Page 1 of 13 1 2 3 4 5 11 ... LastLast
Results 1 to 35 of 435
Thread: BT Audi TT
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    01-27-2012 09:17 AM #1
    Well, Its been almost a year in the making, but everything is coming together and hopefully be done very soon. I started with a 2001 Audi TT 180hp front wheel drive car. The block and head were rebuilt professionally by local hot rod shop. The transmission was also rebuilt professionally with an LSD and TDI 5th gear. I am doing the rest of the work and labor to put it all back together. The engine and tranny were finished last august and are now in the car. Next week I will be ordering my SEM intake manifold and new fuel lines and the setup will be complete! The 1.8t was the ATC narrowband. I already have a wideband ecu (AWW) and wiring harness (AWP). The wb ecu has already been flashed by Gonzo with a 870cc MAF'd file and all deletes.
    Block:
    82mm Wiseco pistons 8.5:1 c/r and Eagle rods- Engine builder took care of
    Race coated rod and main bearings (oversized) - Engine builder
    Polished and balanced crank
    IE Dowel Kit
    All ARP hardware- IE
    New IE oil and water pump (metal fins)
    IE manual timing belt kit- IE
    Victor Reinz gasket kit- IE
    Head was rebuilt to OE specs (sticking to small port and going with stainless valves)
    ECS Lw power steering pulley
    External Oil cooler
    Green top CTS- ECS
    034 Race mounts- 034motorsports
    NGK plugs- ECS
    Accessory belt for A/C delete- PAG
    Supertech Stainless exhaust valves
    Transmission:
    Complete rebuild 02J 5-speed
    Wavetrac LSD (ARP bolt kit)- IE
    TDI 5th gear- used
    IE Shift fork
    Clutchmasters FX400 6-puck and lightweight flywheel (ARP bolts)- PAG
    Redline MT90 fluid- ECStuning
    Turbo System:
    Pagparts Bottom mount manifold and downpipe-PAG
    Precision 5857SP Ball bearing- BMP20TH
    -3AN oil line with restrictor from PAG
    ECS Exhaust nuts and Nordlock washers- ECS
    HKS SSQV BOV- Previous build
    Tial 38mm WG- used
    Frozenboost AWIC kit (2.5" turbo to core, 3" from core to TB)-Frozenboost
    42dd MAP flange
    SEM Intake Manifold- CTS turbo
    034 Fuel Rail and FPR adapter- 034motorsports
    Walbro External Inline- previous build
    Racetronix 79lb injectors
    RS4 throttle body
    Apexi AVCR EBC (boost by gear FTW)- previous build
    Gonzo TUNING
    Autometer wideband, EGT, Boost, and Oil Press. gauges- used
    Suspension:
    ST coilovers- HPAmotorsports
    USRT solid subframe bushings-USRT
    New brembo rotors and Hawk pads- MJMautohaus
    Tyrolsport brake stiffening kit-USRT
    Lightweight tubular LCA's-USRT
    Stainless Steel Brake lines- ECS
    All new poly swaybar bushings and steering rack
    As of now, the motor is in the car. The suspension and brakes are finished (just have to tighten tie rods). The PAG bottom mount made it near impossible to fit a 4" to 3" 90degree reducer between the frame rails. There was a one inch lip the dug into the reducer. I pulled the motor again and took the cutter to the lip. After the lip was removed, I took the grinder to it to smooth out the edge where the fitting would sit. I initially wanted to keep the A/C, but since I am running the AWIC on the drivers side of the bay, the intake runs right where my A/C lines are at.. I removed the A/C stuff for now. I will make some new A/C lines, but after its running lol I have a couple questions/concerns I wanted to express as well.
    -need a compressor housing o-ring for the turbo.. anyone know who carries these? -getting from PAG
    -I am mounting the AWIC heat exchange in the A/C condensers spot. I have heard some concern for the TT's running hot, anyone have any opinions/suggestions? I was also considering a new (3 row) radiator to help with cooling. Is there anyone with any experience running an upgraded radiator on these cars?
    -Initial start up- Priming the oil.. IIRC, I will need to unplug injectors; turn over with key for 30 seconds; plug in and fire up? Looking for a little more detail to make sure everything is sufficiently primed and ready to go.
    - unplugging injectors to cut fuel and then cranking over to prime.
    E
  2. Forum Sponsor AL@PagParts.com's Avatar
    Oct 23rd, 2008
    NY
    07 AUDI 2.0T 07 VW GTI
    01-27-2012 09:50 AM #2
    Good to finally see progress on your build. I always wonder about TT builds as they are bit different. I normally use a 4" to 3.5" cobra for the T3 and even vbanded bottom mounts (the latter pulling the turbo farther away from the frame rail which makes fitting any silicone inlet a non-issue). I should've suggested it but didnt know exactly what you were doing. Good luck w/ it all
    Pag Parts
    Turbocharger Systems, OEM Parts / Fabrication
    Garrett / PTE / BW / TiAL / Clutchmasters / Southbend / Brute Con Rods / Wiseco / CP Pistons / Supertech / Ferrea / CatCams / Walbro / EV14 Injectors / Eurodyne Software / Much More... Pag Parts Facebook
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    01-27-2012 10:03 AM #3
    Quote Originally Posted by AL@PagParts.com View Post
    Thank you! I used the frozenboost reducer (probably coud have found a more compact one) since it was what I had and grinding the lip off took a whole 10 minutes I am really looking forward to getting this completed and have a working car again
  4. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    01-27-2012 10:07 AM #4
    Also, do you guys carry the compressor housing o-ring for the 5857? I got a hold of precision and they said to use a vendor, but will sell one to me if I cant get one soon enough..
  5. Forum Sponsor AL@PagParts.com's Avatar
    Oct 23rd, 2008
    NY
    01-27-2012 11:06 AM #5
    Sure, I have a garrett one. Should be the same
    Pag Parts
  6. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    01-27-2012 12:05 PM #6
    dope, build Also LOL @ Grass City
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    01-27-2012 06:05 PM #7
    I'll be in touch with you soon.
    -Tom- don't hate on the city
  8. 01-27-2012 07:05 PM #8
    can we get the pictures linked directly? i dont have a grasscity account
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    01-27-2012 08:22 PM #9
    finally got it pics working..
  10. Member Chris164935's Avatar
    Jan 9th, 2004
    Orange Park, FL
    2001 Audi A4. 2001 Audi A4.
    01-28-2012 12:44 AM #10
    Unplug the injectors to prime the engine/turbo with oil. This will keep the injectors from spraying fuel into the cylinders and possibly washing down the cylinder walls while cranking to prime the engine with oil.
    "You know you have a bad idea when Ford guys are making fun of you."
    FS: Autronic SM2, 500r CDI, Misc. Related Parts.
  11. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    01-28-2012 05:36 AM #11
    Quote Originally Posted by Chris164935 View Post
    Thank you! I should have realized injectors instead of spark plugs.. Thanks though!
    - ordered SEM this morning from CTS
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    01-28-2012 08:26 AM #12
    Well, I got paid today, but the USRT tubular control group buy ended a day or two ago.. I pm'd Scott so hopefully they will let me slip in on the group buy.. Fingers crossed!
  13. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    01-29-2012 08:54 AM #13
    Apexi avcr install-- few questions..
    1) I have the Bentley manual and looked up the vss signal, rpm signal, and tps.
    - now, I know the vss can be pulled from the back of the cluster as well, but my main concern is the tps and rpm signal has me worried.. I started on this yesterday after working on the car all afternoon. The first issue, I spliced into the rpm sensor instead of signal then was going for a green/brown wire. Well, when you pull the tape off red looks an awful lot like brown when it's used as the trace on the covering.. Stopped here, wasn't going to eff anything else up til I slept on it.
    2) in the wiring diagram index, I used the 2000-2001 standard equipment diagram. My method was to find the signals on the index and use the colored wire that is linked to J220(ECM) in the index. I'm not new to electricity, but these wiring diagrams aren't the best in my opinion. Any help with this would be greatly appreciated! I'll post up pictures of my diagrams and the highlighted wires I think are correct.
    -get off work at 12 and will post them up then.
    - I really didn't want to take a chance and use a random guide on here with wire colors.. I'm pretty meticulous and second guessed myself, so I have come to the tex for support
  14. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    1989 Helios GLI 1997 Mk3 ****box
    01-29-2012 10:44 AM #14
    In to see how the gonzo bt file runs
  15. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    01-29-2012 10:59 AM #15
    Quote Originally Posted by Dave926 View Post
    That makes two of us! I have The VagCom to run logs and try to remote tune. My goal is to get it running and get through the break-in period. Once that happens, I will get it on the dyno and let the real tuning begin
  16. Member mk4boost's Avatar
    Jul 31st, 2010
    Long Island, NY
    BT Prius
    01-29-2012 09:18 PM #16
    those awic's are so gangster...
    good luck with the remainder
    F23 Frankenturbo ll Bosch 550cc ll Eurodyne Maestro ll 034 Motorsports High Flow Exhaust Manifold ll Eurojet street FMIC ll Cooling Mist Dual Nozzle W/M ll 287whp, 290ft/lbs (18psi) ll stock bottom end ll
    http://www.frankenturbo.com/
    http://www.usrallyteam.com
  17. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    01-30-2012 07:25 PM #17
    Well, I owe a huge thanks to Clay @ CTS for getting me an SEM manifold! It will be on its away along with a transition spacer and new injector inserts!
  18. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    01-30-2012 07:45 PM #18
    Battery talk-
    Looking for a lightweight battery that will be relocated inside the cab behind the drivers seat. I am currently looking at Braille's line, but wanted to get some advice on CCA. I live in Oklahoma so its 110 degrees in the summer and <0 degrees during the winter. How many CCAs will reliable crank it over every morning?
  19. Former Advertiser
    Jul 20th, 2011
    99.5 Jetta TDI, 02 GTI VR6, 00 Golf 1.8T, 01 Jetta Wolfsburg 1.8T, 00 Jetta TDI
    01-31-2012 11:32 PM #19
    I was wondering why I haven't heard from you in a while. Can't wait till you have this setup running so we can get the tune dialed in
  20. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    02-01-2012 08:29 AM #20
    Quote Originally Posted by Gonzo@GonzoTuning View Post
    Sorry man, been trying to get everything together with work and school as well :/
    I shipped off my throttle body to FFE yesterday. Clay had a manifold but it was the 75mm flange, so Ed is gonna port it out and get it to work with his Hemi throttle body!! Thanks again guys!
    The new fuel lines, brake stiffening kit, subframe bushings, and Defcons will be here thursday.. THe care will be done then except for the intake manifold and routing the piping!
  21. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    02-01-2012 08:36 AM #21
    --Just a side story for those wanting the ST coilovers..
    - I ordered the setup from HPA motorsports (great price too!). Unfortunately, the product code on the FWD was for AWD. The picture in this thread is actually the wrong rear struts. Now, I didnt put these on for a month or two after ordering, so I didnt find out til weeks later.. I called HPA and got a hold of Darrell. He worked with the supplier to get me new rear struts and had prepaid shipping so I could send them the wrong struts back to them! Everything was handled quickly and professionally.. I highly recommend HPA for the great customer service and communication
  22. 02-01-2012 11:14 AM #22
    Quote Originally Posted by seth_3515 View Post
    Hahahahahahaha, that won't always be the case. They still owe me a couple $k, still have my spec clutch, ignored their own warrenty, and dragged me along for over half a year that they had a custom clutch for me.
  23. Forum Sponsor Justin@USRT's Avatar
    Aug 1st, 2011
    Philadelphia
    04.5 PG GLI
    02-01-2012 02:40 PM #23
    I know Scott said No, but check your pm. I think I have a solution
    Justin Im, Technical Sales
    US Rally Team
    www.facebook.com/usrallyteam
    AIM-jijust88
    Unitronic Chipped Authorized Dealer
  24. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    02-01-2012 04:00 PM #24
    Quote Originally Posted by Justin@USRT View Post
    In Scott's defense he was trying to be fair to everyone, I cant blame him for that.. But I think the proposed solution is quite wonderful!
  25. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    02-01-2012 04:01 PM #25
    Quote Originally Posted by BlueSleeper View Post
    I cant speak for your situation, but Darrell was awesome to work with!
  26. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    02-02-2012 03:28 PM #26
    fuel lines will be here tonight! im really excited about this!
    -6AN Twist-tite Blue lines
    -6AN Twist-tite fittings
    -5/16 barb to -6AN fittings- Replacing stock fuel filter with direct replacement from ECS and then stepping up to the -6AN line..
    -this is only a temporary solution. After some breathing time, I will upgrade the intank fuel pump and run a surge tank with bosch 044 pump.
  27. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    02-02-2012 09:39 PM #27
    Need to order a few more fittings, but its almost there..
    -AWIC heat exchanger in the A/C condensers place.
  28. 02-02-2012 10:52 PM #28
    I like this
    Unitronic830cc/Racetronix 846cc flowmatched injectors/HP6262SP-b/ TurboSmart Race Port/PrecisionPW39/TurboSmart MBC/Snow W/M Injection/IE Rods/AEB pistons/ARP Main cap studs/ARP headstuds/3" turboback/ FMIC/Custom fuel surge tank/ Wally 255/AEB head/supertech single keeper valves/ IECVA1 cams/IE valve springs and retainers/034 motor mounts. SPEC Stg 4 6 puck clutch, Vr6 lightweight flywheel. KRM intake manifold/80mm tb
  29. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    02-02-2012 10:54 PM #29
    Quote Originally Posted by Mindfault View Post
    I like this
    Thanks man! I appreciate it! hopefully I will have the manifold in a week or two and finally make some real progress
  30. Former Advertiser
    Jul 20th, 2011
    02-02-2012 11:04 PM #30
    Is there someway I can convince you to run 830cc's instead of 870cc's? Lol I hate Siemens injectors.
  31. 02-02-2012 11:10 PM #31
  32. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    02-02-2012 11:17 PM #32
    yes if we need to, amy recommendations on brand?
  33. 02-02-2012 11:39 PM #33
    Racetronix tri cone spray. They are a flowmatched set but whatever gonzo recommends!
  34. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    02-03-2012 12:21 AM #34
    this
  35. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    02-03-2012 05:27 AM #35
    I'll definitely keep them in mind, but I'll go with the brand that gonzo has had the best experience tuning with (not sure which that is yet, he will chime in here today I'm sure)
