VWVortex.com - *Group Buy* IDF: MK4 Tubular Control Arms.
    Results 1 to 10 of 10
    Thread: *Group Buy* IDF: MK4 Tubular Control Arms.
    1. Forum Sponsor Justin@USRT's Avatar
      Aug 1st, 2011
      Philadelphia
      04.5 PG GLI
      01-16-2012 12:49 PM #1
      These Mk4 Tubular Control Arms are designed to reduce unsprung weight while providing full wheel travel with minimal friction. Although the top-quality rod ends provide no cushion at all, they articulate without any of the binding and "sticktion" involved with rubber and harder material bushings. Driver and passenger typically experience a smoother but firmer ride with radical improvement in steering feel and handling precision.
      Note: Arms are set up for standard Mk4 Ball Joints. Those upgrading Mk4 R32 or Mk1 Audi TT cars will need a pair of our Conversion Ball Joints. Purchase a discounted set with your arms.
      The Group buy is available for the first 10 orders received. The group buy will be available for 10 days or until all 10 spots are filled. Which ever one comes first. (When ordering please include your username in the notes so that I can keep this thread updated)
      1.
      2.
      3.
      4.
      5.
      6.
      7.
      8.
      9.
      10.
      Specifications:
      • Jig Assembled
      • Fully TIG Welded
      • 1-1/4" DOM Tube
      • Laser Cut Gussets
      • FK Rod Ends 4130 Chromoly, Teflon Lined (15,000 lb. static radial load rating)
      • Stainless Jam Nuts
      • Custom Stainless High Misalignment Spacers to match Factory Bushing Width and Bolt Size
      • Optional Sway Bar Provision
      • Grade 10.9 Flange Hex Head Ball Joint Hardware
      • Powder Coated
      Weights:
      Mk4 Tubular Control Arms: 7.0lbs/3.2kg
      R32/TT alloy control arms: 9.6lbs/4.35kg
      Mk4 stock (stamped steel) control arms: TBD
      Justin Im, Technical Sales
      US Rally Team
      www.facebook.com/usrallyteam
      AIM-jijust88
      Unitronic Chipped Authorized Dealer
    2. Forum Sponsor Scott@USRT's Avatar
      Jan 13th, 2005
      Haddon Heights, NJ
      MK4 Jetta 2.0T, Mk1 Scirocco 16v, 323 GTX
      01-16-2012 04:25 PM #2
      Okay, folks. You asked for some pricing help with these mighty Mk4 Tubular Control Arms. The USRT/IDF group buy is now officially ON with 10% off the introductory price and over 16% off what will be standard in TEN DAYS (or 10 kits sold).
      DISCOUNT CODE for website orders: CONTROLARM4
      As is already known from the massive introduction thread, these parts are built for drivers of dedicated performance cars AND the “go low” show car crowd. How can one kit provide the same exact improvements for cars with such different build specs? Racer types will love the handling precision that only solid rod ends (aka heim, pillow ball, or rose joints) can deliver. There’s no deflection that compromises normal bushing operation. There’s also ZERO binding as the suspension travels through it’s normal range.
      Try getting arms with stock bushings to move this far without binding. You CAN'T!
      Guys on airbag suspension aren’t too worried about handling precision but suffer badly from binding stock bushings. Forced to operate well outside their intended ride height range, they produce ride harshness and unpredictable handling. These arms are stronger than stock and weigh less, too. So, impact resistance is built in. Can’t dodge that pot hole? HIT IT with confidence. Put the extra camber adjustment to work to achieve extra “tuck” and correct tire wear problems, too. Solve all the typical annoyances with these direct bolt-on arms. Plus, THEY'RE SEXY AND YOU KNOW IT.
      Group Buy RATES are available for the next TEN DAYS or ORDERS -whichever comes first. (When ordering from our website, include your username in the notes section.) Post your name here, too.
      Scott F. Williams, Team Director
      US Rally Team
    3. Member Billburt's Avatar
      May 2nd, 2006
      sLUTZ, FL
      996 Turbo
      01-16-2012 06:54 PM #3
      how rough is the ride compared to stock or even drop in poly bushings?
      MotorsportsbyReeves__The SteveGangBang 11.21__TheHazeBang_2012_TheGreatCatTakeover2012_
    4. Forum Sponsor Justin@USRT's Avatar
      Aug 1st, 2011
      Philadelphia
      04.5 PG GLI
      01-17-2012 12:39 PM #4
      Here is the answer to your question.
      US Rally Team
      AIM-jijust88
    5. Member Emron's Avatar
      Mar 27th, 2007
      Miami, FL
      2004 GTI Swapped to R32
      01-18-2012 10:01 PM #5
      Done and done... purchased.
    6. Member RAULTPEREZ's Avatar
      Jan 6th, 2002
      florida
      57 oval bug, 80 rabbit, 17 golf R
      05-24-2012 06:58 PM #6
      is the sale over?
      Bitches !!
    7. Forum Sponsor Scott@USRT's Avatar
      Jan 13th, 2005
      Haddon Heights, NJ
      05-25-2012 10:31 AM #7
      Quote Originally Posted by RAULTPEREZ View Post
      is the sale over?
      You're about four months late.
      US Rally Team
    8. Member RAULTPEREZ's Avatar
      Jan 6th, 2002
      florida
      05-25-2012 11:16 AM #8
      Dam it! I havent been on here lately.
      Bitches !!
      Jun 15th, 2001
      Westchester Co., NY
      80Rabbits(4sp&5sp), 91Golf, 98 GolfVR6, 01Golf1.8t, 2000Golf12V VR6, 2003Golf24V VR6
      04-29-2014 12:31 PM #9
      can anyone provide some feedback about the feel and longevity of the product?
      TomJV
    10. Member L.I.VW13's Avatar
      Apr 8th, 2006
      Long Island
      Built mk4
      06-27-2014 08:20 PM #10
      Possible to do another group buy on these?
