Page 1 of 2 1 2 LastLast
Results 1 to 35 of 46
Thread: My first car (98 VW GTI VR6) & Build thread.
  1. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    Mkiii GTI (sold),Mkiv Golf TDI Stage 3+, MKVI JSW TDI, 85 Celica XT.
    01-22-2012 01:36 PM #1
    So some of you may have seen my posts in the classifieds for a while looking for an MKIII, and I looked at a few of craigslist and none really were a good deal, and people tried to rip me off. Recently I took a drive to Clearwater (2-ish hours from Orlando) and picked up my 98 GTI for $2,150, has 96,xxx miles has no rust and some upgrades.
    Done by PO:
    ~A dumb a$$ white hood (said he planned on a checkerboard design).
    ~Neuspeed catback.
    ~Ground Control Coilovers (also included a neuspeed set, and a set I can't find the name for).
    ~Neuspeed P-chip computer.
    The car does need some work though (it came with all of the parts to fix it).
    ~Front wheel bearings.
    ~Front control arms with bushings and ball joint.
    ~Both front window regulators.
    ~Also the hatch doesn't open via. the key or the button inside, any ideas?
    Link to an album of pics (before the wash). Also don't mind the white hood, PO wanted to do a checkerboard design:
    http://s1084.photobucket.com/albums/..._scotty/98GTI/
    Thanks for looking and I hope to spend all my time on this forum,
    ~Scott.
    Quote Originally Posted by 12V_VR View Post
    Gave some honda kid a ride in the vrt and popped his cherry
    My 98 GTI VR6 Build Thread.//My WTB Thread//FS White Boxes & Cruise Control Box//FS Suspension Parts
  2. Member 95jetta17's Avatar
    Jan 20th, 2008
    York, PA
    95 2.0 turbo, 97 vr6
    01-22-2012 03:08 PM #2
    link doesnt work
    OG suede
    I survived epic thread 2011 never forget 11/11/11
    Quote Originally Posted by vastxpunk View Post
    You have a harness you forgot to plug back in, and you want to know where it goes? Back where you found it would be my guess..
    Feb 8th, 2011
    New Hampshire
    00 gti
    01-22-2012 09:46 PM #3
    You WILL spend all of your time here.
    and link not working.
  4. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-22-2012 11:33 PM #4
    Quote Originally Posted by 95jetta17 View Post
    link doesnt work
    Quote Originally Posted by yeabmx View Post
    Sorry, was at work, link fixed.
    Ok so I did the window regulators today (both), one problem on the pass. side window when I put it up it goes up 3/4 of the way and then comes back down, if I tap the switch it goes all the way up. Any ideas?
    Tomorrow I plan on tackling both front bearings and the control arms, wish me luck.
    ~Scott.
  5. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-23-2012 11:20 PM #5
    Attempted to do the front wheel bearings and control arms this morning before work, didn't realize it would take all day.
    Control arm bushings are shot.
    Attempting to bang the axle from the hub.
    This.
    This.
    Then did some searching on the forum and found that I needed this, it's a hub puller and I STRONGLY suggest getting one before attempting to change the bearings.
    New bearing in.
    That's all for today, I have to get the control arm out (oil pan in the way of the far right nut on the control arm. Also think the PO gave me the wrong control arms, I may need to just put poly bushings all around and be done with this ****.
    ~Scott.
  6. 01-23-2012 11:31 PM #6
    Looks like you need a new CV boot too.
    Golf bumpers don't belong on Ventos
    European Performance Products
    PVW 5/11 Held It Down
  7. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-23-2012 11:35 PM #7
    Quote Originally Posted by GTi2OV View Post
    Link, please?
  8. Member ZACHER3tuning's Avatar
    May 12th, 2008
    Colourful Colorado
    1998 Mk3 GTI VR6.with 19,XXX original miles.1999 Mk3 GTI VR6."silver arrow".1991 MK2 Jetta 8V.
    01-23-2012 11:50 PM #8
    look at your pics again, why do you need a link
    Quote Originally Posted by cheeze you View Post
    Link, please?
    Geld und Macht bringt korruption!!!
    Von allen je gebauten volkswagens,steht man Kopf über den rest,den mk3 golf VR6
    "stop telling lies about me, and ill stop telling the truth about you"...MD.
    WWW.1stVWparts.com
  9. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-23-2012 11:56 PM #9
    Quote Originally Posted by ZACHER3tuning View Post
    Link to the part..........
  10. 01-24-2012 01:59 PM #10
  11. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-24-2012 11:49 PM #11
    Thanks man, I'll have to look into that. Not a bad price either.
    Also something to tide me over and keep me motivated while I wait on these
    http://www.ebay.com/itm/380373476382...84.m1423.l2649
    Jun 14th, 2007
    E36, R32
    01-25-2012 12:07 AM #12
    damn, that sounds rough.
    have a CEL?
    welcome to the layer cake
  13. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-25-2012 12:10 AM #13
    Quote Originally Posted by n0rdicalex. View Post
    have a CEL?
    Yeah, haven't had the time to run it and see what codes come up. The PO said it needs a new MAF. Sounds like a ***king bike.... I thought maybe it was cause of being chipped and the cat being hollowed but ehhhh... I'm listening to all opinions..
  14. Member
    Jun 14th, 2007
    E36, R32
    01-25-2012 12:57 AM #14
    doesn't sound like it's firing on all cylinders or it has a misfire(s).
    most likely ignition related, but i'd be curious to see what a compression test would yield.
  15. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-25-2012 06:26 AM #15
    Thanks for the info man, you think it's as easy as a bad spark plug / wire, or the coil pack or as serious as a failing cylinder?
    Once I get the bearings done and if it runs ok I'll shoot down to autozone ( like ten mins down the road ). They can read it and throw me the code for free. But isnt there a little plug that came in mk3's that went into the OBDII port and I could get a code that way?
    Thanks,
    -Scott.
  16. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    98 GTI Vr6-T (Project) | 96 GTI Vr6 (SOLD) | 97 Passat Wagon Vr6 (Daily)
    01-25-2012 06:42 AM #16
    That does NOT sound like a vr. Get the codes!
  17. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-25-2012 06:57 AM #17
    Quote Originally Posted by Insan3Vr6 View Post
    I have a snap on reader that does OBDII but I don't think I have the VW one.. They expensive?
  18. Member 87veedub's Avatar
    Oct 22nd, 2007
    Lancaster, PA
    8v army
    01-25-2012 11:24 AM #18
    Use the snap on one and post up what codes you have on here.
  19. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-25-2012 11:28 AM #19
    Quote Originally Posted by 87veedub View Post
    I don't own one... Or at least my car didn't come with one when I got it...
  20. Member 87veedub's Avatar
    Oct 22nd, 2007
    Lancaster, PA
    8v army
    01-25-2012 12:51 PM #20
  21. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-25-2012 01:02 PM #21
    Yes snap on as in the tool company. I DO NOT HAVE THE PLASTIC ONE THAT CAME WITH THE CAR..
  22. Member sk8too's Avatar
    Dec 22nd, 2004
    Offutt AFB, NE
    97 Jetta VR swapped. 2010 CC VR Executive
    01-25-2012 01:06 PM #22
    holy crap that isn't running well...if it was a MAF the idle would be very different. after the scan I'd do a FULL tune up plugs,wires,fuel filter whole sha bang
    97 Jetta GL, OBDI VR swapped, 262 cams, GIAC chip, turn 2 style CAI, Magnaflow catback, 2.9 clone manifold, eurospec flywheel, B&G RS2 coilovers, MKIV front and rear seats
  23. Member sk8too's Avatar
    Dec 22nd, 2004
    Offutt AFB, NE
    01-25-2012 01:09 PM #23
    what are you talking about man? Thats whats got us confused, if you have a snap on OBDII reader you can plug that into the OBD port above the cig lighter and get the codes. I think what your talking about is the vagcom cable, you dont need that to just read codes....or am I misunderstanding what your saying?
  24. Member 87veedub's Avatar
    Oct 22nd, 2007
    Lancaster, PA
    8v army
    01-25-2012 01:50 PM #24
    Quote Originally Posted by sk8too View Post
    ^This. Are you missing the port all together. Any obd2 scan reader will plug in to the port. The port is behind the dummy plate above the cig lighter. You have to pull out the ash tray and slide it towards the driverside of the car. Voila there is your obd port
  25. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-25-2012 02:08 PM #25
    I might be mistaken but the reader I have needs cartridges ( like a n64 ) for different types of cars and models.....
    What I meant was that and the fact that my car didn't come with the OBDII plug so the car would spit codes out without a reader...
    Sorry to confuse you, once the bushings are in I will do a read whether I do it or take it to autozone for a free read and then a full tune up oil, plugs, wires, filters, needs tires like a b***h too.
    Thanks for the replies guys.
    People on here are more helpful than any other forum I've been on...
  26. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-25-2012 02:40 PM #26
    I have this scanner.
    These are the cartridges I'm talking about.
  27. Member 87veedub's Avatar
    Oct 22nd, 2007
    Lancaster, PA
    8v army
    01-25-2012 03:15 PM #27
    Gotcha
  28. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-25-2012 04:14 PM #28
    Gotcha
    I'll probably go to autozone and have them run it after I put the new bushings in the control arms...
  29. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-28-2012 12:19 PM #29
    Got the old bushings out on the passenger side... Just waiting on FedEx to deliver my new prothane bushings...
  30. Member 87veedub's Avatar
    Oct 22nd, 2007
    Lancaster, PA
    8v army
    01-28-2012 10:09 PM #30
    What in the hell are you using to get the old bushings out?
  31. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-28-2012 11:19 PM #31
    An array of tools. A tool for putting in bushings. And mainly a chisel and a hammer works good.
  32. Banned vento86's Avatar
    Oct 13th, 2008
    01-29-2012 03:34 AM #32
    Snap on vantage? Can't really tell by the pics but I have that same one.
  33. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-29-2012 09:18 AM #33
    Quote Originally Posted by vento86 View Post
    Probably. I just need to figure out how I'm gonna scan my car, since it's not on the road, needs tires, and I can't get it to autozone.
  34. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    01-31-2012 05:15 PM #34
    Alright both front control arms and wheel bearings are in and done! now I need to get (borrow) an OBDII scanner, and find out why she's running rich. Then tires, battery, registration and FUN!
  35. Member cheeze you's Avatar
    Dec 31st, 2011
    Davenport, FL
    02-02-2012 01:57 PM #35
    She's still running rich, check spark plug wires. They were ok so it's not the coil pack. Pulled the MAF with it running, and it completely shut off so the MAF is good... I'm at a loss for options here... Could it be due to the neuspeed P chip and tune????
