VWVortex.com - Mk4 Control Arm Geometry
    Results 1 to 10 of 10
    Thread: Mk4 Control Arm Geometry
    1. Member XvwX's Avatar
      May 5th, 2004
      Albany, NY
      Mk4 Wagon VR, Mk3 GTI VR
      01-16-2012 03:53 PM #1
      Hello,
      The only thing I want to do to my ST(C?) class VR Wagon this year is front end geometry.
      1. Camber (upper strut mount)
      2. LCA angle
      3. possable tie rod flip
      My question is about getting the LCA angle down. As of now they are about level to slightly up with the subframe.
      I've seen the TT spindle/LCA swap before but thats not going to happen ($$$).
      So what I'm thinking is to relocate a Mk4 Ball Joint to the TOP of the LCA. Make a plate to go inside the LCA and run longer bolts through the whole thing.
      Then I may need to do a tie rod flip. (I'm a machinist and will be drilling/reaming the old tapers and pressing new tapered bushings into the spindle)
      Feb 3rd, 2003
      Croydon, PA
      '03 TDI wagon, '72 GT6, '73 1800ES, '64 Mini
      01-16-2012 04:51 PM #2
      Camber plates are the only "ST-legal" way to add camber. Ball-joint and or tie-rod relocation is not. The way to "fix" the LCA angle is to run tall, stiff springs, like Shine.
    3. Member XvwX's Avatar
      May 5th, 2004
      Albany, NY
      01-16-2012 06:49 PM #3
      Hummmmm. Well, DSP might be calling. If thats allowed in _SP.
      Either way I don't want to raise the ride height. I love the lowered look. So here is my LCA angle.
      Yuck.
    4. 01-17-2012 12:23 AM #4
      Its not DSP legal either, geometry correction using the factory pickup points is a SM modification.
      The method which you are describing does not correct the geometry issues that arise from lowering, the pivot point is still at the same location in space. All you would be doing is correcting the angle on the control arm bushings.
      Feb 3rd, 2003
      Croydon, PA
      01-17-2012 08:53 AM #5
      Unfortunately, what looks good and what performs don't go hand and hand when dealing with a mk iv. If looks are that important, then you'll have to pony up the coin for the h2sport spindles along with other mods.
      Or do what I did - leave the wagon alone and bought another car...
    6. Member XvwX's Avatar
      May 5th, 2004
      Albany, NY
      01-17-2012 10:49 AM #6
      So by lowering the outboard side of the LCA that wouldn't correct the geometry?
      2. On arm-and-strut (MacPherson/Chapman) suspensions, the lowerarms may be modified/replaced OR other methods of camber adjustmentas allowed by paragraphs 14.8.B, C, or G may be used,but not both. This is from the ST_ rules.
      Ian, I know I can't help it. HA!
    7. Member chois's Avatar
      May 12th, 2000
      Chicagoland
      01-17-2012 02:09 PM #7
      Quote Originally Posted by XvwX View Post
      Maybe I am missing something, but I don't see how this would change the suspension geometry. Remember that it actually has nothing to do with the LCA position, only with the imaginary line between the LCA - chassis bushing pivot point and the ball joint pivot point. The only way to change it is to raise the chassis side (hard to do), or lower the ball joint relative to the hub - thus the widespread use of ball joint extensions and alternate bearing carriers.
      Chris
      2014 Passat SE, 1.8tsi, 5sp
      2007 GTI 16v, 4 door, 6sp
      2005 20V E-450 motor home
      A2 Golf & A2 Coupe racers
    8. Member XvwX's Avatar
      May 5th, 2004
      Albany, NY
      01-17-2012 04:32 PM #8
      Eyyyyyyyyyyyyyye gotchya! I see now. I stand corrected. Hu, so the only camber option without spending a small fortune is upper strut mount then.
      Well, it def looks like I'm staying in ST_ now!
      Thanks for talking some sence into me!
    9. 02-29-2012 08:45 PM #9
      As per my post in the stickied control arm install
      I need to replace my control arm bushing and I already have the upgraded bushes (R32/TT).
      I cant seem to find a part number for them new WITHOUT bushes already pushed in. Does anyone know it?
      Also while im at it, is there a OEM 'upgrade' for the control arms?
    10. Member Stealth 993's Avatar
      Jul 19th, 2010
      Tacoma, WA
      97 911 C4S, 95 911 C4, 08 MCS
      03-11-2012 01:36 PM #10
      If you want to fix your geometry, raise the car up about 2-4in, & get a proper alignment.
      Right now, your car is too low, & the LCA angle is way off, you want it level, or a little turned down, not up as you have it. Your caster, bump steer & akerman angle is all wrong. The only thing you get form being this low is camber.
      You are also putting a lot more stress on the drive shafts.
      Best thing is to find the class leader, ask him how his car is set up.
      I like cars.
      Flicker
      Photobucket
