I was certain about the outer lip/fender fitment, but i was still a bit unsure about the inner lip, specially fitting 9's in the front and 10's in the rear with such a high offset...and when the car is sitting at normal ride height, the inner lips actually sit even a tad bit closer to the struts.. my rears are et51 and front are et42 or (or 44, i forget)...the offset in the front can not be like a single mm higher...it's already too close for comfort..
depends what kind of fitment you're looking for...i don't think there is any way to tuck 10's in the rear, unless you had a lower offset and some ridiculous amount of camber, which i definitely wouldn't reccomend...and the you can tuck 9's in the front, shouldn't be a problem..but it is one hell of a tight fit...i'm finally trying to get around to have some time to roll and pull my fenders, specially the fronts....it's just a matter of time...i wish we had like 10 extra hours in a day..
