Results 1 to 27 of 27
Thread: 2012 PZEV 2.0 T oil question
  1. n00b
    Jan 3rd, 2012
    RI
    2012 CC Lux Plus, candy white
    02-02-2012 09:29 AM #1
    This is a first time post, seems like a great forum.
    I have 2012 2 liter CC. It is the PZEV moter, so CA emissions. The owners manual calls for 502.00 or 503.00. The sticker under the hoods states 502.00. I am pretty sure our dealer uses the Castrol SLX Pro LL3 which is 504 and 507 approved so they can use it across the board (gas and TDI). I want to go to the dealer while the vehicle is under warranty, otherwise I would do all changes myself - love the oil filter being on top.
    I have been reading posts trying to figure out if I should insist on 502 or just go with the 504/507 oil the dealer has. I am not sure if there is a concesus on which way to go - it seems the 502 may provide better wear protection vs better intake deposit control with 503/507. One other thing, I plan on changing the oil every 5k rather than 10k per VW. About 1200 miles on it currently.
    Any comments on 502 vs 504 would be great, and also does 504 encompass 502?
    By the way, the vehcile is really nice, at least that is what my wife says as she pulls out of the garage smiling leaving me a little jealous!!
  2. Member DasCC's Avatar
    Feb 23rd, 2009
    Monterey Peninsula
    2012 VW CC R-line
    02-02-2012 04:13 PM #2
    504 superseded 502. They'll both work.
    Typos courtesy of iPhone 4 using Tapatalk
  3. n00b
    Jan 3rd, 2012
    RI
    02-03-2012 09:08 AM #3
    thanks for the info, will "trust" the dealer that they will use the 504 oil. i guess i am still curious why the sticker under the hood specifically states 502.00 - the vehicle has a late 2011 build date, i would imagine it would include the 504 option as well.
  4. Member
    Nov 10th, 2010
    mid hudson valley
    02 jetta wagon 1.8t, 03 passat 1.8,06 jetta 20t
    02-03-2012 11:46 AM #4
    504 does not superside 502 but rather 503.. google vw oil specs. it's probably all good but if you're on warranty use what's called for.
  5. Member DasCC's Avatar
    Feb 23rd, 2009
    Monterey Peninsula
    2012 VW CC R-line
    02-03-2012 03:30 PM #5
    Quote Originally Posted by gmikel View Post
    Oops I stand corrected! I knew it replaced something
  6. Member
    May 10th, 2010
    North Jersey
    08 Passat wagon 2.0T 6MT (current). Past: 02 Golf TDI, Dark Beige 88.5 Camry V6 5MT, AE82 Corolla
    02-03-2012 11:04 PM #6
    504 does "supercede" both 502 and 503 specifications. It is suitable for both flexible service (503) and fixed intervals (502)
    likewise, 507 covers both fixed (505) and flexible service (506) for TDI's
    2008 Passat wagon, 2.0T 6MT with mods
    Other Rides:
    - 2013 Cannondale CAADX-6
    - 2010 Specialized Secteur Elite
    - 2009 Specialized Rockhopper Comp 29-er
  7. 02-04-2012 12:40 AM #7
    Problem.
    The sticker states VW 502 because that's what's needed to deal w/our high sulphur fuels in the USA. Although 504 "exceeds the requirements of 502" or is "recommended for 502", the products themselves are very different, 504 being a low-saps oil...basically low-additive, intended for the nice clean Euro petrol.
    In contrast, dealer Syntec 502 has high additive levels, across the board.
    Any qualified shop should know this, and use 504 in the diesels only. A prime example is BMW, they already acknowledge the issue with low-saps LL-04 oils in the USA, specing the "older" LL-01 oils instead.
    You mention Cali emissions, afaik, there is no difference in the engine or emissions. Unless CA legislates low-sulphur fuel, you are in the same boat as everyone else and should avoid the low--saps oils.
    http://sas-origin.onstreammedia.com/.../pc/index.html
    May 10th, 2010
    North Jersey
    02-04-2012 01:51 AM #8
    502 is also low SAPs since the last revision.
    Other Rides:
    Nov 10th, 2010
    mid hudson valley
    02-04-2012 07:46 AM #9
    Quote Originally Posted by BsickPassat View Post
    it's not what i read but, i do believe you know what you're talking about
  10. n00b
    Jan 3rd, 2012
    RI
    02-06-2012 02:45 PM #10
    Re: CA emissions, this was unfortunately my non-technical way of trying to describe the engine, i know there are two types (CBFA and CCTA), living in RI, we have the "CA" emission which I used instead of the proper term CBFA. But the manual specs 502 for the CBFA motor. is this issue improtant enough to insist the dealer uses a 502 or will my 5k oil changes allow me to always have enough additives if using 504. Also, i have read that the 504 oil may help in reducing intake build up b/c of the additives used in the formulation.
  11. n00b
    Jan 3rd, 2012
    RI
    02-06-2012 02:50 PM #11
    btw - thanks for the link apexxx
  12. 02-07-2012 12:12 AM #12
    I thin it'd be best to say, not to use 504 oils in cars not ever speced for it. That is, avoid it in most cases.
    Many of the DI and deposit issues came about at the same time as VW 504...and there were definitely problems.
    I have some Valvoline Racing Synth for this summer. Any oil rated API SL, SM, or SN won't have any issues with excessive zink or SA.
  13. Member
    May 10th, 2010
    North Jersey
    02-07-2012 01:04 AM #13
    Quote Originally Posted by Apexxx View Post
    100% wrong.
    the DI and deposit issues came about due to the nature of DI.
    Even one of your favorite sources, Lubrizol, lists a study showing Euro 4 oils, ie Low-SAPs oil (which includes 504 and some 502) show a reduction of deposits in the intake compared to Mid-SAPs oils (Euro 3)
    Other Rides:
  14. 02-07-2012 11:37 AM #14
    Umm, I said it was *at the same time*, which it was.
    low-saps is a BMW LL-04, with <.8% SA, not VW 504 with <1.5%, not really a huge reduction over the previous <1.6%.
    idk what your point is anyway.
    Intake deposits, in a warm lab, with European fuels is hardly the touchstone for our deposit issues in USA. If you are to buy into the test thing, how did we end up with such a grevious deposit issue anyway? I mean afterall, didn't VW "test" the fuel/oil combo of VW 502 and USA fuels? Hmm?
    Everyone says, "oh the VW engineers know everything". Well, do they?
  15. Member
    Nov 10th, 2010
    mid hudson valley
    02-07-2012 01:51 PM #15
    switch to the other half and take your meds.
  16. Junior Member
    Jan 26th, 2012
    Central NJ
    2011 Audi Q5 3.2; 2004 Subaru Forester XT; 2013 TTS Oolong Gray P+
    02-07-2012 03:11 PM #16
    Are you sure about? Because there are high SAPS 502 oils. Look at M1 0W-40 for instance. It has 1000 ppm's of phosphorus, 1100 ppms' of zinc, and sulphated ash of 1.3% and meets 502 so I believe it would not be considered low or even mid SAPS.
    M1 0W-40 data sheet pdf
    M1 zinc & phosphorus levels pdf
    This Motul X-clean data sheet has more info on mid SAPS levels
    TYPE OF USE
    Lubricant specially designed for last generation cars, powered by turbo Diesel direct injection or
    gasoline engines, EURO IV emission regulation compliant, requiring an ACEA C3 engine oil, high
    HTHS (> 3.5 mPa.s) viscosity and "Mid SAPS" with reduced content of suphated ash (= 0.8%),
    phosphorus (0.07 = x = 0.09%) and sulphur (= 0.3%).
    Suitable for any type of Diesel or gasoline engines calling for ACEA A3/B3 or A3/B4 lubricants.
    ATTENTION : For BMW vehicles, this product can be used for gasoline engines only in European
    Union countries, Switzerland, Norway and Liechtenstein. Refer to BMW recommendation.
    And here's the Lubrizol document.
    http://www.lubrizol.com/richmedia/En...6LowerSAPS.pdf
  17. Member
    May 10th, 2010
    North Jersey
    02-07-2012 03:16 PM #17
    mass produced gasoline direct injection was introduced prior to Audi.
    Other companies, including Toyota and Mitsubishi introduced GDI to the masses before Audi --- and they have experienced the carbon deposits before the Euro IV days.
    At least Toyota, learned from their earlier GDI (D4) production and introduced D4-S with both port & direct injection. They introduced that when VW/Audi just introduced us to the 2.0T FSI. And the D4-S does not suffer from carbon deposits, using US Gas and regular Group II engine oil.
    Lo and behold... the next generation of FSI/TSI technology is marrying port injection with direct injection, just like Toyota.
    Other Rides:
  18. 02-08-2012 02:52 PM #18
    Quote Originally Posted by Dennis M View Post
    TYPE OF USE
    Good post. Syntec 5w-40 is (what I consider) high organo-metallics, like 1200ppm across the board.
    Lubrizol explains, ina roundabout way, the new oils aren't for engine longevity or performance, rather emissions protection and EU legislation:
    UEIL Congress 2005
    – European automotive lubricant trends and impact on base oil
    requirements
    • Growth in demand for lighter viscosity grades is resulting in a
    change in base oils used for engine oil formulations: API Group III
    • Aftertreatment compatibility is leading to
    a new generation of additive technology:
    Lower SAPS1 engine oils
    • These changes are the result of new
    emissions legislation: Euro 42
    Note 1 – SAPS is a common acronym for Sulphated Ash, Phosphorus, Sulphur
    Note 2 - Detailed in Directive 98/69/EC
    So, as I say, oils like Mobil 1 High Miles aren't trying to meet the "uber-important VW spec", because it's not actually ideal, outside the European Parliament building.
    For USA, there are either *very few* good oils for 2.0 TSI or they *all* pretty much work fine, meaning auto store jug synthetic 5w-30....the answer depends on the amount of brainwashing. Sure, the tech tells the layman that 504 is "new and better".... thus the cycle begins.
    Anyway, back to the OT, 504 for 5000 miles in a new vehicle if the dealer is paying for it....sure, fine. The data I've seen, I wouldn't trade anything in my home oil stash for M1 ESP or SLX Pro OE.
    I have my last fill of green German Syntec 0w-30 coming up...
  19. Member
    Nov 10th, 2010
    mid hudson valley
    02-08-2012 04:03 PM #19
    with di NO fuel goes by the intake valve. what does it matter the source? just wondering
  20. n00b
    Jan 3rd, 2012
    RI
    02-08-2012 08:53 PM #20
    apexxx - is GC 502 approved? i used this for my nissan 3.5 - served me well for 120,000 miles
  21. 02-10-2012 01:59 PM #21
    Yes, sir.
    There is a whisper of fuel drawn across the intake when the valves lap doing VVT stuff. Crankcase oil mist is discharged into the intake, that's most of the deposit problem.
    Using less volatile oil is the best way to minimise vapour condensation. SynPower 10w-30 is amazingly low, under 10% NOWACK
    This is an old AMSoil study.
    I Seafoam my intake once a year and I don't **** with the airfilter.
    Top-Tier fuels often too.
  22. Member
    Nov 10th, 2010
    mid hudson valley
    02-11-2012 09:39 PM #22
    Yes, sir.
    do they offer buy one get one free if you call in the next 30 minutes and throw in free shipping?
  23. 08-10-2012 02:56 AM #23
    The dealer is using a oil convenient and cost profit for them and not for your vehicles benefit.
    Use the factory recommended oil. FInd a dealer that has it or have them order the oil prior to your service visit.
    Request factory 502 or 503 on your paperwork.
  24. Member
    Mar 24th, 2012
    Wappingers Falls NY
    2008 Passat 2.0, 2012 Golf TDi
    08-10-2012 04:16 PM #24
    So what gets rid of the deposits? I have an 2012 TDi, but my 07 Passat 2.0 might benefit from a shop injector cleaning service to help remove the deposits, yes?
  25. Member
    Nov 10th, 2010
    mid hudson valley
    08-11-2012 07:28 AM #25
    Quote Originally Posted by meboice View Post
    while it might clean the injectors, it will do nothing for the intake valves or ports. no fuel passes through the intake tract as it is injected directly into the combustion chamber. the pcv is plumbed into the intake tract and eventually fouls the intake valve and ports. you can try seafoam through the iat port or manually clean the valves. manual cleaning is best, but requires removal of the intake manifold.
  26. Member
    May 10th, 2010
    North Jersey
    08-13-2012 01:21 AM #26
    seafoam is useless through the IAT port as well as their spray can through the throttle body
    there is manual cleaning... and supposedly BG's chemically assisted manual cleaning
    Other Rides:
  27. Member
    Nov 10th, 2010
    mid hudson valley
    08-14-2012 05:54 AM #27
    i feel the same way, but some seem to think it helps. after doing a mnaual cleaning myself, cannot imagine a spay doing the job.
