Results 1 to 12 of 12
Thread: FS: 1979 Scirocco 2.0 ABA Full CE2 Swap & More...
    Feb 12th, 2004
    raleigh, nc
    98 audi a4, 83 jetta
    01-28-2012 01:24 AM #1
    SOLD SOLD SOLD SOLD SOLD
    Specs:
    1979 Scirocco
    2.0 ABA from 1997 Jetta (obd2)
    Full CE2 wiring swap
    5-speed manual
    complete interior in ok shape (dash is cracked, rocco 2 seats with driver bolster wear, headliner needs tucked in around the edges)
    the GOOD stuff: (parts listed as new have between 3 and 300 miles)
    full ce2 wiring swap, headlights to tail lights
    outer high/lows with yellow inner wired to rare 3-position (on/rear/front) fog light switch
    runs, drives, makes good power
    obd2 functions, and can pull codes (has codes for rear o2 and evap, which was not installed)
    new front crossmember brace
    new timing belt & tensioner
    new water pump
    new thermostat w/ early aluminum elbow/thermostat cover
    new head gasket/bolts/other gaskets
    new tie rods (manual steering)
    new front wheel bearings
    new front hubs
    new front rocco 16v calipers/rotors/hawk pads
    stainless braided brake lines
    fresh fluids
    new control arm bushings
    new koni reds
    new h&r sports
    new front strut mounts
    new ball joints
    new 100mm axles
    new clutch disc
    new motor/trans mounts
    new clutch cable (in trunk, not yet installed)
    new shifter bushings
    new fuel filter
    new walbro fuel pump
    new rubber fuel lines
    new serpentine belt
    new intake pieces (silicone elbow, cone filter)
    new spark plugs
    new plug wires
    new ignition coil
    new fan switch
    modified early 1.7 timing cover to fit tall-block aba
    custom PCV configuration (using mk4 check valve, thereby deleting the flying saucer)
    fresh oil/filter/coolant/brake fluid
    the BAD stuff...
    the 2.0 aba is a little too tall, leaving a dent in the hood where the throttle cable bracket hits
    alignment is off
    needs tires - comes with teardrops
    instrument cluster is acting up. pretty sure it is something in the cluster harness (will include 2 ce2 cluster harnesses)
    was hit in the rear at some point, but repaired (figured it was worth mentioning)
    surface rust (no rot, nothing major)
    needs paint to be nice, but is decent
    no radio
    heater control vacuum lines leak, currently disconnected
    needs turn signal switch, it seems to have an intermittent connection when pushed down (left turn)
    the downpipe & exhaust was cobbled together with a mk3 unit, and some pipe i had laying around. not terrible, but not great. the downpipe is wrapped to keep heat away from the right inner cv joint
    comes with a ton of spare parts:
    spare glass for all windows except windshield
    exterior window trim/door window trim/etc
    there are some older (during build) pics here:
    http://s626.photobucket.com/albums/t...cpZZ1QQtppZZ20
    i will try to get some current ones within the next couple days.
    ***NOTE: it will not come with the black team dynamics wheels, probably teardrops.
    price:
    $3500 firm, but negotiable
    negotiable meaning, i will lower the price if you want me to take some of the new/good parts off of the car and replace with old, worn out stuff (suspension, brakes, crossmember brace, etc).
    i am also open to full/partial trades for cars & parts
    car is located in raleigh, nc
    can deliver for additional fee
    title in hand
    pm me or post up
    Feb 12th, 2004
    raleigh, nc
    01-28-2012 05:49 PM #2
    please excuse the fact that the cluster is not installed. i pulled it yesterday to figure out the issue
    Feb 12th, 2004
    raleigh, nc
    02-21-2012 01:07 AM #3
    bump..
    will trade for b5 a4 stuff, 1.8t stuff, a truck, big turbo crap, etc.
  4. Junior Member
    May 26th, 2009
    pa
    90/94/raddo 88foxwag/85van/78van/e21/b5a4
    02-27-2012 02:38 PM #4
    like what do u need off of a b5 a4 for that rocco
    Feb 12th, 2004
    raleigh, nc
    02-27-2012 03:21 PM #5
    i have a 98.
    i mostly need performance stuff. upgraded fuel pump (looking for the 034 unit), drivetrain stabilizer, clutch, front gray seats with working heaters (broken elements sucks in the winter), upgraded mounts, etc. i don't really need any oem stuff as i parted a 99 recently. i could use a rear deck that doesn't have broken tabs. or "big turbo crap". rs4 grille, front pearl white a4 bumper without holes and/or the lip/valence (unbroken)
    lmk if you have anything like this, or shoot me a pm with offers.
  6. Member
    Feb 12th, 2004
    raleigh, nc
    03-27-2012 11:25 AM #6
    Feb 12th, 2004
    raleigh, nc
    04-09-2012 04:42 PM #7
    just ordered a new wiper switch, so that will be fixed soon
    Feb 12th, 2004
    raleigh, nc
    05-31-2012 12:59 PM #8
    will trade for 4x4 truck or van (tow rig, preferably v8), e30, or some other small rwd car, or other vws.
  9. Member MattRabbitDrummer's Avatar
    Dec 8th, 2007
    NNJ
    2010 Golf TDI,'86 635CSI Euro
    07-08-2012 06:18 PM #9
    damn, i wish this was closer. I'd totally trade an e30 for it.
  10. Member
    Feb 12th, 2004
    raleigh, nc
    07-18-2012 11:12 AM #10
    bump
  11. Member
    Feb 12th, 2004
    raleigh, nc
    08-22-2012 11:31 AM #11
    up.
    Feb 12th, 2004
    raleigh, nc
    08-30-2012 01:37 PM #12
    really looking to get this out of my way.
    make an offer (cash or trade)
    i'll be at h2oi if that helps.
