VWVortex.com - Passat in Snow?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 39
    Thread: Passat in Snow?
    1. 01-22-2012 05:42 PM #1
      Just considering getting the new passat.
      Has anyone driven it yet in bad weather? It's not 4wd, but hows it do? I shouldn't need to drive through anything crazy, and I don't need awd, but I'd like a car that can make it through a few inches of snow without having to worry.
    2. Member cfurman's Avatar
      Feb 4th, 2008
      Michigan
      way too many to list...
      01-22-2012 07:36 PM #2
      It is actually great! Usually on other cars would turn off ESC. But VW did a great job with the permanent system. Had a few inches last week and drove into work with no issues at all on unplowed roads. Only AWD would be better IMO.
      ________________________
      2015 Audi S4 6MT, B&O, ASD
      2014 Tiguan R-Line 4-Motion
      Oct 10th, 2011
      Mexiland
      2012 B7 Passat
      01-22-2012 08:08 PM #3
      Of course is not an AWD but i think that if you drive as you should in bad weather and you have the right tires the independent rear suspension, traction control, electronic brake disribution and electronic brake assist will take good care of you
    4. 01-22-2012 09:28 PM #4
      6 inches of snow yesterday - had no problems - some areas not plowed at all
      Mar 22nd, 2006
      2013 CC R-Line DSG
      01-22-2012 10:54 PM #5
      Are you guys using OEM all season tires or snow tires?
    6. Junior Member
      Sep 25th, 2011
      Boston, MA. U.S.A
      2012 Passat TDI SEL Premium
      01-22-2012 11:20 PM #6
      The car is very good in the snow better that I thought it would be running the factory tires.
      Dan D
    7. Member cfurman's Avatar
      Feb 4th, 2008
      Michigan
      01-23-2012 10:00 AM #7
      Quote Originally Posted by sbkim View Post
      OEM Bridgestones on mine.
      Dec 6th, 2011
      2012 Passat TDI SE Roof/Nav/18s
      01-23-2012 01:53 PM #8
      OEM Bridgestones on mine. Car drove fine with acceleration, braking and turning typical of past large front drive sedans I have driven. I did a few slow starts on some minor inclines, not too bad and the traction control doesn't cut power completely and keeps you going.
      I haven't driven it enough in the snow to compare against my past front wheel drive cars and my past rear wheel drive with snow tires. I will update when I get the chance.
      I think better all seasons and definitely snow tires would help. If you check tirerack, our OEM tires are not the best rated (typical with OEM tires from most auto manufacturers).
    9. 01-23-2012 08:14 PM #9
      Thanks for responses, sounds good. Particularly glad that the traction control doesn't totally cut out--the lack of a "traction off" button initially had me uneasy.
    10. 01-23-2012 11:17 PM #10
      Hankooks as supplied
    11. Junior Member
      Nov 11th, 2011
      Palmer, Alaska
      01-23-2012 11:44 PM #11
      45 miles each way to work up here in Alaska.
      Handles great, can't complain.
      One of our Passat's is running Hakkapellita's and the other is running Blizzak's. I'll probably put Hakka's on both next season and hearing those studs is always comforting.
      PassatupNorth
      2012 TDI SEL DSG Platinum Grey Metallic
      2012 TDI SEL DSG Black
      Moose Dodger!
    12. 01-24-2012 03:15 PM #12
      It handles great in the snow! I even tried yanking the E-Brake to get the rear end to slide out - the ESC wouldn't allow it to happen. I have been thoroughly impressed! Handles much better than my Maxima did. BTW, I have the OEM tires and a TDI SE 6M
    13. Awaiting Email Confirmation
      Jul 20th, 2004
      South Coast (508)
      2014 VW Passat TDI
      01-26-2012 08:02 PM #13
      Just had a 10inch snow storm a week ago, and the stock Hankooks handled all the unplowed roads very well. I was impressed with how it handled the snow, especially since I'm used to driving my Discovery.
    14. Junior Member
      May 30th, 2009
      Prince George, BC
      2006 Dodge 3500, 2012 TDI Passat (DSG)
      02-05-2012 10:11 PM #14
      I am running 215-65-16" General Altimax Arctic tires and they are great in snow and very quiet. I suspect that the tread wear won't be the greatest but short of having a 4x4 they certainly do the job and are much better in snow than the all seasons that came with the car.
    15. Member AufMitDemSpiel's Avatar
      Nov 15th, 2012
      Idaho Falls, ID
      It sukz cuz you a bad azz yo
      02-04-2014 09:42 PM #15
      I have been getting around okay with Michelin Primacy MXV4's... But having to stop on a slight incline still makes me feel a bit nervous
      Blah blah car stuff
    16. Junior Member
      Jan 29th, 2013
      Dublin, Ireland
      B7 Passat TDI
      02-05-2014 11:53 AM #16
      The TDI's are especially good in this weather, the low end torque, allowing for higher gears at lower speed make it really good. Also with most of the weight over the drive wheels means the ice and snow doesn't have a chance
      Although I do drive in winter with winter tyres myself, normal tyres will get you around, but emergency situations will show you otherwise, If you have consistent snow I would recommend winter tyres.
    17. Senior Member christofambrosch's Avatar
      Jul 4th, 2011
      Pennsylvania
      2015 Audi A4
      02-05-2014 11:58 AM #17
      If you knew what I drove through to take this photo, you'd know these are great.
      22 | 365 by santorum, on Flickr
      I like having the extra weight from the VR6 and DSG.
    18. Junior Member
      Jan 29th, 2013
      Dublin, Ireland
      B7 Passat TDI
      02-05-2014 12:01 PM #18
      Quote Originally Posted by VR_Kraut View Post
      LOL it's so low it's like a plow, Probably has the same power as well
      I'm sure your neighbors wait for you to drive out first to clear the road.
      Pretty awesome pic by the way.
      I got this one last year in Poland (pre-lowered):
    19. Senior Member christofambrosch's Avatar
      Jul 4th, 2011
      Pennsylvania
      2015 Audi A4
      02-05-2014 12:08 PM #19
      Quote Originally Posted by maceocc2 View Post
      Nope. Air suspension lets me drive normally.
    20. Member gawa's Avatar
      Dec 29th, 2003
      Toronto, Ontario
      12 Passat, 11 C63
      02-05-2014 12:20 PM #20
      I'm on General Altimax Arctic tires as well and it's been great this winter, haven't had any issues driving through the several snow and ice storms we've had in the north east.
    21. Junior Member
      Jan 29th, 2013
      Dublin, Ireland
      B7 Passat TDI
      02-05-2014 12:22 PM #21
      Nice, Always wanted air suspension. Unfortunately two expensive in Ireland. For the system I wanted €1800 (~$2500).
      I got Koni coilovers instead, which are good to be fair, just not as good as air.
    22. Junior Member blSwagger's Avatar
      Sep 9th, 2009
      New York
      '11 GTI 4dr DSG w/ sunroof
      02-05-2014 06:09 PM #22
      My wife has a '12 Passat with Hankooks. They are the worst OEM tire I've ever driven. Over the summer I was driving on the highway going maybe 50-55mph and I was constantly hydroplaning. It was scary.
      Today, it took my wife half an hour with the help of 5 guys(!) to get out of her parking spot. We only had a few inches of snow and ice. The Pirellis on my GTI may have been slightly worse in the snow, but at least they were great on dry and wet roads.
    23. Member
      Jun 24th, 2008
      Topeka, KS
      2012 VW Passat SE w/ Sunroof & Nav | 2009 VW Jetta SE w/ Sunroof | 97 VW Jetta GLS w/ Sunroof(Sold)
      02-05-2014 06:52 PM #23
      I always had trouble with tires on my '97 Jetta, especially on wet roads at highway speeds. A semi would go by, and you'd be white knuckling it to keep the car on the road. Over the 14 years / 300,000 miles / 25 states that I've driven the Jetta, I found the best solution was to keep the tires around 40 - 42 psi. But I agree with you that the Hankooks suck as sticking to the road.
    24. Member
      Feb 12th, 2012
      Upstate NY
      2016 Passat SE w Tech; 2014 Tiguan SEL 4Motion, 2013 Passat TDI SE 6M
      02-05-2014 07:27 PM #24
      We've had tons of snow here this winter and I also went up to Canada at Christmas (to get even more). I'm running Michelin X-Ice snow tires and haven't had any problems. Highly recommend snow tires to give yourself added traction.
    25. Junior Member blSwagger's Avatar
      Sep 9th, 2009
      New York
      02-06-2014 12:23 PM #25
      Quote Originally Posted by KurtK View Post
      I wouldn't get snow tires for a leased car living in Long Island where we get only a few snow storms per winter. This winter has been pretty rough though. My wife is ready to trade in her Passat after 19 months for an Outback. That's what she originally wanted, but went with the Passat SE to save a ton of money (lease payment is only $315/month with nothing out of pocket, including taxes, etc.). Plus, they took my wife's Jetta back 3 months early. It was our 3rd VW in 3 years, so my salesman hooked us up to help him make room for '13s. I'm sure the Passat would be better with better tires. Other than poor traction on wet and icy roads, we love the Passat.
