VWVortex.com - Service interval for the Clean Blue additive on the Passat TDI.
    Results 1 to 19 of 19
    Thread: Service interval for the Clean Blue additive on the Passat TDI.
    1. Member TSeck's Avatar
      Nov 20th, 2007
      Florida
      2012 Passat SE TDI, 1972 Porsche 911S, Mercedes C250, 2007 Jetta, 2001 Ford Excursion 7.3
      01-26-2012 09:59 PM #1
      Anyone know for sure the cost and replacement interval for this service? Also, Is this something we can do at home or is this only available from the dealer $$$$
      I'm considering the Passat TDI for a host of reasons. I need to get a good handle on the actual costs for maintenance.
    2. Member dubfreeek's Avatar
      Nov 30th, 2003
      Orlando Fl.
      '07 Ram 2500, '08 Altima, '12 Passat TDI SEL, '97 C280
      01-26-2012 10:13 PM #2
      Been told the interval is around 5500 miles but unsure of the cost. I do know the additive is available at larger truck stops and even some auto parts stores.
    3. Member Turbonium20V's Avatar
      Jun 30th, 2002
      Virginia
      2015 GTI SE 4Dr DSG
      01-26-2012 10:14 PM #3
      Every 10k and you can buy generic urea for cheap in places like auto zone.
    4. 01-26-2012 10:20 PM #4
      Its part of your scheduled maintenance every 10k and is covered under the free maintenance program for 3yr/36k miles.
    5. Member TSeck's Avatar
      Nov 20th, 2007
      Florida
      01-26-2012 10:55 PM #5
      All true, but I put about 20k miles a year on the car (TDI justification) so that nets me about 1.5 years of "free maint". After that, its my cost. I have a 7.3 diesel Excursion so I'm no stranger to these engines. These new "clean diesel" engines require more frequent service and costs. If I buy one it will be for the long haul (300k-500k).
    6. Member
      Nov 23rd, 2006
      2003 Audi TT Quattro Roadster, 2012 VW Passat TDI SEL
      01-26-2012 11:55 PM #6
      I had read in a review article several months back that the fluid in the 5.5 gal tank should last for around 50k miles, however VW suggests to top it off every 10k miles. That just happens to coincide with the maintenance interval. There is a warning light when it gets low, so the only reason to fill it every 10k miles is during the free maintenance period. Outside of that Auto Parts stores carry it. O'Reilly's Auto sells a 2.5 gal jug for $13. Way more expensive at the dealership.
    7. Member Turbonium20V's Avatar
      Jun 30th, 2002
      Virginia
      2015 GTI SE 4Dr DSG
      01-26-2012 11:55 PM #7
      Quote Originally Posted by TSeck View Post
      I'll say your looking at the right car then.
    8. Junior Member
      Oct 11th, 2011
      Virginia
      2015 Passat TSI SEL, 2012 Passat TDI SE, 2005 Audi A6
      01-27-2012 10:24 AM #8
      Grainger sells 2.5 gallons for $14.78.
      http://www.grainger.com/Grainger/AIR...GJ8?Pid=search
      Advanced Auto Parts has 2.5 gallons for $12.99
      http://shop.advanceautoparts.com/web...content=value4
    9. 01-27-2012 11:41 PM #9
      My local Walmart has 2.5 gallons for $10.00
    10. Member
      May 29th, 2004
      Eastern Canada
      13 Passat tdi
      09-10-2013 03:05 PM #10
      Was told that Freightliner was the cheapest for Canadians,,
    11. 09-10-2013 05:36 PM #11
      My new TDI is almost 6 months old and about to hit 10k miles, the warning light hasn't come on for more DEF. The stuff is cheap, it's the least of your worries...
      Aug 21st, 2005
      SE Michigan
      2014 Passat TDI SE w/3M clear bra, Dieselgeek Panzer plate and Etsy-bought fuzzy armrest cover
      09-10-2013 06:14 PM #12
      Quote Originally Posted by TToplessTTs View Post
      I believe the other reason for the top off is to keep the tank "fresh" so-to-speak. Reading a thread at TDIClub, it was mentioned in a few places the AdBlue (or the other commercial names) all have about a 2 year shelf life. For the regular driver of 12-20k miles / year, the smaller bottles every 10k miles or so should suffice. Most did not recommend buying bulk the 5 gal container because it wouldnt get used in time before it's expiration. That and the smaller bottles (especially the VW OE service bottles) have a spill free feature.
      But agreed, the cost and frequency of needing to add this stuff every so often would not discourage me in the least.
    13. Member
      Jun 2nd, 2012
      Hawaii
      2012 Passat TDI SEL, 2007 Touareg VR6
      09-10-2013 07:26 PM #13
      Just did the 20K service and put in 1.75 gallons of adblu. Same as at the 10k. At $11/2.5 gallon jug at Napa, that's 63 cents per 1000 miles. At the rate I use it, I'm good for over 20K miles per tankful. Your mileage will vary, as it seems that higher mpg rates use more urea.
      2012 SEL TDI DSG - Platinum Gray with Moonrock
      2007 Touareg V6 - Offroad Gray w/ Anthracite
    14. Member
      Oct 10th, 2012
      Lake Arrowhead, CA
      2012 Passat SE TDI
      09-10-2013 10:01 PM #14
      The car typically uses between 2 and 2.5 gallons every 10,000 miles.
      The tank holds 5.5 gallons.
      So the farthest between doing something - getting the dealer to fill it or you filling it yourself - is about every 20K.
      I had the dealer do it once so I could see what they do, and they have a special siphon tube that prevents spills from occurring.
      The little bottles are about 8 bucks each and they have a no-spill feature as well.
      Be careful not to spill it in the trunk it makes quite the mess.
    15. Member
      Jun 2nd, 2012
      Hawaii
      09-11-2013 04:46 AM #15
      Quote Originally Posted by kendavis View Post
      You can unscrew the top of the OEM bottles and refill them from the 2.5 gallon jug. Saves having to buy special bottles all the time or worse, cutting the bottom off to make a 'funnel'. Plus it helps to gauge what you put into the tank, 1/2 gallon at a time.
    16. Junior Member
      Mar 31st, 2008
      Quebec, Canada
      2015 Passat TDI Sportline : 1966 VW Beetle
      05-22-2015 08:33 PM #16
      My warning light come on at 9200 km (5680 mi). When I've put urea in the tank, I took me almost 2 gal to fill up.
      My question is : did the car came filled up with urea? If yes, my urea comsumption is quite high, isn't?
    17. Member
      Feb 8th, 2001
      2013 Passat TDI SEL Premium
      02-15-2017 08:03 AM #17
      To update what has pretty much become a "zombie thread," DEF can now be had (in our area, at least) as cheap as $7.99 for the 2.5 gal. jug at Rural King, and there are several "clean" ways of filling the DEF tank out there. Probably the cheapest expedient (although time-consuming) is to buy one of the 1.5 liter bottles from the VW dealer, which has a more or less spillproof attachment to the filler neck, and just keep refilling it from a jug of cheap generic DEF. I use the M-B jug / hose (the hose is vented and locks to the filler neck), which I got on sale and is a really slick way to put in 2.5 gal in one shot with no mess.
      The interval for this (in our NMS '13 Passat) works out roughly to one 2.5 gal jug -actually a bit less- at the 10K service interval. So I just change the engine O&F, and whatever else needs doing, and fill the DEF tank. Pretty easy.
    18. Member
      Feb 8th, 2001
      02-15-2017 08:04 AM #18
      Quote Originally Posted by Miliceman View Post
      From the figures you gave, either your consumption of DEF is WAY high, or the tank wasn't filled up when you got it. Don't know what your car's DEF tank holds, our Passat holds about 5 gal.
    19. Member
      May 28th, 2009
      Ft. Worth, TX
      2009 JSW TDI; 2014 Passat TDI SEL;2014 Toyota Avalon Hybrid; 2013 Ford Cmax Hybrid; 2015 Nissan Leaf
      02-15-2017 11:39 AM #19
      Yo...Rico1...pay attention. You're responding to a post that's almost 2 years old!!!
      2009 JSW TDI (returned 12/15/16)
      2014 Passat TDI-SEL (returned 12/14/16)
      2013 Ford Cmax Hybrid (replacing 2009 JSW)
      2014 Toyota Avalon Hybrid (replacing 2014 Passat)
      2015 Nissan Leaf (for in-town use)
