VWVortex.com - Mk5 / Mk6 Jetta Sportwagen Rear Bumper Cover Removal
    Results 1 to 12 of 12
    Thread: Mk5 / Mk6 Jetta Sportwagen Rear Bumper Cover Removal
    1. Member andylyco's Avatar
      Apr 21st, 2003
      Hbg PA, Las Vegas, Brian Head UT
      '93 SLC, '98 Boxster, '06 911 C2S, '08 Boxster RS60, '04 Bajaja (ALL MT!)
      01-24-2012 01:22 AM #1
      Another DIY!
      The Mk5 Bentley manual doesn't give the correct procedure for bumper cover removal. You do not need to remove any of the trunk floor or side liners.
      1. Access the tail lights from inside the trunk. There is a cover that pops off on the passenger side, and there is a flap on the driver side. This is the passenger side:
      2. Disconnect the wiring harness.
      3. Remove the three 16mm nuts from each tail light as seen in the photo above.
      4. Without using tools, the lens (including bulbs) will slide out the rear of the opening, and there is a small ball-joint near the front corner that needs to be overcome:
      5. This is what you should be holding in your hands:
      6. On each side of the car in the wheel well behind the back tire remove the three T25 Torx screws. (the upper 2 are shown below):
      7. On the passenger side only, remove two more T25 Torx screws on the bottom of the bumper cover:
      8. Along the bottom of the bumper at the rear of the car, there are three T27 Torx bolts to remove:
      9. In each taillight opening remove two more T27 screws holding the top of the bumper cover:
      10. The bumper cover should easily slide off the rear of the car. There are bumper cover guides on each side of the car, so bring the bumper straight back until it "unclips" from the rear of the car. This is the end result: (note I had already reinstalled my tail lights and custom plate holder)
      Here you can see the clips on which the bumper cover slides:
      11. Beer!
      A week ago I was tapped VERY lightly in the rear, and since their insurance company was willing to give me $571 to repair the scuff, (but no rental car while repairs were made) I thought it easiest to just pull the cover and take to my favorite body shop. The actual bumper is still in place, and I don't feel that it is unsafe to drive without the cover.
      Las Vegas Real Estate: RealEstateAndy.com
      Brian Head, Utah Ski/Board Rental Condo: BrianHeadGetaway.com
    2. Member Code3VW's Avatar
      May 5th, 2004
      Gilbert, AZ
      '10 CW JSW TDI 6MT
      01-24-2012 01:31 AM #2
      Great DIY. Thanks for adding it to the DIY/FAQ thread!
      OEM+ Bi-Xenon HIDs | Front & Rear Fogs | Highline CECM | Euroswitch | RNS-510 HW:08 SW:1140 w/ Software VIM | Backup Camera | 9W7 | Dash Cubby | Aspherical Mirrors | GTI Steering Wheel w/ .:R Badge | GTI 6MT Shift Knob | GTI E-Brake Boot | GTI Pedals | GTI 18" Detroits
      Not so OEM+ Koni Coilovers | Gentex Homelink Mirror | Yaesu FTM-350AR
    3. Geriatric Member rootrider's Avatar
      Feb 18th, 2004
      Tacoma, WA
      '95 e36 m3, '04 e60 530i sport
      01-24-2012 02:23 AM #3
      nice... good to see it's as easy as the front bumper cover to remove. I'll be needing to remove mine soon for similar reasons..
      PNWfahren - Pacific Northwest Regional Car Enthusiast Forum Community
      2009 VW SportWagen TDI sold =-=-= 1995 M3 -=- 2004 530i
    4. Member dubidoobs's Avatar
      Jan 7th, 2003
      On Top of West Durty Jurzy
      MKII Alpine White GTi 2.1 16V (in the works) | "MKVI" PGM 2.0L CR TDi Wagon
      01-25-2012 09:08 AM #4
      Quote Originally Posted by rootrider View Post
      This might be a silly question, but what if you have the Votex rear valence? same removal process?
      PS - great write-up!
      a bad day in a Volkswagen, is better than a good day in a Honda...
      MKII Alpine White GTi 2.0/1 16V (in the works)
      MKVI PGM 2.0L 6MT TDi Wagon (daily driver)
      SLAM-N-EURO'Z
      Oct 1st, 2006
      Antwerpen
      01-25-2012 03:21 PM #5
      Great
    6. Junior Member
      Oct 4th, 2010
      Toronto
      2011 GSW Highline, DSG, Nav, Tint. 18" Interlagos
      01-25-2012 03:54 PM #6
      Great information...You never know when your going to need, but I'm glad that's here.
      Thank you.
    7. 02-04-2012 09:29 AM #7
      Nice write-up man!
    8. 02-04-2012 01:28 PM #8
      What are the black vents (last photo) on the side of the car for? Does anyone have an idea on how to tighten the closure of the tailgate also? I don't think mine is closing tight, I took out the little rubber bumpers off the tailgate and it seems quieter inside.
      Thanks,
      Steve
    9. Member Code3VW's Avatar
      May 5th, 2004
      Gilbert, AZ
      '10 CW JSW TDI 6MT
      02-04-2012 07:10 PM #9
      Those vents are for pressure relief...otherwise when someone slammed the door to your car, your head would implode.
    10. Member dubidoobs's Avatar
      Jan 7th, 2003
      02-13-2012 01:13 PM #10
      Quote Originally Posted by dubidoobs View Post
      Beuller...Beuller...
      SLAM-N-EURO'Z
    11. Semi-n00b
      Mar 19th, 2011
      SportWagon 2011 6AT Platinum
      03-19-2015 12:03 PM #11
      Great explainer , thanks for sharing. In the spring I need to repair cracks in the lower bumper cover on the rear of my car (2011 jsw) I haven't been able to have a really good look at the job yet, (its still -10c here and I don''t have an indoor work area) . Will I need to remove the whole cover assembly as per your guide or is it possible to take the lower assembly off leaving the upper in situ? TIA
    12. Member andylyco's Avatar
      Apr 21st, 2003
      03-19-2015 12:47 PM #12
      Quote Originally Posted by windybrit View Post
      I'm sorry, I don't know about the newer style bumper covers. The '09 was a 1-year car in the states, so perhaps someone with a '10-'15 wagon can chime in!
