Got a clear bra installed. I finally pick her up tomorrow morning.
Sent from my iPhone 4S using Tapatalk
#71
Drove it to work for the first time! Everyone in the office asked if they could go take a look at it. Spent most of the work day giving tours of the [R]
#72
2012 Rising Blue Golf R (Build Thread)
2012 Night Blue Tiguan SEL w/ Premium Nav
#73
smoked side marker install... took all of 2 minutes per side..
Makes a big difference on black.
#74
#75
Used vag-com to code remote window open and close with key fob and changed comfort blinkers to 4.
Waiting on some additional feedback from Ross tech on the led drl intensity and the bulb out code for the tails.
NC Wookies in the Woods Caravan Info
APR Stage 1 2012 RSB, Golf R Loaded 4 door - Euro Tails - Euro Cupholder - Wintake - OEM Parcel Storage Tray
#76
#77
XPel Ultimate. I was sold on it after I saw the video of the film self-healing after being thoroughly scratched. The scratches literally disappeared in minutes on their own. Very cool technology. I posted a link to the video in the recent clear bra thread.
#78
#79
#80
Don't think you can change that yet... At least I couldn't get it to.
What he is referring to is the ability to change the brightness in the DRL mode... or with the lights off... you can dim it down tot he same level with the lights off, or crank it up to what it comes to from the factory... I tried putting the setting at 110% and it seemed to stay the same.
And I was trying to get it to be bright with the lights in the on position, but could not find a solution.
2001 Audi A4 QM 1.8T | Under Construction...
2007 Chevy Duramax | BT Dieselworks 1000+rwtq
2012 VW Golf R | Mini-Avant
#81
Thanks, thats good to know.
Now I just need to figure out how to edit byte 18 and then I'm good to go![]()
#82
#83
If you're using the newest version of VCDS, it's not an option in the drop down menu of the Long Coding Helper. You must do it manually.
This is simple. Just copy the default long code and past it underneath. Count over to byte 18 (the red arrow) which by default should be "20." Change byte 18 to "21" and click Do it.
This is the coding for non-fog LEDs.
As far as adjusting the LED intensity with the head lights on, it might be possible but I'll need to take a closer look. Hope this helps.
#84
I just copied and pasted that long coding string I PMed you into the "new coding" box and hit "do it".
The coding was accepted and is now changed. I cleared the faults.
Problem is-I still have "check rear reverse light bulb" (or something like that)...and the passenger side reverse light still does not light up????
Could I actually have a bad bulb in there?? If not the coding is still messed up![]()
#85
#86
Thanks everyone. Between the forum and Dana at Ross tech I've got all faults cleared!
I ended up cutting and pasting the code manually fwiw
#87
Just a note here: be VERY careful about copying and pasting long codes, if yours is not exactly the same as other's, it could end poorly. Generally it's best to go to the long code helper, click LCode in the title bar of the next window, and manually change byte 18 (you tab through them) to 0x21 (0010 0001). Our default is 0x20 (0010 0000) so it's a check box difference. I coded my lights yesterday and it worked perfectly.
#88
#93
I took my Golf R on the highway for the first time.I love having passing power.
Engineer @ TriMech Solutions | Certified SolidWorks Expert
Form Engineer & Weldor @ Advanced Armament Corporation
2012 Golf R & 1982 Jetta Coupe
#95
Finally got to test drive it - got into the dealer yesterday but I was working late. Took it for a nice spin, was very impressed with how it handled and the power delivery. I'll actually take delivery monday afternoon. Can't wait. Next step: Buy and install LED tails. Got a bigger tax refund than I expected so the LEDs are definitely in my budget this month.
#96
installed Led tails, interior bulbs, euro switch, and enabled the windows to be controlled by the key fob
#97
#98
#99
#100
#102
Today I got her cleaned up ready to clay bar / Zaino tomorrow. First time I have tried to detail a white car though... so many little rust dots that just don't seem to want to come off. Hopefully the clay bar will do better.
Also discovered it's pretty difficult to get the slots in the stock rims clean. My fat fingers are hopeless... May need to invest in something that can get into the ends of them.
Soon she will gleam though!Tomorrow!
- ook
#103
just rolled 500 miles..
got my vag com cable today so I enabled the remote window operation and disabled the seat belt alarm.. Any other suggestions? I tried bumping the convenience turn signals up to 5 blinks, but it didn't take.
#104
#105
