Results 1 to 12 of 12
Thread: 1.8l 16v r1 carbs
  1. Member lilredcabby's Avatar
    Mar 28th, 2010
    CT
    mk1 cabriolet
    01-31-2012 12:29 AM #1
    im going to start my project soon and have a few questions for now one is, what do i do with my crank case breather? do i just put a filter on the opining?
    and what are people doing for jets?
    is there a specific way to tap for a break booster or could i use the nozzle thats originally on the lower half of a 16v intake mani? heres a pic of the nozzle im talking about.
  2. Member oldschool eighty8's Avatar
    Apr 17th, 2009
    Way up theah, Maine
    CW mkv GTeye,BM20th toilet#461(dead to me),91 EA cabby, yellow C
    01-31-2012 12:34 PM #2
    Run a catch can for the breather, an the fuel return you shoudnt need anymore. you can cap it off or run a return from your fpr to it
    I am in the middle of putting mine together right now ( 1.8 16v on r1 carbs) if you have any other questions feel free to pm me
  3. Member lilredcabby's Avatar
    Mar 28th, 2010
    CT
    mk1 cabriolet
    01-31-2012 10:18 PM #3
    oh ok sweet what are you doing for a throttle cable? and ill prolly have a lot of questions im very new to this
  4. Member oldschool eighty8's Avatar
    Apr 17th, 2009
    Way up theah, Maine
    02-01-2012 04:49 AM #4
    I have a diesel rabbit cable an a few different cable ends, I haven't tried it yet I'm still putting the motor together
  5. Member lilredcabby's Avatar
    Mar 28th, 2010
    CT
    mk1 cabriolet
    02-01-2012 07:16 PM #5
    also what are people running for jets?
  6. Member lilredcabby's Avatar
    Mar 28th, 2010
    CT
    mk1 cabriolet
    02-05-2012 10:11 PM #6
    any one?
  7. Member impulse byer's Avatar
    Mar 8th, 2003
    Guelph,ON
    97 Jeep ZJ "Black Dynamite" mk3 parts car
    02-06-2012 09:04 AM #7
    Quote Originally Posted by lilredcabby View Post
    vacuum for your booster I taped one of the plugs I made for the injector holes. Once you plug the holes that port you have circled will be useless. And as someone said above run a catch can off your breather. it will reduce the mess on your motor.
    The plugs are 22mm with a 1.5 thread pitch iirc.
  8. Member lilredcabby's Avatar
    Mar 28th, 2010
    CT
    mk1 cabriolet
    02-06-2012 01:17 PM #8
    the mani that im using i bought used from a guy who already pluged the holes and he used quarters so that breather still breaths and i dont realy have the money for the adapter for the catch can is ther another way todo it?
  9. Member 86Franklin's Avatar
    Apr 5th, 2008
    Goshen, Indiana
    1986 VW Cabriolet 1.8l 16v / 01 Audi A6 2.7T Quattro
    02-08-2012 09:36 PM #9
    Question. What kind of tools do you have access to? I made the the breather block off with a 1/4" inch piece of steel. Traced the breather shape and cut it down with a band saw. Then used a grinder to make it look pretty. As for throttle cable I'd find a motorcycle shop to alter yours or make one.
  10. Member lilredcabby's Avatar
    Mar 28th, 2010
    CT
    mk1 cabriolet
    02-08-2012 10:18 PM #10
    Quote Originally Posted by 86Franklin View Post
    thank you for replying none has for awhile and today with my free time i took the breather off my spare 1.8l 16v block and went to advanced autoparts and got rubber gromets for valve covers and then got a plastic piece that fits my catch can hose and it worked out pretty nicely tomoro im ganna put it on my car. but im wondering if i should drill and tap a hole into my valve cover and run my catch can to that to?
  11. Member 86Franklin's Avatar
    Apr 5th, 2008
    Goshen, Indiana
    02-09-2012 05:37 AM #11
    If the breather hose is a pretty good diameter (like 1/2 inch) I wouldn't worry about it.
  12. Member lilredcabby's Avatar
    Mar 28th, 2010
    CT
    mk1 cabriolet
    02-12-2012 02:25 AM #12
    thank you i think this week somtime im ganna finaly put my new head on and then start doin the carbs
