NEED TO SELL. $1,000 OBO. make an offer.
#1
1993 Audi 90 CS (B4)
12v – 2.8L - V6
FWD – Automatic trans.
150K miles and the engine is still going strong and has been well maintained.
Interior and exterior are in good shape, both around 7.5/10. I'm sure the car would really pop with a good detailing. Couple MINOR rust spots, 1/2" or less.
Needs a new brake Brake Master Cylinder and rear calipers.
Need to sell.
No mods – assuming all OEM spec parts
Green with beige leather interior
Over the 7+ years I've put ~ 5K in repairs in to it:
Fuel and trans filters
Oxygen sensors
Rear guide bushings, Front control arm bushings
Front Struts and Bearing mount plates
High pressure power steering hose
Dealer fuel system cleaning and fixed vacuum leaks: repaired crank breather hose, small vacuum line, and bushings between air intake and throttle body
Fuel Pump- also @ dealer
Front outer CV boots
Front Lower ball joints
Left outer tie rod
Right front axle shaft
Water Pump, Timing Belt, Thermostat and gasket
Idler and Tensioner Pulley
New Starter and Ignition switch
Door Switch (driver I believe)
Oil pressure control/relief valve
Front upper strut mounts
New battery
Only needs a few other minor things required to pass MD (very strict) state inspection like bulbs, drivers side door handle cable (interior), etc.
Located in Columbia, MD.
Contact Jason @ 313-550-5564
#3
Would you consider a full priced offer IF you take care of getting it to pass inspection?
How's the tranie doing? Any slipping? Anything broken, like AC or climate control?
#4
-No, I cannot afford to make any repairs.
-AC does not work. Needs brake work.
-That's why I'm taking all offers.
