VWVortex.com - What Did You Do To Your Golf R Today?
    Page 7 of 532 FirstFirst ... 345678910111757107507 ... LastLast
    Results 151 to 175 of 13296
    Thread: What Did You Do To Your Golf R Today?
    1. Geriatric Member
      Aug 31st, 2004
      New Jersey
      2015 /S3 - 2004 .:R32
      01-31-2012 03:02 PM #151
      Quote Originally Posted by lobuzz311 View Post
      From the mojo mat thread:
      http://forums.vwvortex.com/showthrea...1#post75247140
      I hope that's not the case, but it may be too low volume a car to justify monster mats...
      wouldn't make sense since they did it for the MKIV and MKV R.
      '85 Golf (SOLD) - '91 Jetta GL (SOLD) - '97 Jetta Trek (SOLD) - '99 Jetta Wolfsburg (SOLD) - '02 GTI 337 (SOLD) - '04 R32 (SOLD) - '04 R32 - '10 GTI Autobahn (SOLD) - '12 Golf R (SOLD) - '13 Tiguan SEL (SOLD) - '13 Golf R (SOLD) - '15 GTI Autobahn (SOLD) - '15 Tiguan R-Line (SOLD) - '15 S3 - '18 RS3
    2. Global Moderator iThread's Avatar
      Sep 27th, 2005
      Portland, Or
      67 Bug, 92 Miata, 12 Golf R, 15 eGolf
      01-31-2012 03:04 PM #152
      That's awesome. Gotta love a company that knows how to treat their customers!
      Can you and johannes make a separate thread for these pads when you get them? This way, the info won't be lost in this thread...
      I think a lot of people will be very interested in them if the brake dust is really as bad as has been reported.
      Trust me, the 1521 pads are the real deal. I've been running them for years in all my cars from my MKIV R32 with a Stasis BBK, a MKV GLI with a stoptech BBK to my 92 Miata. I even use them on my wife's Routan because I trust them that much. They don't dust much at all, have great modulation, are quiet, don't eat rotors, and are compatible with their racing pads without having to swap rotors or turn your existing ones. Initial cold bite is OEM and the excellent bite and modulation continues beyond temperatures the stockers would start to fade at.
      http://www.ctbrakes.com/brake-compounds.asp
      Sep 28th, 2011
      Texas
      2012 Golf R; 2012 Tiguan SEL
      01-31-2012 03:16 PM #153
      Quote Originally Posted by iThread View Post
      On this strength of this recommendation and positive reviews online, I just called in an order for these.
      2012 Rising Blue Golf R (Build Thread)
      2012 Night Blue Tiguan SEL w/ Premium Nav
    4. Member lobuzz311's Avatar
      Oct 12th, 2011
      San Jose, CA
      2012 Golf R, 2011 Ford Explorer
      01-31-2012 03:38 PM #154
      That sounds like a pretty solid recommendation... What exactly is it that I need to order? You said you called to verify something being correct on your order. What is it that I have to make sure of?
      I've changed pads / rotors on my Honda, but I'm no mechanic... I want to make sure that if I order the pads, I have exactly what I need.
      About turning the rotors for the new pads. Assuming I do it at the dealership when I pick up the car, I won't need to turn them since they're effectively new. How long after delivery does it become necessary to turn them?
      2012 Golf R - Candy White 4-door (Build Thread)
      Sep 28th, 2011
      Texas
      01-31-2012 03:42 PM #155
      As long as you don't have any deep scoring, distortion, or major deposits on the rotor surface, it isn't necessary to turn them.
    6. Awaiting Email Confirmation
      Apr 21st, 2007
      San Diego, Ca
      '13.5 Platinum Grey GLI Autobahn w/ Nav, '12 Black Passat 2.5 SE W/ Nav, '12 Golf R Stg 2+ (Sold)
      01-31-2012 03:45 PM #156
      Whats the part number for these? I want to order some, but I want to check some local avenues first.
    7. Member Dutchmastr9's Avatar
      Sep 13th, 2004
      Boston
      2 Door bugatti coupe...er, i mean Golf Racecar
      01-31-2012 03:46 PM #157
      i hope thats not true. seems pretty stupid to introduce and advertise a R-Line and then not have monster mats for it
      You Aint About That Life | ETYolo
      Ruined Blue Golf | 42 Draft Designs
    8. Global Moderator iThread's Avatar
      Sep 27th, 2005
      Portland, Or
      01-31-2012 03:46 PM #158
      Since the Golf R is so new they're not totally familiar with it yet but, assuring them that we have the same brakes as the TT-S (which we do) they let me order them. THey asked that after I install them to let them know they fit properly so they can include the Golf R on their website and also let their distributors know.
      What you'd want to order are the 1521 pads for a TT-S (though based on how many of us have ordered them you can probably say Golf R and they'll get you the right pads.) I'd also ask that they install the pad wear sensor for you unless you don't want it and want to disable the sensor with a vag-com.
      If you've changed pads and rotors before you should be ok but, if you're the least bit doubtful about it have a mechanic do it. They're brakes and you don't want to **** about with them. You don't want to risk having to mash the pedal in a panic and the brakes not performing.
      As for how long before you have to have the rotors turned you should be good if you get rid of the stockers in a couple of hundred miles of normal street driving. I'm planning on just roughing the rotors up a bit with some light sand paper when installing mine. I'll have less than 200 miles on the car when they go on though. And, I can still see the machining grooves on the rotors.
    9. Member lobuzz311's Avatar
      Oct 12th, 2011
      San Jose, CA
      01-31-2012 03:51 PM #159
      Great, thanks for the info!
      How much was it for the set, all said & done?
    10. Member
      Sep 28th, 2011
      Texas
      01-31-2012 03:56 PM #160
      Enough Golf R people have ordered these that they'll know which pads you need. For your info, the front pads are CT915 and the rears are CT1108. I asked for the pad wear sensors and confirmed that the wear sensors need to be on the inner pads.
    11. Global Moderator iThread's Avatar
      Sep 27th, 2005
      Portland, Or
      01-31-2012 04:01 PM #161
      $267 plus shipping for fronts and rears.
    12. Member lobuzz311's Avatar
      Oct 12th, 2011
      San Jose, CA
      01-31-2012 04:42 PM #162
      That's going to be a tough sell to the wife... We're moving about a month after picking up the car, so it's going to be a nutty time for us financially.
      I just really want to know how bad the stock brakes dust... It's hard to quantify someone's approximation of "a lot" without seeing what they're seeing.
    13. Global Moderator iThread's Avatar
      Sep 27th, 2005
      Portland, Or
      01-31-2012 04:50 PM #163
      The stock brakes perform well. They stop the car in normal driving just fine. But, they dust a lot. Maybe it's just because they're new but, after a 25 mile round trip there was noticeable dust on the front wheels a little less on the rears. More noticeable when I started wiping them off, my blue microfiber cloth started turning black.
      But, the dust isn't the primary reason I'm swapping out the OEM pads. It's just i've used carbotech pads for years and am used to them and like how they perform. The OEM pads just don't do it for me.
    14. Member johannes's Avatar
      Oct 25th, 2004
      Plymouth, MI
      2016 Golf R
      01-31-2012 05:25 PM #164
      +1 on every word iThread has written...this will be my fifth set of Carbotechs.
      Whenever I can get my R to the track, I will be running their race pads as well
    15. Member
      Aug 24th, 2003
      Miami, FL
      2012 Golf R 2-Door
      01-31-2012 05:44 PM #165
      It's not hyperbole. The dust is to the point where I dread cleaning my wheels simply because as soon as I hit the brakes there will be a nice coating of dust applied to them. "A lot" is really the best description.
    16. Member
      Sep 28th, 2011
      Texas
      01-31-2012 05:54 PM #166
      +1 The brake dust is shockingly bad...to someone who has lots of experience with the dust-o-matic OEM BMW pads.
    17. Member AAC Welder's Avatar
      Apr 13th, 2011
      Richlands, NC
      01-31-2012 09:11 PM #167
      Ordered a Diesel Geek short shifter. I hope it makes it in by Friday so I can install it this weekend.
      http://www.dieselgeek.com/VW_six_spe.../ss-sigma6.htm
      Mechanical Engineer | Certified SolidWorks Expert | Reverse Engineering and Design Services Available
      ------- 4dr AWD 16V Turbo MK1 Rabbit Build -------
      http://forums.vwvortex.com/showthrea...1#post88166484
    18. Member dummy's Avatar
      Apr 13th, 2003
      seattle
      2012 RB Golf R 4dr, 13 RB Golf R 2dr, 2012 Abarth (GONE!), 1967 Bug
      01-31-2012 09:22 PM #168
      Quote Originally Posted by AAC Welder View Post
      i have a dieselgeek shortshifter on my MKV. i LOVE it. it is on the list for one of my first mods for the R once i see how the shifter feel is stock.
      best quality short shifter on the market, hands down.
    19. Member johannes's Avatar
      Oct 25th, 2004
      Plymouth, MI
      2016 Golf R
      01-31-2012 09:36 PM #169
      Just scored some 17x8 TR Motorsports MT01s for the track....thanks Brett!
    20. Member
      Apr 25th, 2010
      Cherry Hill, NJ
      71 Porsche 914 w EJ20 Swap, 2008 R32, 2002 Jetta GLX VR6 Wagon, 04 Audi A4 Quattro RS4 look.
      01-31-2012 10:56 PM #170
      Supposed to be at the Dealership Feb 9th//// was hoping to get it on my Birthday 2/1
      Slate Gray/Sun/Nav clear bra right away!
      Kyle
    21. Member
      Nov 13th, 2009
      PNW
      2012 RB Golf R--Gone, 2015 S4
      01-31-2012 11:06 PM #171
      Changed color from CW to RB....
    22. Global Moderator iThread's Avatar
      Sep 27th, 2005
      Portland, Or
      02-02-2012 12:42 PM #172
      Here's what's showing up on my doorstep today....
      APR Intake (Standard FSI one for now)
      APR High Pressure Fuel Pump
      Carbotech 1521 Pads front and rear
      I'm taking tomorrow off so I can throw the fuel pump and intake on to go get the stage 1+ flash and then I'll install the pads this weekend.
      Sunday is going to be a fun driving day.
    23. Member lobuzz311's Avatar
      Oct 12th, 2011
      San Jose, CA
      02-02-2012 01:56 PM #173
      Is there any way that you could post a DIY with pics of the brake pad replacement?
      I'd like to do it myself, but want to make sure I don't eff it up...
      Otherwise, I'll have to pay the dealership to do it when I pick it up and wait even longer before taking it off the lot!
      And yes, your Sunday sounds like it's going to be pretty epic!
    24. Banned
      Jan 30th, 2012
      Ohio
      72 TR-6, 78 911SC, 84 Vanagon Wesfalia, 06 Colorado, 00 Mk4 GTI w/R on order
      02-02-2012 02:11 PM #174
      Is there any way that you could post a DIY with pics of the brake pad replacement?.....
      http://forums.vwvortex.com/showthrea...7#post50122390
      http://forums.vwvortex.com/showthread.php?3942932
    25. Member lobuzz311's Avatar
      Oct 12th, 2011
      San Jose, CA
      02-02-2012 02:17 PM #175
