VWVortex.com - Transmission Adaptive Shift Resets
    Results 1 to 19 of 19
    Thread: Transmission Adaptive Shift Resets
      Nov 7th, 2011
      Woodbury, MN
      2008 VW Jetta 2.5
      01-20-2012 05:49 AM #1
      I was wondering if anyone knew the process to reset the adaptation on the thransmission for MkV cars with the 09G? When I enter the transmission menu the button for adaptation is grayed out. Is there a way to make this active or another way to reset the transmission adaptation?
      Thank you,
      Brad
    2. 01-21-2012 04:19 AM #2
      Sub system redundancy check
      FAIL !
      Nov 7th, 2011
      Woodbury, MN
      2008 VW Jetta 2.5
      01-21-2012 07:53 PM #3
      This is helpful how?
    4. Member
      Feb 25th, 2010
      Wilkes-Barre, PA
      01-22-2012 10:27 AM #4
      He's telling you follow the basic rules of the forum post an auto scan. With out the scan you fail the basic requirement. Good Luck
    5. 01-22-2012 11:51 AM #5
      Auto-scan or you get nothing, exactly.
      http://www.youtube.com/watch?v=M5QGkOGZubQ
    6. Member
      Nov 7th, 2011
      Woodbury, MN
      2008 VW Jetta 2.5
      01-24-2012 06:13 AM #6
      Ohhhh, the "rules" of the forum! I see. Well, I will see what I can do.
      Nov 7th, 2011
      Woodbury, MN
      2008 VW Jetta 2.5
      01-28-2012 05:05 PM #7
      As you requested, I guess I have an intermittent steering fault too.
      Saturday,28,January,2012,09:20:06:21859
      VCDS Version: Release 11.11.1
      Data version: 20111209
      Chassis Type: 1K0
      Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
      VIN: 3VWJM71K38M074150 Mileage: 122870km/76347miles
      01-Engine -- Status: Malfunction 0010
      02-Auto Trans -- Status: OK 0000
      04-Steering Angle -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: Malfunction 0010
      15-Airbags -- Status: OK 0000
      19-CAN Gateway -- Status: Malfunction 0010
      42-Door Elect, Driver -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      52-Door Elect, Pass. -- Status: OK 0000
      56-Radio -- Status: OK 0000
      62-Door, Rear Left -- Status: Sporadic communication error 1000
      65-Tire Pressure -- Status: OK 0000
      Address 01: Engine (CBT) Labels: 06A-906-032-BGP.lbl
      Part No SW: 07K 906 032 BJ HW: 07K 906 032 Q
      Component: 2,5l R5/4V G 1567
      Revision: 1NH01--- Serial number: VWX7Z0G924G0MV
      Coding: 0000003
      Shop #: WSC 00066 000 00000
      VCID: 72E1FC946DB4014
      1 Fault Found:
      005784 - Please Check DTC Memory of Steering Wheel Electronics
      P1698 - 001 - - Intermittent
      Freeze Frame:
      Fault Status: 00100001
      Fault Priority: 0
      Fault Frequency: 1
      Mileage: 122379 km
      Time Indication: 0
      Freeze Frame:
      RPM: 790 /min
      Load: 66.2 %
      Speed: 0.0 km/h
      Temperature: 78.0°C
      Temperature: 0.0°C
      Absolute Pres.: 980.0 mbar
      Voltage: 11.049 V
      Readiness: 0000 0100
      Address 02: Auto Trans Labels: 09G-927-750.lbl
      Part No SW: 09G 927 750 HE HW: 09G 927 750 HE
      Component: AQ 250 6F 1090
      Revision: 00H69000 Serial number:
      Coding: 0000584
      VCID: 7BFFD1B03AFE40C
      No fault code found.
      Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
      Part No: 1K0 907 379 P
      Component: ASR FRONT MK70 0105
      Coding: 0017025
      VCID: 3F8765A06E669CC
      Address 08: Auto HVAC Labels: 1K0-820-047.lbl
      Part No SW: 1K0 820 047 GF HW: 1K0 820 047 GF
      Component: Climatic PQ35 141 0909
      Revision: 00141027 Serial number: 00000000000000
      Shop #: WSC 00000 000 00000
      VCID: 6ED9E8E4798C254
      Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
      Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
      Component: Bordnetz-SG H54 2202
      Revision: 00H54000 Serial number: 00000000775964
      Coding: 14050E234004150007140000001400000008730B5C00010000 0000000000
      VCID: 6FE7F5E07E862CC
      Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
      Component: Wischer 251007 020 0501
      Coding: 00038805
      Shop #: WSC 00066
      1 Fault Found:
      01333 - Door Control Module; Rear Left (J388)
      004 - No Signal/Communication - Intermittent
      Freeze Frame:
      Fault Status: 00100100
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 107
      Mileage: 122367 km
      Time Indication: 0
      Date: 2005.09.13
      Time: 31:63:63
      Freeze Frame:
      OFF
      Voltage: 12.45 V
      OFF
      ON
      OFF
      OFF
      OFF
      Address 15: Airbags Labels: 1K0-909-605.lbl
      Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
      Component: 6A AIRBAG VW8R 034 8000
      Revision: 05034000 Serial number: 003B6M039YJL
      Coding: 0013889
      VCID: 6CDDE2EC4F90D74
      Part No: 1K0 959 339 F
      Component: BF-Gewichtsens. 007 0005
      Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
      Part No SW: 1K0 953 549 AP HW: 1K0 953 549 AP
      Component: Lenksäulenmodul 036 0070
      Coding: 0010021
      VCID: 8005265CD318A34
      Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
      Part No SW: 1K0 920 954 F HW: 1K0 920 954 F
      Component: KOMBIINSTRUMENT 3HL 1212
      Revision: V0002000 Serial number: VWX7Z0G924G0MV
      Coding: 0023203
      VCID: 2F6735E0BE066CC
      Address 19: CAN Gateway Labels: 1K0-907-530.lbl
      Part No SW: 1K0 907 530 L HW: 1K0 907 951
      Component: J533 Gateway H07 0052
      Revision: H07 01 Serial number: 041007F2000669
      Coding: ED807F070002021002
      VCID: 3065369CA338734
      1 Fault Found:
      Freeze Frame:
      Fault Status: 00110100
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 107
      Mileage: 122367 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 07:46:28
      Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
      Component: IMMO 3HL 1212
      Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
      Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
      Component: J386 TUER-SG FT 1133
      Revision: 32008001 Serial number: 00000523079004
      Coding: 0001205
      VCID: 3B7F11B07A7E80C
      Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
      Part No: 1K1 909 144 M
      Component: EPS_ZFLS Kl.070 H08 1901
      Shop #: WSC 02069 000 90108
      VCID: 356B07885C5A56C
      Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
      Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
      Component: KSG PQ35 RDK 052 0221
      Revision: 00052000 Serial number: 00000000000000
      Coding: 13900F880186281B0904058FB0880F0488DCA0
      VCID: 840D2A4CC700BF4
      Component: Sounder n.mounted
      Component: NGS n.mounted
      Component: IRUE n.mounted
      Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
      Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
      Component: J387 TUER-SG BT 1133
      Revision: 32008001 Serial number: 00000132179001
      Coding: 0001204
      VCID: 3C7D12AC7F70874
      Address 56: Radio Labels: 1K0-035-161.lbl
      Part No SW: 1K0 035 161 C HW: 1K0 035 161 C
      Component: Radio DE2 014 0019
      Revision: 00014000 Serial number: VWZ4Z7G6284114
      Coding: 0040401
      Shop #: WSC 06416 444 84484
      VCID: 1F47C520CEA6FCC
      Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
      Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
      Component: J388 TUER-SG HL 1120
      Revision: 12006001 Serial number: 00000002225946
      Coding: 0001168
      VCID: 3E7918A4696C954
      Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
      Component: RDK 0450
      Coding: 0100101
      Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
      Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
      Component: J389 TUER-SG HR 1120
      Revision: 12006001 Serial number: 00000002222638
      Coding: 0001168
      End ---------------------------------------------------------------------
    8. 01-28-2012 10:24 PM #8
      Nov 7th, 2011
      Woodbury, MN
      2008 VW Jetta 2.5
      01-29-2012 06:22 AM #9
      This link seems to not have anything on it. Could you try again?
      Brad
    10. Member
      Feb 25th, 2010
      Wilkes-Barre, PA
      01-29-2012 10:30 AM #10
      I tried to correct the link and also it wouldn't work. I have no idea why? So I copied and pasted the page instead.
      Basically it is telling you to clear codes in TCM.
      Do the throttle body adaptation.
      Then do the kick down adaptation of the gas pedal.
      What I don’t understand is that it’s telling you “Not” to hold the pedal to the floor for the kick down adaptation.
      I have never seen a kick down that didn’t require you to hold the pedal for 3 seconds.
      So I am at a loss there! Wait and see what Jack say’s because that doesn’t seem right.
      This is a 2008 model so it maybe something new?
      The ECU code 005784 - Please Check DTC Memory of Steering Wheel Electronics
      Is telling you to check the steering wheel electronics for codes. However address 16 & 44 show no problem or codes. I would just clear the ECU steering code and see if it returns then do the throttle body adapt and the kick down adapt. Good luck
      The copy & pasted page the link failed to point to is below…
      6-Speed Automatic Transmission (09G)
      From Ross-Tech Wiki
      Jump to: navigation, search
      Information
      The09G and 09M transmissions are built on the same version of the 6-speed automatic transmission manufactured by Japanese automatic transmission manufacturer AISIN Co., LTD.
      General Information about this Transmission is not yet available in the Wikipedia entry at this time. Additional information can be found in the Official Factory Repair Manual and sources such as Bentley Publisher's SSP (Self-Study Program) .
      Contents
      [hide]
      • 1 Coding
      • 2 Basic Setting
      o 2.1 Kick-Down Adjustment
      o 2.2 Special Notes
      Coding
      Due to all of the Coding variants for the 09G transmission it is recommended to use the coding from the original module when replacing the TCM. VCDS will display a coding chart a pop-up balloon while connected to the vehicle.
      Basic Setting
      Prerequisites:
      • No fault codes in the Auto Trans.
      • Throttle Body Alignment (TBA) performed successfully when applicable
      • Ignition on, engine off.
      • Do not touch the accelerator pedal.
      [Select]
      [02 - Auto Trans]
      [Basic Settings - 04]
      Set Group to "001"
      [Go!]
      System in Grundeinstellung will be displayed
      [Done, Go Back]
      Special Notes
      • It is normal for there to be no explicit instructions or changes on the screen when you do the above procedure other than "System in Grundeinstellung".
      • If faults are stored in the Engine or Transmission for throttle related problems, the procedure will not be successful.
      • The 09G transmission is commonly found in vehicles using the Drive-by-Wire (DBW) throttle systems. In most cases the ECM (Engine Control Module) should support a Kick-Down Basic Settings as described here: Automatic Transmission Basic Settings.
    11. Semi-n00b
      Oct 11th, 2011
      Stavanger, Norway
      12 Touran TDI DSG6
      01-29-2012 01:10 PM #11
      You missed the last character in the link:
      http://wiki.ross-tech.com/wiki/index...smission_(09G)
      Please try again.
    12. 01-30-2012 11:19 AM #12
      Link corrected. Thank you!
      Yes the procedure is correct Stan.
    13. Member
      Jun 1st, 2003
      Dearborn Heights, MI
      2005.5 MKV TDI
      01-30-2012 05:37 PM #13
      Rain Closing Windows, goF raeR, Aspherical Mirrors, Remote Windows, Amber Club
    14. Member
      Nov 7th, 2011
      Woodbury, MN
      2008 VW Jetta 2.5
      02-01-2012 07:04 AM #14
      I have already visited these, but they're not for the adaptive shift resets. The kickdown and throttle body adaptation is nice, but irrelevant to this concern. Also, an auto-scan was not needed for you to tell me what page at Ross-tech to visit as I told you what transmission and car I have. My concern was why the option for "adaptation" on the VCDS is greyed out when I access the TCM and was told an auto-scan would explain. Any help would be appreciated. Also, a thank you to Stan067 for taking the time to give an actual answer. Also, is there a resource where you can see what the most current software versions are for a vehicle?
      Brad
    15. Member
      Feb 25th, 2010
      Wilkes-Barre, PA
      02-01-2012 10:23 AM #15
      This is a VCDS forum sponsored by Ross Tech and the basic rule is post an auto scan. This is so people with pirated version of VCDS get no help. Basic rule auto scan or no help!
      The adaptation being grayed out is because it’s not available for your trans. As far as I know the kick down adaptation is the only thing you can do to set shift points for your trans. Throttle body adaptation is need also to set the shift points. As far as I know that’s all you can do to set the trans.
      Now is there a problem with the shifting of the trans? If so explain…
      I wish there was a place to find software versions only the dealer or the dealer repair online service.
      Good Luck
    16. 02-01-2012 11:17 AM #16
      Respectfully, the link, is the answer to your question in your post request.
      Just because you are inexperienced, or choose not to subscribe to a proper repair manual, is no reason to vent here.
      Yes, auto-scans here are required, or you can pound sand.
      Keep in mind, Ross-Tech offerers direct free hardware support for the first year after purchase of their devices, and then charges for support after that.
      You can always call them or maybe consider a Erwin repair manual.
    17. Member
      Nov 7th, 2011
      Woodbury, MN
      2008 VW Jetta 2.5
      02-01-2012 12:22 PM #17
      See how Stan was an adult and explained things rather than being a dick Mr. Shapiro?! Take note! Don't feed the new Yorker stereotype
    18. 02-01-2012 03:07 PM #18
      Well, I guess I'm that typical NY Dick! Hurray!!!!!!
      I still believe if you took the time to actually read the forum rules, or have the repair manual read to you, you would of maybe had a better understanding of your problem.
      Instead you would rather not recognize your mistake, and vent on me, which is fine, I don't mind at all.
      I hope it helped your health using me as your scapegoat.
    19. 07-25-2012 04:15 AM #19
      Probably it is too late, but according to document for the transmission I have the procedure is as follows:
      1. Select "01 - Engine" (not TCM)
      2. Click "Adaptation"
      3. Select chanel "0" -> Go
      4. Click "Save"
      5. Confirm on the poped up dialog
      this will reset engine learning values to their factory defaults as well the gerabox learned values.
      When you start the engine, the learning starts from the begining.
      I did it and it works. I have 2009 Tiguan 2.0TSI with 6 speed auto (09M). Basicaly both gear boxes are the same.
