Results 1 to 13 of 13
Thread: Steering Wheel for the Track
  1. Member 1FLiGLi's Avatar
    Jan 13th, 2003
    NoVA
    '90 GLi + others
    01-25-2012 12:27 PM #1
    I track a Mk II GLi with the factory steering wheel.
    I'd like to change to a proper steering wheel for the track. Are there any general rules when looking at a track steering wheel? I've seen they range in diameter. Is smaller better? Any other tips on buying a wheel?
    Cheers,
    FLi
  2. Member chois's Avatar
    May 12th, 2000
    Chicagoland
    01-27-2012 09:20 AM #2
    I used the stock one for years, because it made manual rack + welded differential easier to handle.
    Then I picked up a Longacre aluminum wheel aimed at short track stock cars for about $70 so that I could space it closer to the driver seat. I went that way because I could get one that was not tiny, and a little bit because no one uses them.
    Chris
    2007 GTI 16v, 4 door, 6sp (well really that one is Brandy's)
    2004.5 Passat Wagon 20v, 1.8t, 4mo, 5sp
    1986 GTI 8v road racer - DIYAutoTune.com
  3. Member 1FLiGLi's Avatar
    Jan 13th, 2003
    NoVA
    '90 GLi + others
    01-27-2012 10:21 AM #3
    Thanks for the input, chois. Appreciated.
    FLi
  4. Member 2 doors's Avatar
    Jun 18th, 2003
    Baltimore, MD
    '00 GTI 1.8t, '05 Mazda6 Wagon V65M
    02-02-2012 01:16 PM #4
    I got a Sparco that is smaller in dia, but as FAT as i could get. The smaller diameter makes it feel more responsive.
    If you and I happen to meet at SP for the PDX in March, you can check it out.
  5. Member 1FLiGLi's Avatar
    Jan 13th, 2003
    NoVA
    '90 GLi + others
    02-02-2012 02:28 PM #5
    Quote Originally Posted by 2 doors View Post
    Thanks, 2 doors. I plan to be at the PDX in March.
    I've narrowed my search to these Sparco wheels - Naxos and Veloce. They are both 330mm, which is ~ 50mm smaller than the stock wheel I currently have. Just got to get over to OG to see them in person. Its hard to get a feeling for the thickness via the interwebs.
    Cheers,
    FLi
  6. Member 2 doors's Avatar
    Jun 18th, 2003
    Baltimore, MD
    02-02-2012 03:21 PM #6
    I don't know what mine is called, but its the thick suede covered one. Of course OG is where I got mine. Trying them out definitely helps.
  7. Member 1FLiGLi's Avatar
    Jan 13th, 2003
    NoVA
    '90 GLi + others
    02-02-2012 03:36 PM #7
    Naxos - http://www.ogracing.com/sparco-naxos-steering-wheel-3
    Veloce - http://www.ogracing.com/sparco-veloce-steering-wheel
    2 doors - Your wheel look like either of those?
    FLi
  8. Member 2 doors's Avatar
    Jun 18th, 2003
    Baltimore, MD
    02-02-2012 04:06 PM #8
    No. Mine's the 383 Competition one.
  9. 02-02-2012 11:41 PM #9
    You're over-thinking this as only an engineer can do
    The only real decision factors are if you want hand-grips , thumb rest (aka thumb breakers) and diameter - aside from that, it's just a matter of asthetics unless you have a clearance issue (which I don't think you have given your relocated seat position). The only other consideration is the amount of "dish" you want - the OE wheel has a surprising amount of offset but this is usually compensated by using a flat wheel and a hub adapter (which you'll use regardless of the dish in the wheel). I had an older version of the Veloce in the Truckette (deep dish) and with the adapter, the offset was significant enough that I had to take my hands off the wheel to actuate the signals and wipers. That's not necessarily a bad thing though as I can say that I never accidentally turned either on while driving in a "spirited" manner - of course I never drive in that manner but that's another story.
    Of the Sparco line-up, I like the 383 Competition b/c it has expanded grips at the "incorrect" positions of 9 and 3. If you don't care for the hand grips, the 333 Competition is similar - both are 330mm diameter. I think I have a Lap2 (discontinued colour) in the MR2 and it makes a world of difference compared to the miserable Grant wheel it had when I purchased it.
  10. Member 1FLiGLi's Avatar
    Jan 13th, 2003
    NoVA
    '90 GLi + others
    02-03-2012 02:57 PM #10
    Quote Originally Posted by mgyip View Post
    Ah, I was fine with just two variables - diameter and thickness. I believe YOU were the one that over complicated things by adding variables, such as dish and offset
    Since I know everyone is awaiting conclusion to my decision, I went with the Naxos. We'll see how it feels when sitting in my garage making vrrrroooom, vrrrroooom sounds AND on the track.
    Cheers,
    FLi
    PS - Nice Old Man Car (OMC), Yip. I see you did upgrade and now have a radio. It's technology great!?
  11. 02-04-2012 09:21 AM #11
    Glad you made a decision on a wheel - it'll make a big difference over the OE version.
    I love my German Camry - at a 47 mpg average, I can't help but smile. The radio was a "must" - I was running out of show-tunes to sing on my commute
  12. Member 1FLiGLi's Avatar
    Jan 13th, 2003
    NoVA
    '90 GLi + others
    02-08-2012 04:36 PM #12
    I bet it won't get 47 mpg on the track .
    FLi
  13. Moderator Justin's Avatar
    Mar 7th, 2006
    Air-I-Zona
    2011 Silverado 2500,2012 Mitsubishi Evo X,2002 Ford F350, 2010 Equinox, 62 Mercury Monterey, 95 M3
    02-26-2012 08:57 PM #13
    Quote Originally Posted by 1FLiGLi View Post
    FLi
    if I could find a car that got 47 on the track that would be nice...
    except the gas isn't the expensive part...2 days this weekend in my Evo and I took a good 20k of wear off the tires...
