Results 1 to 35 of 35
Thread: not a project per say, just some random pics and parts
  1. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    little d BIG D - texas
    81 VW Rabbit 1.7L EN 4-speed 020 GP, 78 VW Rabbit 1.5L EH 4speed 020 GC->GP
    01-27-2012 10:21 AM #1
    hey hey i bought a 78 W germany rabbit
    i have been working on it since the day I got it
    i need it to run me around to school and for a month to work while i repair the 81's transmission this spring
    trying to get this thing going with half of it scattered on the floor (neatly) and the other half in the rear compartment organized and boxed up including ziplocked by category!
    here are some photos of things i have done
    removed, changed, replaced, whatever
    hope someone finds this useful other than enjoying the photos
    thanks
    *oh, i have some other photos on camera
    will upload them later*
    and before/after
    whats next?
    well i have some connectors for the WUR and CSV but not the TTS, it has 3 wires
    replacing those with upgraded 90-2003 connectors
    and putting the wiper stalk assemblies back in
    thats all
    will have photos of more things later (in this post, not second post)
    ugghh....
    ah...oohh....ugggghhh.....
    this AC core is going to scrap. JUNK ---edit--- just the AC not the whole box....duh, i need heater
    a (bad) 7/1977 load reduction X relay. forgot to test it, will test it later..
    I DID NOT break these, they were broken when I bought the car!!
    adding some hub clip retaining bolts, perfect fit, stainless steel
  2. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    02-24-2012 11:41 PM #2
    ok so working on the gauges
    these are going in the radio slot using the "lock" housing from the radio
    built the front using smoked plexi glass
    fugged the last hole, it was off 2-3mm from center
    best i could do with a hole saw
    last pic you can see i am wiring it
    each gauge is in parallel so they each receive the same voltage
    the blue wire is ground for the lights which get wired next
    after i figure if the wire im going to splice in is + or -
    i dont have an oil pressure sender yet, but it gets wired and connected
    a dead wire will be located into the engine bay until then
    nearly certain the CELS gauge is correct for the wiring
    it kicks on when powered but havent tested its temp reading yet
    the BAR gauge is definately wired correct to the G connection
    so unsure if it is _|_ or G for the CELS gauge that goes to the sender I put on the coolant outlet
    will be able to test that next week and either way its not a major re-wiring to switch
    distributor work
    the distrubutor in the picture came with the car in the trunk
    i am positive it was the factory 78 because it does not have holes for frequency valve
    the one running on the car has the frequency valve plugged and banjo bolt swapped over
    cleaned the distributor, replaced the o-rings on the system pressure valve
    cleaned 3 of the 4 injector filters, one would not come out at all so just sprayed it heavily..
    removed the WUR and cleaned the filters and rust
    inside looked good, o-ring was good, that was clean
    pulled the CSV and cleaned that, replaced the gasket and both bolts
    all new crush washers
    also new rubber fuel box gasket
    runs smoother with the plunger and float all cleaned and sparkling
    here is my fuel pump relay switch
    when "off" the switch is not contacting the battery pin
    switched on it goes from pin 30 battery -> fuse -> switch to pin 87
    fuse had to be located outside of the housing for replacement purposes
    pins 85/86 are not connected to anything, they just hold the relay in the socket
  3. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    03-02-2012 05:21 PM #3
    finished gauges, wired the coolant temp sender
    oil wire is also present but does not yet have a pressure sender on the head
    i'll get one eventually
    next week i am tearing apart the front suspension to do bearings, ball joints, tie rods
    also doing the rear bearings since it was all a good deal
  4. Banned vento86's Avatar
    Oct 13th, 2008
    03-02-2012 06:57 PM #4
    Random
  5. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    03-03-2012 09:36 PM #5
    Quote Originally Posted by vento86 View Post
    Random
    thanks, it only gets more random the faster i get things done
    progress:
    and for fun:
    also finally cleaned my transmission....its been sitting there oily as ...oily dirt gets for nearly 2 months
    tis my spare GP transmission 6/81
  6. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    03-09-2012 12:10 AM #6
    front arms disassembled, almost
    the rest came apart easily
    factory control arm rivets
    not sure where the 6th one went flying to
    cleaned everything and painted
    grinding on everything to clean is such a huge task
    btw, steel wool works awesome and beats sand paper any day
    definately more work to do before this is done
    green factory arms after tons of rust grinding
    also has new bushings...although the 35 year factory ones were still good!
    these beautiful dust shields were in excellent condition. probally have been replaced..bearings were f.A. G. when i hammered them out
    yea im almost as bad as cooljet...colorful clowns we are
    also working on restoring this using some POR15
    btw, "chrome" paint and clear acrylic SUCK.
    chrome doesnt dry for shiz, and the acrylic makes everything RUN
    whatever
    replacement MOOG CC202 springs (variable rate w/AC)
  7. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    03-09-2012 12:39 AM #7
    Clown colored parts? Seriously?
  8. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    03-09-2012 12:46 AM #8
    Quote Originally Posted by deathhare. View Post
    yeah it really happens
    haters gonna hate
  9. Member simon_C's Avatar
    Oct 4th, 2006
    SFBAY
    1983 Rabbit GTI
    03-09-2012 01:05 AM #9
    Quote Originally Posted by rabbitnothopper View Post
    haters gonna hate
    I dig the hell out of it.
    When i do the ABA swap in my GTI its gonna be all sorts of stupid NEON colors, just for the haters.
    How does a rotary work? This one's easy: the magic triangle spins in the peanut and then apex seals come out.
  10. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    03-09-2012 01:14 AM #10
    Quote Originally Posted by simon_C View Post
    make sure you check out captain's project
    thats his engine
    http://forums.vwvortex.com/showthrea...hlight=captain
  11. 03-09-2012 03:07 PM #11
    that's stupid looking as fawk, I like it! hahaha
  12. 03-09-2012 04:54 PM #12
    In for the Ronald McDonald Donk picture.
  13. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    03-09-2012 04:57 PM #13
    Dont forget one of these for when you drive.
  14. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    03-10-2012 03:25 PM #14
    fffffffffffffffff................
  15. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    03-23-2012 04:51 PM #15
    springs and struts completely replaced
    finished
    hood etched, por'd, primerd, and pumpkin painted...best match i can get, whatever
    decided to take out the GC now and swap in my prepared GP
    not going to do my 81 GP rebuild right now and it seems to be running "OK"
    btw did i mention i hated this thing @60mph? 3400rpm is B!S!
    complete swap took 6 hours to perform
    .......by myself......i can benchpress a 75lbs transmission...and i dont even weigh close to twice as much
  16. Member GTrabbIt's Avatar
    Mar 12th, 2007
    San Diego, CA
    '11 Golf TDI
    03-23-2012 06:35 PM #16
    Can we see the whole car please?
    Our mk6
    oldskoolvw.com
    DIY Garage needs funding... CLICK HERE!!
  17. Member Vamped's Avatar
    Jan 2nd, 2003
    Las Vegas/Socal!
    3 Volkswagens!
    03-23-2012 09:26 PM #17
    Quote Originally Posted by GTrabbIt View Post
    Vamped EuroCouture!
  18. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    03-24-2012 03:49 AM #18
    oh....this was just pictures of parts and junk
    but ok
    hehe
    previous owner had a few pictures
    here is a "good" one
    pictures of these things, wish i could get some for a 4door
    i was talking to a beetle guy who said maybe JCwhitney
  19. Member GTrabbIt's Avatar
    Mar 12th, 2007
    San Diego, CA
    '11 Golf TDI
    03-26-2012 12:48 AM #19
    I want a panama brown
    Our mk6
    oldskoolvw.com
  20. Member 8v-of-fury's Avatar
    Jul 14th, 2008
    Central Ontario, Canada
    Because MK1
    03-26-2012 12:56 AM #20
    You weigh less than 150lbs??
  21. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    03-27-2012 01:15 AM #21
    Quote Originally Posted by 8v-of-fury View Post
    yes im 6foot and weigh 130lbs.... just like my grandfather
  22. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    03-27-2012 01:16 AM #22
    sell you this one for $2k
    which is obviously about 1.5k loss for me
    haha...damn money pits
  23. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    03-27-2012 01:24 AM #23
    some finished project pictures...
    yes the front strut housings raise the car a lot
    its all i can do for now....
    let me paint a shark on this and we'll call it shark-jr
  24. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    04-08-2012 02:02 AM #24
    relayed the headlights today
    before: 11.00vdc @ lamp sockets (too dim....)
    after: 13.05vdc @ lamp sockets (perfectly bright)
    lots of fun
    i used 97-2003VW parts from various junkyard cars
    lots of good removable fuses/relay connections under the dash for this
    lets just say....my box of "parts" was a legit steal of a price.....
    definately an improvement in visibility
    two 30 amp fuses using Red 8 gauge wires from the battery (think it was 98 passat fuel pump wire)
    two 30 amp BOSCH relays using 12 gauge wire
    2 yellow low beam 12 gauge wire
    2 white high beam 12 gauge wire
    4 brown ground 12 gauge wire
    big improvement all around
    ....i used the left lamp as a signal yellow/black & white/black
    the right was disconnected and left inside the harness
    right fuses were removed
    ...........no pics
    no camera sorry
  25. Member MickR's Avatar
    Jan 27th, 2011
    Baltimore, Meowyland
    1977 Scirocco, Protege 5, Mobylette
    05-18-2012 10:45 AM #25
    This thread is one un-holy mega upload of dirty old Rabbit stuff!
  26. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    05-21-2012 01:36 AM #26
    Quote Originally Posted by MickR View Post
    yep that happens when life happens
    atleast i can drive it bro
  27. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    07-30-2012 10:00 PM #27
    I bought a windshield from a VW Dealership for $119
    plans eventually to get it replaced
    it is a factory VW STEUCK "Pilkington" windshield for 74-91 rabbits etc
  28. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    08-23-2012 11:52 PM #28
    so...post these here too
    havent done much lately
    you can see the black top I did
    which was great
    much better than the lumpy primer when I got the car
    it was spotted with surface rust everywhere under the primer
    i got it completely to bare metal
    por15 then primer then black, more black more black, then gloss
    the hatch was previously sandblasted...hrrmm...
    you can tell because the glass in one area is damaged from the sand
    got it down to bare metal on the outside also
    tons of sanding, por15, primer, some beautifully unmatched paint but it was smooth
    my touch ups on it show through clearly
  29. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    09-27-2012 09:08 PM #29
    so....my aluminum box w/ headlight relays
    not perfect, but it works great
    mounted to driver side strut
  30. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    01-19-2013 08:36 PM #30
    new random stuff for you
    AAR valve...normal temperature, roughly 50F
    looks like it opens
    new chrome Deluxe handles
    ill have new pictures of the door cards and panels tomarrow
    .....my driver side door check
    discovered why it never worked correctly
    its completely cracked
    this other one came with my car in a box when bought it
    obviously wrong one..
    and im making new copies of these hood things
    pics of copies tomarrow
  31. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    01-20-2013 06:10 PM #31
    modded and installed my woodgrain tach
    tach works, all lights work except EGR/OXS, and...the ground for the Oil pressure light is dead
    swapped my speedo/odo over because i hate trip-meters, and it didnt have a decimal
    filled the hole for the trip button with epoxy
    then decided its time to fix my door cards, install chrome handles
    and figure out what the banging is on the passenger door...
    the door handle foam disentegrates instantly....as expected
    bought new foam and cut it out to fit
    the window crank foam is the same kind and although 35 years old, still holds up great
    lubricated the window guides and adjusted the window slightly
    the water/vapor barrier is .002mil 20inches x 25ft...same went onto my 81 so why not
    i used rubber cement to help attach it to the metal compared to taping it entirely on my 81
    the speakers, forgot to measure them, but they are Jensen...kind of odd looking so not entirely sure how stock they are
    didnt get pics of all the passenger work but the banging sound was the window guide
    the lower end is metal instead of a plastic tube
    so the metal was Loose... and banging on the door metal
    i ziptied it and added some foam and a cloth pad, it became much quieter
    i know the whole process isnt the best vapor guard but it works well enough
    the stock stuff was mostly still there in fair condition and surprisingly not falling apart
    a few extra steps i should have done but i tend to skip them
    oh, the whole reason for this epoch?
    the driver side door check was broken...wanted to fix it
    and the passenger side was banging
  32. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    02-07-2013 02:10 AM #32
    post these pics too...
    rear wheels...old bad sachs & rusty springs
    front wheels with diesel spring
    from center of axle
    ...and my BMW lug wrench which works great on those hubcaps, it has a hinged clip on the angle to shove under the cap lip
    [/QUOTE]
    massive rear rake causes higher headlight low beams.....
  33. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    02-23-2013 10:12 PM #33
    replaced the heater valve today....no more leaking coolant from the heater valve!
    we'll see how long that lasts
    i put the Topran brand in from Germany bought from ebay.uk
    took the old MEYLE out and...ugh
  34. Member floridabmx's Avatar
    Apr 30th, 2008
    west palm beach, fl
    77 16v Rabbit
    02-27-2013 04:59 PM #34
  35. Member 83mk2scirocco's Avatar
    Nov 12th, 2008
    StickenBurg,AZ
    84 scirocco,83 Scirocco(parts),76 scirocco"Sabine",85 ledgends turbo scirocco
    04-07-2013 09:11 AM #35
    Dont be a doosh bag.deathcrack
