VWVortex.com - MKIV R32 Engine Build
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 78
    Thread: MKIV R32 Engine Build
      Jun 16th, 2005
      NY
      2001/VW/Jetta GLX
      01-20-2012 10:27 PM #1
      So I had my MKIV R32 for sale for a few weeks, with a hydrolocked engine. Too many fake offers, and low offers. So I decided to keep the car, and build the engine. Here is my step by step build.
      Not really a step by step. I did not choose to show all the bolts and nuts, and locations, and how to remove. SO you'll see the major parts removed step by step (KINDA). I would have liked to do a detailed version, but anyway. Here is the beginning.
      Tools Required
      And of course an engine stand and engine hoist.
      Removed the oil pan to see the damage. Cylinder 2 rod bent.
      Front end removed, intake manifold removed, coolant hoses and AC lines disconnected.
      Water Damage
      Pushed all the wires to the side
      Engine is finally out
      There she isssssssss
      Removed all the parts off the block. Front and back
      Removed the clutch, flywheel, valve cover, and timing chain covers.
      Removed the head and set aside on the tool box
      View of the engine block. You can see cylinder #2 has all the oil in it.
      Engine block is stripped down
      Engine Block is back from the machine shop...The piston rings, main cap bearings, and rod bearings have been replaced with all new parts. The pistons and rods were purchase from a vortex member with only 37,000 miles. They looked practically brand new when I got them. They were however cleaned and checked at the machine shop. The clearance between the cylinders and the pistons were within manufacturers specs.
      These are the pistons and rods before the machine shop
      These are the pistons and rods that I got. This was before they were sent out to the machine shop.
      Cylinder Head has been rebuilt.
      Time for assembly
      Parts arrived. A list of parts will be given at the end.
      New head gasket and head bolts
      IMPORTANT MESSAGE
      For anyone looking to do a build similar to this, on your own, make sure you have this oil non return valve after the machine shop is done working on it.
      Installed new front crank seal.
      Used a socket that was real close to the diameter of the seal, and slowly tapped it in.
      Installed the front cover. I used the red gasket sealant.
      Set the crank tool, and torque down the crank pulley. (I will post all torque specs at the end)
      Set cylinder 1 to TDC, you can see the slit and the line match up near the crank. Also the drive gear (wear the flywheel bolts onto), there is only one ground tooth, it has to line up with the main cap mating line to the engine block (not shown).
      Installed the oil pump drive, intermediate shaft, and intermediate shaft ring.
      Place the head gasket and then carefully line up the head bolt holes with the engine block head bolt holes. It helps to have an extra hand. I finally got it after 4 tries, my shirt kept kitting the gasket, and the head is real heavy and you don't want to drop that. Any build requires patience.
      This step is crucial. Part of the timing, involves the camshaft lobes for cylinder 1 exhaust and intake, to face each other. I had to take my head back to the machine shop because they had the cams backwards. If your confused on which camshaft is which, I called my local VW dealer, and gave them my VIN #, they verified for me. It is a 9 digit number, the last three differentiate by a digit. The exhaust cam shaft number ends in 102A, and the intake camshaft ends in 101C. It is located on the camshaft body, near the 32mm hex, where you would normally put an open end wrench to turn the cam.
      The camshaft adjusters are also interchangeable. The intake adjuster is 24E, and the exhaust adjuster is 32A. Its an idiot proof system.
      The cam tool used was from Baum tools, for only $20.00. Its made of plexiglass. Unfortunately it didn't last too long. So I used it as reference to mock up the tool into Solidworks software, and I'm getting one made. Why pay over $100.00 for the metal version?
      SO I used the 12V cam tool temporarily.
      Flipped the engine over to install the oil pump. I should have done this first, but whatever.
      Cleaned the oil filter housing with parts washer purchased at autozone.
      Assembled the oil cooler and oil filter housing, and bolted back to the block.
      Flipped the engine back around. Time to install the oil control housing. It is important to check the red seal (see second picture below). Mine was still good.
      Also order a new chain rail. (located on the oil control housing)
      Removed the camshaft adjusters to install the oil control housing.
      Once the oil control housing is installed, the camshaft adjuster bolts were torqued. To do this, you can see I had to counter hold the camshaft using a 32mm open end wrench.
      Installed the accessory bracket, water pump and pulley, alternator, power steering pump and pulley, AC compressor.
      Also installed the coolant water pipe with new o-rings.
      MORE TO COME. TIMING IS NEXT
      Here are some pictures to enjoy...
      Cleaned the flywheel myself.
      Before transmission cleaning
      After cleaning
      I cleaned it one more time, I will have pics soon
      Audi B7 License Plate Frame
      Let there be light. Installed two of them. You can see it in the back.
      Who said you need a shop to do the work?
      All my cars over time.
      2000 Jetta GLX 5 Spd
      2001 Jetta GLX automatic. Bought this at the same time as the one with the GTI front. Built both simultaneiously. One was at home, the other one was at my job. Bought this one with a timing chain rail broken.
      2001 Jetta GLX. Two years ago
      This one also went under some work. Bought it with a blown motor. There was a hole in the block.
      2001 Honda Prelude Type SH. This is what I was driving while fixing both of the above Jettas.
      SOLD ALL THE CARS ABOVE. Got married, then got this original owner 2003 GLI 24V.
      Purchased with 88,000 miles. Sold at 91,000 miles for the R.
      Now this one
      Oct 26th, 2010
      Little ol UK
      Snailed Vee
      01-25-2012 06:20 AM #2
      Now is the chance to give the bay a real makeover and bring the baby back to the 21st century.
      Steve
      Jun 16th, 2005
      NY
      2001/VW/Jetta GLX
      01-25-2012 01:24 PM #3
      Quote Originally Posted by sTT eV6 View Post
      Steve
      yup, once the motor is out, going to power wash the bay. clean it up.
    4. Member 02vwgolf's Avatar
      Oct 6th, 2009
      SE-PA
      02 vw golf, 88 Toyota Hilux, 93 4runner(sold), 97 VR jetta(sold)
      01-26-2012 09:25 AM #4
      Glad you didnt sell it or scrap it One more r32 that will stay in the hands of an owner that will fix her haha
      Oct 26th, 2010
      Little ol UK
      Snailed Vee
      01-28-2012 01:51 AM #5
    6. Member 02vwgolf's Avatar
      Oct 6th, 2009
      SE-PA
      01-30-2012 06:19 PM #6
      Good progress
      Jun 16th, 2005
      NY
      2001/VW/Jetta GLX
      01-31-2012 03:36 PM #7
      Quote Originally Posted by 02vwgolf View Post
      Good progress
      thanks.
    8. Member vr6fanatic's Avatar
      Apr 4th, 2003
      Mass
      2004 VW R32, 2016 VW Jetta sport.
      02-11-2012 09:37 PM #8
      Keep us updated
    9. Junior Member albaneg's Avatar
      Apr 22nd, 2004
      Long Island, NY
      2004 MK4 R32 Reflex Silver
      02-13-2012 10:13 AM #9
      Awesome.... really glad that you did not scrap it.
    10. Member ebro's Avatar
      Apr 2nd, 2009
      Cranford, NJ
      JB20thAE
      02-18-2012 06:09 PM #10
      that looks awesome, good luck
    11. Member
      Jun 16th, 2005
      NY
      2001/VW/Jetta GLX
      02-18-2012 06:56 PM #11
      Quote Originally Posted by ebrown520 View Post
      thanks, you still have the jetta?
    12. Member 02awp18705's Avatar
      Jan 18th, 2009
      NEPA
      04 R/90 BT corrado/02 BT TT
      02-19-2012 10:22 AM #12
      gl with the rebuild . What are your plans for the engine ?
    13. Member
      Jun 16th, 2005
      NY
      2001/VW/Jetta GLX
      02-19-2012 02:50 PM #13
      honestly, just keeping it stock, just to keep it simple.
    14. Member ebro's Avatar
      Apr 2nd, 2009
      Cranford, NJ
      JB20thAE
      02-19-2012 02:57 PM #14
      Quote Originally Posted by boraspecvr6 View Post
      yes i do, still running stong ill trade it back to you for the finished R
    15. Member
      Jun 16th, 2005
      NY
      2001/VW/Jetta GLX
      02-19-2012 10:31 PM #15
      LOL, that would be loss on my end. I'm glad you still have the car. If you need anything, you know where to reach me.
    16. Member ebro's Avatar
      Apr 2nd, 2009
      Cranford, NJ
      JB20thAE
      02-20-2012 04:16 PM #16
      haha it was worth a shot, (it does have a brand new trans) and ill probably be looking for things once i get some money together
    17. 02-22-2012 12:36 AM #17
      usually a hydro locked motor has a bent rod you should get the head and crank checked by a machine shop.
      Racing Improves the breed..
      "I have fought the good fight, I have finished the race, I have kept the faith"- 2 Timothy 4:7
      CrossroadsLI
      MY ALL MOTOR BUILD THREAD
    18. Member haf1zur's Avatar
      Feb 20th, 2006
      UK Golf R32 2004
      02-22-2012 09:46 AM #18
      feel for you
      i had a hydrolocked engine
      one of the rods snapped in half
      two others were bent
      had the crank and the case checked but they were fine
      not sure about US r32's but the UK MKIV's had a forged crank which was good
    19. Member
      Jun 16th, 2005
      NY
      2001/VW/Jetta GLX
      02-23-2012 11:54 PM #19
      Yea my next step is to take all the parts to a machine shop.
    20. n00b
      Feb 22nd, 2012
      S.E.MI.
      02-27-2012 10:41 AM #20
      Great to see this rebuild. I look forward to seeing the progress.
    21. Member vr6fanatic's Avatar
      Apr 4th, 2003
      Mass
      03-20-2012 11:36 PM #21
      Now is also a good time to replace (if need be) Alternator, Starter. Etc...
    22. Member
      Jun 16th, 2005
      NY
      2001/VW/Jetta GLX
      03-21-2012 01:10 PM #22
      Quote Originally Posted by vr6fanatic View Post
      Yea thats true, but I dont need the extra expense. I will double check that before the nose goes on.
    23. Member 02vwgolf's Avatar
      Oct 6th, 2009
      SE-PA
      03-21-2012 10:44 PM #23
      Wow that rod had like a perfect wave to it haha atleast when its back together you will know you wont have to do anymore maintenance for a while
    24. Member DRedman45's Avatar
      Aug 7th, 2009
      NOVA
      07 SB Rabbit(sold), 10 UG 4dr GTI(sold), e86 //M coupe
      03-22-2012 11:16 AM #24
      I have never seen a rod bend like that without breaking...good luck with the rebuild...its a good opportunity for some lower compression and boost
    25. Member
      Jun 16th, 2005
      NY
      2001/VW/Jetta GLX
      03-30-2012 04:31 PM #25
      Quote Originally Posted by DRedman45 View Post
      I hear you, but i dont have the budget for that right now, i have twin baby girls!!!
      I might , not sure, do a wire tuck though
