Results 36 to 70 of 100
Thread: My "I want my Caddy to drive better." Build thread. And I need your help!
  1. Member PoLock33's Avatar
    Aug 14th, 2011
    B'Ham WA
    1982 Jetta coupe 1.6D, 1989 GTI 1.8 16v, 82 rocco
    01-31-2012 12:37 AM #36
    Have you done your motor mounts yet? if not i suggest you locate a dial indicator to time your IP after you reassemble everything. if you have, good on ya
    No Bad Days.
  2. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    95 jetta vr6 (rip) 95 cabrio Vr6 in PA, 2012 Harley Forty-Eight
    01-31-2012 12:46 AM #37
    I havent yet. I'm waiting on the new pump from giles to be built, then I will tackle the mounts with a new VC gasket, timing belt and timing the engine/pump. I've never done it so I've been reading as much as i can on it.
    Hopefully sometime tomorrow I can go about checking my hazard switch. I was thumbing through my bentley and found the troubleshooting portion. Hopefully this will get rid of my woes.
  3. Member Rockerchick's Avatar
    May 10th, 2005
    Cary, NC
    '03 BMP 20th GTI, '84 TD Jetta
    01-31-2012 09:49 AM #38
    Quote Originally Posted by Charcoal_Grey View Post
    and I went to a shop and asked if I brought the engine mounts and injector pump, would they put it in for me. the quote was $425 for just the pump. I was astonished. They said it took a very long time to purge the system of air. has anyone changed a pump....is it really that bad? I feel like that can't be right at all.
    That is nuts. $425 for labor to put on the pump? All you need is a mity-vac to get the air out. Doesn't take all that long either.
    The project - '84 Jetta 1.6TD, 186k+, fully rebuilt, Giles IP and injectors, 2.5" custom exhaust, 51mpg
    Hers - '03 BMP 20thAE GTI, 125k, all stock...for now
    His - '01 Jetta TDI, 126k. Now has 3 pedals, as it should!
  4. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    01-31-2012 12:20 PM #39
    I know. It's really not that much work. I just dot have the timing tools to do it so I figured I'd just have a shop do it. But that's rediculous.
  5. Member PoLock33's Avatar
    Aug 14th, 2011
    B'Ham WA
    01-31-2012 03:06 PM #40
    I like what i read!!! glad to see another 1.6D being taken care of!
    No Bad Days.
  6. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    02-02-2012 01:27 AM #41
    Mailman brought me a GAP package and a MK1autohaus package.
    Tie rods and boot kit
    H4 headlights
    lower steering column bearing
    ball joints
    control arm bushings
    blower motor.
    Hopefully I will be able to get this in this weekend. Today was the 1st Marine Division's anniversary so I got to work at 0530 and I just say down back in my room. Ugh. Looooong day. and I forgot to order a heater switch. so I will have to wait for that before I see if my blower motor will work. ugh
  7. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    02-02-2012 06:38 PM #42
    Put the new lights in. Idk if I'll be driving tonight, but It really cleans up the front of the car. I need to get som new chrome to go around the lights since mine is pretty rough, but overall I really like the fact that they are clean instead of old looking
    I might put the blower motor in today, although there really isnt a reason since I don't have a swich. the rest, who knows. Idk if i'll have off this weekend.
  8. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    02-04-2012 08:28 PM #43
    Finally put the blower motor in. In the process broke the tabs off on the acces panel for the heater core. :/ but on a good note I have heat now. I found a 4 speed switch in a junkyard but I need a 3. I'll have to get one from GAP.
    New control arms in the mail.
  9. Member ducatipaso's Avatar
    Apr 13th, 2003
    norcal
    82 aaz pickup
    02-05-2012 12:41 PM #44
    nice work dude. we are travelling down the same road at the same time. I don't have a build thread on vortex but in your spare time you can read up here. keep it up!
    wanted: early MK2 Golf or Jetta GTD rear badge -- any reasonable condition
    click
  10. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    02-05-2012 07:07 PM #45
    Thanks man. You're caddy is lookin good too. heaters are amazing in the morning when you can't see trough your window.
  11. Member Road Boss's Avatar
    Jul 15th, 2004
    Woodbridge, VA
    84 VW Rabbit GTI, 84 VW Jetta Coupe
    02-05-2012 07:57 PM #46
    Are you on Camp Pendleton?
  12. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    02-05-2012 08:49 PM #47
    Yessir.
  13. Member 8v-of-fury's Avatar
    Jul 14th, 2008
    Central Ontario, Canada
    Because MK1
    02-05-2012 09:05 PM #48
    75-79 got the 1.5, 80-85.5 got the 1.6 mech, 85.5-92 got the 1.6 hydro.
    81 was the changeover year for 11mm to 12mm head bolts.
    Also I can see a shop charging $425 for the mount and labor to do passenger side mount by itself.. Lets be real here, there is quite a bit of work involved with doing the passenger side motor mount.
    Pump needs to come off, motor needs to be supported, and the bolt for the mount taken out. Mount pressed out and in, and then everything has to go back together and even possibly come back apart if they don't get it lined up right as the belt may track. Unless they are a diesel specific shop, this may be a job that could take a while.
    I personally feel I could do it in 4 hours or less in my driveway.. $425 is a little high.. maybe $350.
  14. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    02-05-2012 09:14 PM #49
    Thanks for the info. That helps a lot.
    That quote was only for the pump. Not even the mounts.
  15. Member 8v-of-fury's Avatar
    Jul 14th, 2008
    Because MK1
    02-06-2012 12:07 AM #50
    well the pump needs to come off to do the passenger mount and it needs to be retimed when it goes back together.
    When i said i could do it in less than four hours. I meant the passenger mount by itself. not including the other three.
  16. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    02-06-2012 12:09 AM #51
    I'm not worried about it right now. but thanks for the offer. myself, a friend of mine who has built beetles and buses and antoher ford ceritfied friend can probably figure it out. I'll just have to suck it up and by the timing tools.
  17. Member Road Boss's Avatar
    Jul 15th, 2004
    Woodbridge, VA
    02-06-2012 12:09 AM #52
    Yessir.
    I'm in 43 area for the next month and a half. I never seen your caddy around the area. What is your daily?
  18. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    02-06-2012 12:14 AM #53
    it is my daily. I'm in 33 area Camp margarita. I don't drive around alot so that's probably why
  19. Member ducatipaso's Avatar
    Apr 13th, 2003
    norcal
    82 aaz pickup
    02-06-2012 12:29 AM #54
    thanks. you should definitely do the rear carpet underlayment like I did. It did make a difference. if you want smooth at idle and down the road do nothing other than OE motor mounts. I have HDs in mine and it's pretty buzzy at idle. If you don't have the under hood pad, get one.
    my next big job other than headliner is to rebuild the doors. it's amazing how much road noise is coming from there.
    click
  20. Member Road Boss's Avatar
    Jul 15th, 2004
    Woodbridge, VA
    02-06-2012 12:36 AM #55
    I would love to see it. This Thursday a few dubbers meet up at the Sonic in Vista.
  21. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    02-06-2012 12:51 AM #56
    Ill try to come out. I'd love to, but thursday is field night. haha it's a bummer.
  22. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    little d BIG D - texas
    02-06-2012 12:58 AM #57
    i dont remember replying but everytime i see this
    i just want to tell you that it is factory stock
    the lip of the fabric is supposed to go under the windshield seal and the other side under the inner door seal
    my 81 has this fabric also and the roof has bare cardboard all the fabric has been totally torn off
    i often find myself picking at the fabric and ripping it off
  23. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    02-06-2012 01:31 AM #58
    That's really ugly. Idk how vw decided that was OK. haha
  24. Member ducatipaso's Avatar
    Apr 13th, 2003
    norcal
    82 aaz pickup
    02-06-2012 11:37 AM #59
    late GTIs and rabbits had bonded in windshields which have a plastic trim that covers the a pillars.
    click
  25. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    02-06-2012 05:14 PM #60
    Well at least they made it better looking.
  26. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    02-07-2012 01:15 AM #61
    Quote Originally Posted by ducatipaso View Post
    I don't know how I missed this. Yea I have HD mounts. I guess I'll live and I do have that mat. Life would be a lot noisier without that. And what do you mean by rebuild the doors? Not much to the door afaik.
  27. Member ducatipaso's Avatar
    Apr 13th, 2003
    norcal
    82 aaz pickup
    02-07-2012 04:31 AM #62
    rebuilding a door, to me, is:
    * strip it down to just the frame and clean it inside and out
    * replace all glass seals
    * replace all scrub seals
    * replace primary door seal
    * reinstall window regulator, make sure everything is nice and tight
    * clean/rebuild door latches
    * add rust proofing/sound deadening as desired
    * fab up new moisture barriers
    etc etc. obviously, you'd replace any crappy fasteners as well, whatnot.
    you'll be amazed at how much nicer this kind of work will make your car. trust me. the best mods are those that nobody notices.
    moogie on ebay has full door kits
    http://www.ebay.com/itm/270658052192
    I will be doing this to my truck. I've already done about 1/2 it to each door already (cleanup, new moisture barriers, tighten it all up) and even this made a difference.
    click
  28. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    02-07-2012 11:24 PM #63
    woo thats pricey. I'm sure it will help though, Idk if I'd be able to go at it in one kit, but yea it seems like a good idea to do that thanks for the advice.
    Caddy pan is here, but battalion mail clerk went on leave.....and his replacement likes to leave early.
  29. Member PoLock33's Avatar
    Aug 14th, 2011
    B'Ham WA
    02-08-2012 03:38 AM #64
    x2
    Cant wait to get that kit for my jetta. pretty dam good deal compared to buying all the seals separate.
    No Bad Days.
  30. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    02-11-2012 02:42 PM #65
    yeah im so glad he has so many remakes of the door trims
    very helpful for people
    except of course he doesnt carry some of the chrome ones
  31. Member Matysik's Avatar
    Oct 5th, 2008
    Greenfield, Wisco
    '08 HD (FOR SALE), '04 Silvy 4x4 with a turbo (FOR SALE), '83 4 DR. (FOR SALE), '86 5.0
    02-11-2012 04:40 PM #66
    I would do the pump yourself. Save some money, get some satisfaction that you did it, and it's easy. As for bleeding the system check out my thread since I had a system full of air and just follow the steps and she'll be good to go
    http://forums.vwvortex.com/showthrea...iesel-problems
    Real name is Matysik not Matt or any other thing you guys conjure up
    Want a deal on AMSoil products? Longer fluid intervals? Message me for better than retail pricing
  32. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    02-11-2012 10:20 PM #67
    Yea I'm doing it myself. Ill figure it out with the help of some friends.
    caddy pan came in
    along with new turn signals for the front bumper, and control arms in the mail.
    also i got some speakers and a small 4 channel amp to make a little sound system I can hook right up into my Iphone. It consists of 2 6x9s with enclosures, a 4 channel amp and one 4x6 for the dash speaker. (which I have one for sale if anyone wants one )
    I need to have more time. I am just hoarding parts in my room as of now. I feel unaccomplished. haha
  33. Member Charcoal_Grey's Avatar
    Jul 22nd, 2008
    San Diego, CA
    02-12-2012 04:11 PM #68
    This is in the mail as well It might take a while to get here since it's from canada, but a good deal is a good deal. thatnks 1988gti
  34. Member Justin_Eshelman's Avatar
    Dec 3rd, 2010
    South Alabama
    82' VW Caddy, RIP-2003 20th Anniversary GTI #0024
    02-12-2012 10:28 PM #69
    I need a drool smily face
    “A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”
  35. Member stewardc's Avatar
    Feb 2nd, 2005
    Nova Scotia, Canada
    '81 Rabbit Pickup
    02-13-2012 07:31 AM #70
    Nice ! I have a wood wheel in mine and love it.
