Page 4 of 13 FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
Results 106 to 140 of 435
Thread: BT Audi TT
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-09-2012 04:43 PM #106
    Head is off and at the machine shop getting the valves replaced! Got ahold of FFE and ill have my manifold next week and just waiting on my control arms. Things are starting to come together!
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-11-2012 03:17 PM #107
    Ordered the Dynomax Racing Bullet series muffler, yeah itll be loud.. I also got a 3 position relay module to power the awic water pump, inline fuel pump and EBC (gauges also). Hopefully the parts will start coming in this week (manifold and control arms) and then I can get this thing running.
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-12-2012 08:28 PM #108
    I am officially at a complete standstill until I get my manifold, control arms, head, and relay module..
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-13-2012 08:35 PM #109
    Control arms were shipped today, the manifold should be shipped today, relay module and exhaust parts will be here tomorrow Issam helped me out so much today with the throttle body and manifold issues I ran into!
  5. Former Advertiser
    Jul 20th, 2011
    99.5 Jetta TDI, 02 GTI VR6, 00 Golf 1.8T, 01 Jetta Wolfsburg 1.8T, 00 Jetta TDI
    03-13-2012 11:18 PM #110
    I should have a test file for those injectors tomorrow since you sent me the injector specs!
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-14-2012 04:56 AM #111
    Quote Originally Posted by Gonzo@GonzoTuning View Post
    Wonderful! Anything you need to help out just let me know!
    -relay module and exhaust will be in today so I wil get a bunch of wiring done. Won't be able to tap to ignition wire just yet though.. Engine shop has the Bentley to replace head for torque specs and I would rather double check and get it right the first time. I can definitely get a lot of petty chit done though.
  7. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    IY 20th in America, Evolution IV in 沖縄, 日本
    03-14-2012 09:37 AM #112
    In for your dyno sheets too!! lolz
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-14-2012 10:05 AM #113
    ill post em as soon as I got em!
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-14-2012 01:08 PM #114
    The TDI (95.5mm) crank came in today!! I have the oversized main bearings as well.. I looked it up on Eagle website to be sure and they use the 20mm wrist pins (0.79in)!!! This means I just need some oversized rod bearings and stroker pistons to build a 2.1L bottom end Itll be awhile before I can afford the pistons, but I will be putting back and possibly start the bottom end build in the winter
  10. Former Advertiser
    Jul 20th, 2011
    03-14-2012 01:16 PM #115
    Are you available for a flash session tonight?
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-14-2012 01:28 PM #116
    yes, what time? all I need is the ecu to be hooked up to the fuse panel correct? nothing is connected to the engine.. I do have the wiring harness in and can plug the ecu in.
  12. Former Advertiser
    Jul 20th, 2011
    03-14-2012 01:39 PM #117
    Yeah. As long as you can turn ignition on, it will work.
  13. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-14-2012 01:44 PM #118
    Ok.. Ill get it wired up so I can turn the ignition on today
  14. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-14-2012 05:36 PM #119
    few small problems.. distribution block isnt in my electrical parts bin I found someone selling a used one on here and hope to hear from them soon.. I got called in to work 1430-2300 the next two days as well , also have not gotten a tracking number from FFE called at noon and they were shipping it today.. Called twice since and havent gotten an answer. Everything else is on its way with a tracking number. Props to Issam at INA as well. He completely bent over backwards to help me out and I am very appreciative.
    - got a fuse block from a member soooo much better than $100+ bucks for a new one
  15. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-15-2012 02:44 PM #120
    The head will be ready tomorrow. I called FFE again today and he said he thought it shipped yesterday.. guess we will see. They said they would call back but havent.. Anywho, I got the 3 position relay module installed. Got the dual gauge pod (steering wheel) installed along with the boost and wideband gauge wired up. Just waiting on the Supra A-pillar to install the pygrometer and Oil pressure gauges. Also, installed the heat exchanger fan to the awic heat exchanger. Hopefully they shipped the manifold and it will be here this weekend.. Everything else is on the way and Im making as much progress as I can before work..
  16. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-16-2012 08:42 PM #121
    Head is back on, motor is in the car, new muffler was put on and fit like a dream.. Gonna make my 90 corner tomorrow for the side exit system. Hopefully my manifold and fuse block show up tomorrow or ill have to wait til monday to start her up.
    lost 2 bolts and broke my ground capacitor.. Ill be headed to the local parts store to replace the bolts and head to Radioshack to grab a new capacitor. Not a big deal but minor inconvenience is all
  17. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    audi tt gt3076r 01 aston martin db7 04 land rover disco 99rolls royce seraph
    03-16-2012 09:17 PM #122
    need some more pics I love pics
    http://forums.vwvortex.com/showthrea...t-done-I-guess
    ^^^Big Turbo build lots of pics^^^
    Best shop for repair and custom workin ma
    http://www.wentworthmotorsports.com/
  18. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-16-2012 09:55 PM #123
    Rear tire mounted to check fitment.. 225's on 16" rims with 25mm spacers
    3position relay module, will power fuel pump, awic water pump, gauges and ebc.. Battery will be mounted right next to it and I am going to build a custom cover.
    - engine looks the same since im waiting on the manifold to get here
  19. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-18-2012 09:00 PM #124
    Power steering relocated.
    Radiator support put on.
    topside..
    bottom side..
    start of the side exit.
    where its headed.
  20. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-19-2012 07:58 AM #125
    Control arms will be here today. The fuse block should be here today or tomorrow and still waiting on the damn manifold and 4.7 microfarad 110v capacitor but Im going to an electrical motor shop today to see if they have one. Just got to get an oil restrictor then I'm good to go!
  21. Forum Sponsor Justin@USRT's Avatar
    Aug 1st, 2011
    Philadelphia
    04.5 PG GLI
    03-19-2012 11:13 AM #126
    Quote Originally Posted by seth_3515 View Post
    Justin Im, Technical Sales
    US Rally Team
    www.facebook.com/usrallyteam
    AIM-jijust88
    Unitronic Chipped Authorized Dealer
  22. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-19-2012 11:24 AM #127
    UPS always delivers late evenings to my house.. So I stopped te shipment at the facility so I can pick them up as soon as I get off in 2 hours hopefully everything else will be here today. Already talked to Issam about an oil restrictor and have to get the thread pitch and it will be on the way! things are coming together..
  23. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-19-2012 09:12 PM #128
    Thanks to Issam and his wonderful skills getting me a custom adapter and new throttle body
    USRT tubular control arms. The spacers are in the packing lmao --old ball joints got stuck so I have to remove the axles from the spindles tomorrow to get a good swing at em..
    modified supra A-pillar and modified MKIV double gauge steering wheel pod
  24. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-22-2012 04:33 PM #129
    Drilling holes in the intercooler brackets I made.. Drill bit got stuck, ripped the L bracket out of the clamp and right on my arm.. No worries though, the bone stopped it
  25. Forum Sponsor Justin@USRT's Avatar
    Aug 1st, 2011
    Philadelphia
    04.5 PG GLI
    03-22-2012 04:57 PM #130
    That looks like it hurt just a little.
    Glad to see it all coming together though
    US Rally Team
    AIM-jijust88
  26. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-22-2012 05:10 PM #131
    Quote Originally Posted by Justin@USRT View Post
    just a bit, but got most of the wiring hooked up today. Cant torque anything down though, fractured the wrist but my dad and brother will be here tomorrow and will torque everything down for me
  27. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-22-2012 05:14 PM #132
  28. 03-22-2012 06:22 PM #133
    Been thinking about those control arms for my car. I'd be really interested in ride quality feedback and response once you're up and about. Build looks great man, car should rip.
    MK4 Junker : PAG 50trim Kit : AEB : RMR : Eurodyne
    P.P.T. - Pag Parts Turbo
    B6 A4 : Slow
  29. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    03-22-2012 06:23 PM #134
    Ouch that looks painful....extremely painful
    INA Engineering Inc.
    Email | Facebook
    INA Billet | 034 EFI | Mahle Powerpak | DM Forged | Ferrea | Supertech | ARP | South Bend | HTA Turbochargers | Mocal Oil control | DBW Throttle Body Upgrades
  30. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-22-2012 06:47 PM #135
    happened so fast I didnt notice the cut but the pain was from the force of the bracket hitting me. I honestly looked down and thought I would have a big bruise but I was wrong.. After stitches and such, I was trying to keep going at it. Was cutting hose for the AWIC when my hand had a sharp pain and spasmed. That made the box blade go right in the other hand.. Asking about stitches on that one tomorrow after xrays.. My whole hand is swollen and when I called they said I should get it xrayed, so ill just get the stitches then. I was done after that
  31. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-22-2012 06:49 PM #136
    Quote Originally Posted by screwball View Post
    Ill definitely have a full review
  32. 03-22-2012 08:19 PM #137
    Nice progress! I like your turbo to manifold plumbing, it came out really good .
    Quick question, what pump are using on your air-to-water system?
  33. Member
    Dec 25th, 2008
    Enid, OK
    2001 Audi TT
    03-22-2012 09:21 PM #138
    Quote Originally Posted by Marcus_Aurelius View Post
    Bosch cobra pump from frozen boost. I just made some quick brackets and will draw up a design to send off to the machine shop an have them powder coated. I placed the pump under the frame rail in front of the drivers side front tire. Just used previous holes and bolts for the pump bracket. The pump is set slightly below the bottom heat xchanger outlet. The filler neck is place inbetween the throttle body IC piping and the bumper.
    This was not done professionally. I used a propane torch and the square leg of the engine hoist to get a good bend to attach the brackets.. They arent pretty but will work perfectly to get solid measurements for some sexier ones
  34. 03-22-2012 10:42 PM #139
    Cool, thanks for sharing! I am working on mine as we speak and would love to see pictures to give me some ideas
  35. Member rains's Avatar
    May 30th, 2008
    Sherwood Park
    2000 GTI [1.8t], 1993 Jetta [ABA-T]
    03-23-2012 12:24 AM #140
    impressive build so far
    This thread is now about car cakes.
