Results 1 to 5 of 5
Thread: Weird rattle when taking off (MKV GTI)
  1. Member kristijonazz's Avatar
    Oct 9th, 2006
    California
    GTI
    01-31-2012 03:11 AM #1
    Hopefully someone will be able to help me identify the problem.
    Car is a 2007 GTI. The rattle comes from the center console (where the gear lever is), and is only there when the car is cold. After driving for 10-15 mins it goes away completely.
    Its hard to explain when the rattle occurs, but I will try my best:
    When taking off (releasing the clutch pedal and applying gas), but before the gear is fully engaged. Same thing when shifting onto 2nd gear. Here is a video:
    The rattle also occurs when the car is being "jerked". For example, in this video I'm in 1st gear, simply applying gas and releasing it:
    If you listen closely in this video, it sounds like something is "stretching" when I'm on the gas, and then "stretches back" when I release the gas.
    In other words, the rattle occurs whenever there is stress applied.
    I have a Neuspeed Torque Arm Insert installed, could that possibly be the cause of this? (it did not rattle in the beginning) Dogbone mount? Or a transmission mount?
    Thanks is advance for any help
  2. 05-08-2012 05:20 PM #2
    Got the same thing on the DSG...making me crazy!
  3. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
    05-09-2012 03:21 AM #3
    same boat... happened after i installed my BSH dogbone mount. not sure what it could be... maybe something gets loose inside the console?
  4. 05-09-2012 05:23 AM #4
    well... i didnt install anything.
    got my stage 2 few weeks ago and drove a bit harder a night.
    later that night it just did that noise...
    now it only happens when the car is cold.
  5. Member kristijonazz's Avatar
    Oct 9th, 2006
    California
    GTI
    05-15-2012 01:57 AM #5
    I found a post on some australian VW forum, which was suggesting I replace the bolts holding the dogbone mount. It did not silve the problem for me.
    I stopped by at a local dealership to show the the rattle, and the tech said that I should replace the dogbone mount itself. Its only about $90 on ECS, so I might give it a try when I get some free time.
    Anyone else have some ideas?
    Thanks!
