it out west and beat it on those flat ****ing roads!
  8. Member BOOSTAHOLIC's Avatar
    Feb 24th, 2003
    BLAME CANADA
    11 2.0T, 67 Camaro, 85 Shelby Charger, 86 GLH-T Omni
    01-15-2012 05:29 AM #8
    The only person I know first hand as anal with there cars as me... This is a fine specimen of how to do things proper.. Les, you have me thinking...
    PSN o0o_BOOST_o0o
    XBL oo BOOST LEE oo
    Quote Originally Posted by MidnightSpecial View Post
    I'm saying that after 6 hours of angry man on man sex, the MKIV still smelt like an MKIV.
  9. Member seL's Avatar
    Jun 8th, 2004
    01-15-2012 01:08 PM #9
    Added a quick scan of the dyno sheet as well as some cell phone pics I had of the false floor, stereo and SRDs.
  10. Member Mr Ruckus's Avatar
    Aug 14th, 2001
    Toronto AKA Screw face Capital.
    1000cc of pure sex.
    01-15-2012 05:26 PM #10
    This beast is back up on the choppin' blocks.. bump for a well built MK2.
    I HATERS If you are looking for older VW parts you usually check the wreckers, You want over priced junk? hit up B3VW Hasan.
  11. Member The Maytag Man's Avatar
    Apr 5th, 2002
    Toronto,ON
    VW GTI 20th AE BMP, 1983 VW Rabbit GTI(sold), 1978 VW Rabbit L
    01-15-2012 09:40 PM #11
    this thread sux donkey nuts.
    keep this car Les!!!
    oh and if not, ill take the srd's on the cheap yo!
    Buy My Things!
    Buy My 20th!
    What She Order?
    ლ(•益•ლ) Why you no buy my stuff!?
    78 HÄRE
  12. Member asylum's Avatar
    Jan 11th, 2000
    Toronto, Canada
    bagged 01 Golf 1.8t, 03 Jetta wagon tdi, 97 Cabrio, 09 hayabusa
    01-16-2012 07:16 PM #12
    Dont do it Les!!! Ship it out west and enjoy it!
  13. Member Mooz!'s Avatar
    Dec 30th, 2001
    Niagara Falls
    2005 Pontiac GTO 6.0L, 1996 B4 TDI Wagon
    01-16-2012 11:32 PM #13
    This car gives me such a chub.
    GLWS Les... something awesome better replace it
    When I was a kid, I had dyslexia. I used to write about it in my dairy.
  14. Member prometheus_'s Avatar
    Oct 6th, 2009
    pickering, ontario
    88 jetta coupe
    01-17-2012 12:15 AM #14
    Quote Originally Posted by Mooz! View Post
    hyundai w/ warranty
  15. Member BlownWideOpen's Avatar
    Dec 24th, 2008
    Basically China, Canada
    "Black Betty"
    01-20-2012 12:22 AM #15
    I remember seeing this car for the first time. I almost fainted in the Kennedy Commons parking lot.
    Quote Originally Posted by AeroWagon View Post
    ermahgerd phertagrehper
  16. Member The Maytag Man's Avatar
    Apr 5th, 2002
    Toronto,ON
    01-23-2012 04:34 PM #16
    trade you for new appliances for your new house
    Buy My Things!
    Buy My 20th!
    What She Order?
    78 HÄRE
  17. Member nortonator's Avatar
    Jan 5th, 2012
    Alberta
    01-24-2012 06:27 PM #17
    bottom price-line?
  18. Member seL's Avatar
    Jun 8th, 2004
    01-24-2012 09:55 PM #18
    I won't discuss pricing in this thread. If you are genuinely interested contact me via email or PM with an offer.
  19. Member BlownWideOpen's Avatar
    Dec 24th, 2008
    "Black Betty"
    01-25-2012 01:00 AM #19
    Inb4everyoneonvortexlowballslikemad...
  20. Member seL's Avatar
    Jun 8th, 2004
    01-28-2012 04:49 PM #20
    Quote Originally Posted by The Maytag Man View Post
    Sarah would be all over that deal, fortunately our new place comes with new appliances.
  21. 01-28-2012 07:43 PM #21
    club Grim Water
    "When there's no more room in Hell"
  22. Member mushroom_curry's Avatar
    Apr 20th, 2004
    Sunnyside
    01-28-2012 09:12 PM #22
    Bump for Les.
    dasjettakartell - transcend trend - connoisseurism before consumerism
    vr6coilbracket.com
    Wroth European AutomotiveSterling Tire Services
  23. 01-30-2012 09:24 PM #23
    E-mail sent
  24. 02-02-2012 09:24 PM #24
    Wow! Car looks pretty crazy! GLWTS!
  25. Member
    Dec 30th, 2010
    pickering
    1995 VW Golf GTI
    02-03-2012 12:43 PM #25
    are you serious! is this car really in pickering? how come ive never seen it?!!! if i ever had the cash....
    GOOD LUCK WITH THE SALE!
    1991 Toyota tercel - SOLD
    1994 VW Jetta - SOLD
    1995 VW Golf GTi VR6 - Parted out and SOLD second one died... Currently Parting Out
    2001 Lexus IS300 Daily Driver
    I JESUS
  26. Member 89VWdieselGolf's Avatar
    Feb 22nd, 2004
    Durham, Ont.
    2001 Golf TDI 2004 Passat 1.8T
    02-07-2012 07:51 AM #26
    Quote Originally Posted by masterkdrifter View Post
    Cause it never gets driven
    GLWS Les
    89VWdieselGolf's Autobiography
    2001 Golf TDI
    2004 Passat 1.8T
    1990 Golf ABA Turbo -SOLD
  27. Member nortonator's Avatar
    Jan 5th, 2012
    Alberta
    02-07-2012 10:32 PM #27
    still available?
  28. 02-08-2012 04:17 PM #28
    I just cleaned up a bunch of garbage posts.
    If you're not interested, leave your $0.02 in your pocket.
    THANK YOU.
    Quote Originally Posted by VDub2625 View Post
    Plastic seat complaints, girly Beetle complaints, diesel awd Scirocco dreams? And then deciding to stay with an old, very well-used wagon instead? Are you the real-life creation of a VW lover's self-parody crossed with every TCLer ever?
    http://www.cafepress.ca/Driveshaftz
  29. Member seL's Avatar
    Jun 8th, 2004
    02-08-2012 07:57 PM #29
    Quote Originally Posted by nortonator View Post
    still available?
    If you are in Toronto this weekend drop me an email and I can try to set something up with my brother to show you the car. Please note there will be NO test drives until we have discussed further and a deposit has been left.
  30. 02-09-2012 10:52 PM #30
    Do you have a deposit?
  31. Senior Member Big Dac With Fries's Avatar
    Feb 1st, 2002
    Spatula City
    6000 SUX
    02-11-2012 12:54 PM #31
    Free bump for the Les "the block smasher".
    Want to roll your fenders or Lamin-X your lights in clear or yellow for THE ABSOLUTE CHEAPEST PRICE IN THE GTA? IM me!
    "I was thinking about what a friend had said, I was hoping it was a lie."
  32. 02-12-2012 05:09 PM #32
    I want this thing so bad
  33. Member seL's Avatar
    Jun 8th, 2004
    02-17-2012 11:18 PM #33
    Quote Originally Posted by Big Dac With Fries View Post
    Oh when Waterfest was good....miss those days.
  34. Member seL's Avatar
    Jun 8th, 2004
    02-20-2012 01:36 PM #34
    Summer/driving wheels are now back on the car and proper viewings are available.
  35. 02-27-2012 08:05 PM #35
    Still for sale? Check your messages.
Closed Thread
