VWVortex.com - WTB/Rent/Borrow engine support beam
    Results 1 to 21 of 21
    Thread: WTB/Rent/Borrow engine support beam
    1. 01-29-2012 10:00 PM #1
      need to swap a transmision on a MKIII, anyone have an engine support beam I could borrow or rent? Or buy? On Oahu.
      Thanks
      Kbeefy1@gmail.com
    2. Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      1984 GLi 20v, '16 M3, '85 Golf, '03 BMP 20th AE
      01-29-2012 10:14 PM #2
      no one locally has them, i have been meaning to order one for awhile, just lazy lol. i wihs there was a harbor frieght here :\
      :HOMEGROWN MOTORSPORTS:1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
    3. Member Vegeta Gti's Avatar
      Feb 12th, 2003
      01-29-2012 10:15 PM #3
      u dont need one to do a trans in the cabby tricks dude
      What vegeta said.
    4. 01-30-2012 12:08 AM #4
      Can I make do with a small floor jack and the widowmaker? I've done conventional trannies/tcases w/ less, never done a transverse one before. I don't have much help available, don't know anyone here.
      Apr 24th, 2004
      Crockett, California
      '83 Caddy 16V, '87 Cabby 2L, '09 Jetta 2.0T, '66 Suburban 4WD, '57 Austin Healey V8, '04 Dodge Ram
      01-30-2012 12:48 AM #5
      Not that familiar with MKIII engines but I made my own to use on my '87 Cabby. Don't have a picture but I could take one if the following isn't clear. First, I cut a piece of 4" x 4' framing lumber to a length that just fit between the fenders. Each end rests on the edge of the fender which is covered by the hood when the hood is closed. This is where the factory one sits. then I went to a hardware store and bought 1/2" diameter by 12" "eye bolt". I took a sawsall and cut an inch or inch and a half off of the eye portion. Now I had a hook rather than an eye. On my JH engine there is a hole in a cast in flange on the head near the #1 spark plug.
      This isn't the greatest picture but you can see the hole to the left of the oil pressure sender on the end of the head. I set the 4 x 4 over the hole and marked it so that I could drill a 5/8" vertical hole for the modified eye bolt. Hook the eye bolt in the hole on the head, thread the threaded portion through the 5/8" hole, add a large washer and finally a nut. I may have used a tap to make the threaded portion longer. Don't remember. Using a wrench, you can lift or lower the engine by adjusting the nut.
      Classified forum rules require that you post a price. If you don't know what to ask, they suggest that you search past FS threads.
      So, when your item sells, please don't edit out your price and description when you mark it "SOLD". Rather, edit to show selling price.
    6. Member 96744.5's Avatar
      Jun 30th, 2006
      Kahalu'u,Oahu HI
      97' VW Jetta,03' Audi A4
      01-30-2012 02:12 AM #6
      You really dont need one,Ive always used a floor jack and jackstands.Where are you doing the swap?Maybe I can assist,if you want.
      low.life.society
      Apr 24th, 2004
      01-30-2012 03:34 AM #7
      Quote Originally Posted by 96744.5 View Post
      Have you ever used one?
      Just because you can do it without the above doesn't mean that they're not useful. You need to lower the engine to get the necessary clearance to pull the tranny off. It's way safer and way easier to slowly raise and lower the engine with a wrench.
    8. 01-30-2012 11:28 AM #8
      I'm in mililani....
      I'll take a look today and see if a flat piece of lumber will clear everything in the MKIII, and what I have to grab ahold of. Thanks for the explanation, I'm pretty sure I can handle that. I like the idea of suspending it, especially working by myself.
    9. Member 96744.5's Avatar
      Jun 30th, 2006
      Kahalu'u,Oahu HI
      01-30-2012 04:24 PM #9
      Quote Originally Posted by suburbangeorge View Post
      No,I haven't.Because like I said,I do just fine without it.Nowhere in my post did I say it wasnt useful,I just said a floor jack works just fine for me.I've done many clutch jobs and trans swaps,you have to work with what you got.Not everybody has the exact tool for every single job.
      low.life.society
    10. 01-31-2012 12:39 AM #10
      I looked, the 2.0 upper intake is a bit to high to use a flat board. I'm pretty sure I can build something with a few extra pieces of 2x4 or 4x4. The hole is still there.
    11. Member
      Apr 24th, 2004
      01-31-2012 02:10 AM #11
      Good luck
    12. Member Vegeta Gti's Avatar
      Feb 12th, 2003
      01-31-2012 04:07 AM #12
      dude, i'll help. we'll have the trans swapped in no time. it's gravy. trust me.
      What vegeta said.
    13. Member 96744.5's Avatar
      Jun 30th, 2006
      Kahalu'u,Oahu HI
      01-31-2012 08:37 AM #13
      Quote Originally Posted by Vegeta Gti View Post
      I second that.
      low.life.society
    14. 01-31-2012 11:46 AM #14
      Thanks, I'll post back up when I get the tranny and associated parts. I'll buy beer and burn some meat or something.
    15. Member Vegeta Gti's Avatar
      Feb 12th, 2003
      01-31-2012 03:22 PM #15
      Quote Originally Posted by kbeefy View Post
      deal
      What vegeta said.
    16. 02-09-2012 11:16 PM #16
      Well, it's ghetto, but I think it'll work. At least it was cheap.
      Tranny finally showed up, I'm gonna order a couple other parts to replace while it's out.
    17. 03-15-2012 10:23 PM #17
      I bought another car for the wife so this has been on the back burner...
      finally got the tranny out....
      Is that bad?
    18. Member Vegeta Gti's Avatar
      Feb 12th, 2003
      03-15-2012 11:46 PM #18
      diff went pop
      What vegeta said.
    19. Member 96744.5's Avatar
      Jun 30th, 2006
      Kahalu'u,Oahu HI
      03-17-2012 04:51 AM #19
      "and boom goes the dynamite."
      low.life.society
    20. 04-05-2012 04:16 AM #20
      Finally got it all back together and test drove, works great!
      Wound up going with a rebuilt close ratio 2y tranny, new clutch and pplate, rear main seal, oil pan gasket, adjustable clutch cable, changed the oil, new tranny mount, shift bushings, relay rod, linkages... drives and shifts awesome! Still need to replace a couple shift rod bushings, but they can wait.
    21. Member Vegeta Gti's Avatar
      Feb 12th, 2003
      04-05-2012 06:40 AM #21
      What vegeta said.
