VWVortex.com - SOLO WERKS S1 Coilovers for MK5's In stock and Shipping | $499* | at AMI
    Page 1 of 8 12345 ... LastLast
    Results 1 to 25 of 187
    Thread: SOLO WERKS S1 Coilovers for MK5's In stock and Shipping | $499* | at AMI
    1. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      01-31-2012 04:54 PM #1
      At long last Solo Werks has released the MK5 platform S1 Coilovers!
      We are offering these complete coilover kits for:
      Lower 48 states - $499 shipped within the
      Hawaii / Alaska / PR - $559 shipped
      Canada: $575+GST/HST shipped (all duties and taxes are taken care of by AMI)
      Click Here to Order
      We have again had the pleasure of performing the Beta testing and first installation on this kit and have the measurements and data over and above the manufacturers specs
      Here are the specs / details on the kit:
      Features at A Glance
      Solo Werks S1 Coilover System - MK5 and MK6 - Premium Entry Level Coilover Suspension!
      • NEW FORMULA Silver Zinc Plated Housings for superb corrosion resistance
      • Silver spring perches - double lock ring design
      • Platform Specific Spring Rates and Matched Valving
      • Front 35-55mm (1.4-2.2") Lowering Range
      • Rear 35-70mm (1.4-2.75") Lowering Range
      • Includes shortened Sway Bar End links!
      • 3 year Limited Warranty
      Each Kit contains:
      • 2 Front Threaded Coilover Dampers -NEW FORMULA Silver Zinc Plated with dual locking ring perches
      • 2 Front Springs+2 Helper springs
      • 2 Rear Dampers
      • 2 Front Swaybar End Links
      • 2 Rear Adjustable Perches
      • 2 Coilover Spanner Wrenches
      Please note, you must reuse your factory bump stops/dust boots with this kit.
      Here is the Beta Test car in its testing:
      Stock height:
      At the Solo Werks lowest "recommended lowest setting - 55mm front 70mm rear":
      The Hub to Fender measurements for the Solo Werks Recommended max lowering:
      Solo Werks Posted Lowering ranges:
      AMI Tested max drop:
      AMI Tested max drop measurements:
      • Tire size as tested is 225/45/17
      • The max lowering shown in the tables above is achieved at the lowest position of the threaded adjustment on both front and rear axles.
      • Helper Springs have been retained and should not be removed! See notes below on the Helper Springs.
      • These measurements allow for the shock absorbers both front and rear to have the minimum amount of travel required by the engineers to do their job before full bump stop engagement.
      • Depending on your wheel and tire combination, you may need spacers to clear the coilover perch/springs. SOLO WERKS recommends at least 5mm clearance in this case.
      • At the lowest level with some wheel/tire combinations, you may need to modify one or more of your body panels to allow for sufficient travel of the wheel inside the fenders. Please ensure that you have clearance from all obstacles through the complete travel of the wheels.
      NOTES: The Helper springs are there to keep tension on the main spring during full extension of the shock absorber.
      The main spring is not long enough on its own to keep the shock at full extension.
      Removal of the helpers will result in the main spring being able to travel away from its upper and lower spring perches, and will result in damage to your suspension as well as other components.
      DO NOT REMOVE THEM!!!
      eurocollective
      sales@eurocollective.com
      Toll Free 1 (888) 362-3117
      BB Exhausts - FK - KW - Magnaflow - Solo Werks - ST - Wagner Tuning & more
      www.eurocollective.com - Contact us for a personalized quote!
    2. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-01-2012 07:28 PM #2
      Thanks to everyone for their questions & orders!
      Our shipping department is busy getting your kits shipped this afternoon for everyone who has ordered as of 3:00PM pacific time today, watch your email for tracking
      Let us know if you have any questions!
      Glen @ AMI
      eurocollective
    3. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-04-2012 09:31 PM #3
      Thanks to everyone who ordered last week!!!!
      All orders that were received before 3 PM pacific time on Friday have been shipped, and your tracking information should be in your inbox (check your junk folder just in case!)
      All Questions have also been responded to that have been received as of Saturday evening.
      Thanks!
      Glen @ AMI
      eurocollective
    4. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-06-2012 08:01 PM #4
      Thanks again to everyone who ordered over the weekend!
      All kits are on their way that were ordered before 2:30 PM today
      For those who have ordered, do not forget to post your reviews online on Vortex or other forums and email your ship to info & Shirt Size into Solo Werks (info@solo-werks.com) along with the link to the thread and they will get a Solo Werks coilover shirt sent out!
      Glen @ AMI
      eurocollective
    5. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-07-2012 08:30 PM #5
      Our shipping department is really busy trying to get out all the orders today!
      They get a bit carried away, but they are pretty sure they can get everyone's order that was placed in the last 24 hours out today!
      Orders shipping out today will have tracking emailed to them via our automated system + UPS/FedEx
      Keep the questions coming!
      Glen @ AMI
      eurocollective
    6. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-08-2012 07:54 PM #6
      Another great day!
      As always, all orders received before 3:00 PM pacific time are in process and will be shipping today and tracking information will follow - watch your email boxes for the info (and check your Junk folder just in case)
      Thanks!
      Glen @ AMI
      eurocollective
    7. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-09-2012 08:12 PM #7
      Thursday Bump!
      Keep the questions and orders coming!!!
      Thanks
      Glen @ AMI
      eurocollective
    8. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-10-2012 09:24 PM #8
      TGIF!!!!
      All orders that were received before 3PM today are on their way via UPS / FedEx
      We will be in and out of the office this weekend, so don't hesitate to send us a PM or email!
      Have a great weekend!
      Glen @ AMI
      eurocollective
    9. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-11-2012 07:17 PM #9
      Saturday Update.
      All PM's and emails have been responded to and all orders processed in the warehouse.
      Thanks!
      Glen @ AMI
      eurocollective
    10. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-13-2012 08:07 PM #10
      Thanks to everyone who Ordered, PM'd or sent in Emails over the weekend
      All orders placed by 3:00PM today are on the shipping doc ready for pickup by UPS for domestic or FedEx for International - tracking numbers to follow in your inbox later tonight
      Let us know if you have any additional questions
      Thanks again,
      Glen @ AMI
      eurocollective
    11. Member
      May 18th, 2002
      Montreal, Canada
      VW Golf 1990 Diesel, VW GTI 1991 8V, VW GTI 1992 16V, VW JETTA 1992, VW GOLF 1991 8V, VW RABBIT 2008
      02-14-2012 06:02 AM #11
      Can't wait to receive them and install this spring!!!!!!!! Snow go away!!!!
    12. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-14-2012 06:01 PM #12
      Quote Originally Posted by disphunktion View Post
      Your kit is now on its way! Check your inbox for tracking
      Thanks again for the order,
      Glen @ AMI
      eurocollective
    13. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-14-2012 07:30 PM #13
      Tuesday Bump!
      All orders from the last 24 hours are on the shipping dock waiting for UPS/FedEx pickup
      Thanks again for all the questions and orders!
      Glen @ AMI
      eurocollective
    14. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-16-2012 08:24 PM #14
      Almost the end of another great week!
      As always, orders placed in the last 24 hours are on the dock and ready for UPS/Fedex to pickup and get on their way to their new owners - with tracking numbers automatically going to your inbox!
      Let us know if you have any questions, and don't forget to post your reviews on Vortex and send in the link to the review and your info inc shirt size to info@solo-werks.com for your free shirt!
      Just as a reminder, Solo Werks S1 Coilovers are in stock and shipping for:
      MK2 + MK3's 2wd
      (Golf, Jetta, Passat B3...)
      MK4 2wd (Golf, Jetta, Beetle...)
      MK5 + MK6 (Golf, Rabbit, Jetta, Passat, Eos, CC, R32 ...)
      All for $499 shipped within the lower 48!
      Thanks
      Glen @ AMI
      eurocollective
    15. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-17-2012 07:05 PM #15
      Welcome to the Weekend!
      Thanks again to everyone that has ordered and sent in questions on these kits
      Our shipping department has all orders that have been received over the last 24 hours on the dock ready for UPS/FedEx pickup.
      Glen @ AMI
      eurocollective
    16. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-20-2012 07:00 PM #16
      Happy Presidents Day for our US Customers & Family Day for many of our Canadian Customers!
      We hope everyone has had a great weekend
      Thanks to everyone who placed their orders over the weekend, our shipping staff is working to get everyone's order on their way today.
      As always, your tracking information will be sent to your inbox from our system as well as UPS/FedEx.
      Please let us know if you have any questions.
      Don't Forget to post pics of your car when you get the kits installed!
      Thanks,
      Glen @ AMI
      eurocollective
    17. Member
      May 18th, 2002
      Montreal, Canada
      02-21-2012 09:29 AM #17
      I will be posting picture next weekend.
      Switched from FK Streetline (which was broken after 15 months), I must say that these are way more comfortable! It feels like a cup-kit with near stock comfort.
      Overall, I recommend the kit to anyone looking to go lower and that is aiming for comfort with a little bit of sportiness in. The perfect balance for people that daily drive their car in uncomfortable environment.
    18. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-21-2012 07:16 PM #18
      Thanks for the quick review!!!
      Don't forget to put your complete review with the images in a new post and send the info & your shirt size to info@solo-werks.com and Solo Werks will get your T-shirt on the way
      Glen @ AMI
      eurocollective
    19. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-21-2012 07:22 PM #19
      Another Great Day!
      As usual our staff is busy getting all of the orders out
      Tracking numbers are following shortly after pickup by UPS / FedEx
      Keep the questions / PM's / emails coming!
      For those of you interested in more Stormtroopers Check out the artist's page Stormtroopers 365 for a years worth of Stormtrooper goodness
      Thanks,
      Glen @ AMI
      eurocollective
    20. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-22-2012 09:09 PM #20
      Happy Hump Day!
      All PM's and Emails have been responded to, and all orders processed and shipping as we speak.
      Thanks again!
      Glen @ AMI
      eurocollective
    21. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-23-2012 08:31 PM #21
      Thursday Bump!!! - Another Crazy day in the AMI Shipping Department
      For everyone who sent in a question or ordered today, all questions have been answered and our shipping department has all orders that were in before 2:00 PM today are on the dock ready for pickup by UPS/FedEx.
      Thanks,
      Glen @ AMI
      eurocollective
    22. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-27-2012 10:03 PM #22
      Thanks again for a great weekend!
      All PM's and Email questions and quotes have been responded to.
      All orders placed from Friday until today before 3:00PM have been shipped and your tracking numbers should be in your inbox!
      Glen @ AMI
      eurocollective
    23. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-28-2012 10:19 PM #23
      Tuesday Update
      Another busy day at AMI - All PM's, Emails and Orders have been processed and tracking numbers & answers are in your inbox
      Don't Forget, we also have MK2, MK3 & MK4 kits for your friends and family with other VW's in stock and shipping!
      Glen @ AMI
      eurocollective
    24. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      02-29-2012 08:56 PM #24
      Another busy day at AMI!!!!
      For everyone who has put their order in, I have just received the updates for today and all orders received in the last 24 hours have been picked up by UPS and FedEx and tracking is in your inbox.
      Also, all questions in the form of PM's and Emails have been responded to.
      Thanks again for such a great response to a great product
      Glen @ AMI
      eurocollective
    25. Banner Advertiser eurocollective's Avatar
      Sep 2nd, 2010
      2002 Audi TT 225Q
      03-05-2012 09:26 PM #25
      Monday Update - Tracking Emails on their Way!!!
      Thanks to everyone for their orders over the last few days - Your tracking numbers have been emailed and your kits are on their way! (and maybe a few Rebel Hate mail's as well )
      Keep the questions coming, and the reviews! We have been told by Solo Werks that they have finally started receiving emails over the weekend with reviews, so for those of you on the fence keep watching the forums!
      Thanks again,
      Glen @ AMI
      eurocollective
    Tags for this Thread
