Page 5 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 141 to 175 of 287
Thread: Steelcurtain’s 3071 Build Thread
  1. 03-12-2012 09:15 AM #141
    Quote Originally Posted by steelcurtain View Post
    My previous 3+ 03 runs were 12.30 and 12.46. My old sig was the stage 3 93 run. I haven't run that slow on 93 tune in a long time. Stage 3 was easy 12.0/12.2. WTF??
    What are your 200 now on 93 vs old runs. My guess is wheel spin!!! and the track is still green. Your Car is a Monster! Your car is FOR SURE making more power! (I got to drive car Saturday) I think a couple more times at the track and adjusting tire pressure and launch is going to be Key!
    I honestly don't know how you are getting down the track that fast as 1st through 3rd are very touchy. You are a good driver and I know you will figure it out, as now it is a challenge!
    I can't wait till next time you hit the track as I know those times will come down.
    Your car is totally sick!!! There are no words to describe the pull that it has in 4th
    You just gotta tame this beast and get it under control at the track!!!
    Later,
    Jj
  2. Member VaGPuncher's Avatar
    Jul 22nd, 2006
    Queens, NY
    TR MK6 4Door Stage 3+
    03-12-2012 09:52 AM #142
    I'm confused as well. If you put my 12.2 timeslip up against your 12.3, your 60' was better and mph. I don't get how you crossed the line slower. As I said, I just wish we have stage 3 V2 timeslips to compare your 100oct run with.
  3. Member VaGPuncher's Avatar
    Jul 22nd, 2006
    Queens, NY
    03-12-2012 10:14 AM #143
    Maybe DSG getting hung up Shifting gears since your still at peak power at redline?
  4. 03-12-2012 11:45 AM #144
    wow surprised 3+ 93 was that much slower....
  5. Member pattrick02's Avatar
    Jun 9th, 2009
    South Florida
    MK6 GLI | MK4 GLI | 4.4TT X5
    03-12-2012 12:11 PM #145
    sweet build man! i envy this build!
  6. Member
    Mar 26th, 2008
    Fredericksburg, VA
    '12 R; Built GTI TSI 3+
    03-13-2012 07:08 PM #146
    100 octane file. 1st and only pass on this tune. The 2 passes with 93 were operator error. Not slow due to the tune.
    11.53@121.18
    Mar 26th, 2008
    Fredericksburg, VA
    03-13-2012 07:30 PM #147
    Newest addition to the engine bay.
    11.53@121.18
  8. Member GlfSprtCT1's Avatar
    Feb 8th, 2002
    East Hartford, CT
    2011 CSG GTI
    03-13-2012 08:10 PM #148
    thats on my shopping list for next month.
    2011 GTI / APR K04-Carbonio stg1/2 intake-APR catted dp-Magnaflow catback-APR intercooler-Audi S3 shifter-Podi boost tap/boost gauge-034 Motorsports engine/trans mounts (street density)-DXD stg2 daily-H&R coilovers-APR 27mm rear swaybar/Whiteline adj. end links-vcds coding tweeks-Tinted oem tails-HPA 6 piston bbk/80a subframe mount
    Follow on instagram @glfsprtct1
  9. 03-13-2012 08:15 PM #149
    where did you find it? Everyone I have asked seems to be sold out.
  10. Member
    Mar 26th, 2008
    Fredericksburg, VA
    03-13-2012 08:23 PM #150
    Quote Originally Posted by HalvieCuw View Post
    I got connections.
    11.53@121.18
  11. Junior Member theharleyquin's Avatar
    Mar 15th, 2011
    Orlando, FL
    '10 GTI DSG
    03-13-2012 09:17 PM #151
    Crazy build with some DSG love also. Did you do anything internal to the DSG or just the software?
    Mar 26th, 2008
    Fredericksburg, VA
    03-14-2012 08:36 AM #152
    Quote Originally Posted by theharleyquin View Post
    Just a dsg fluid change. The stock clutch packs are good with the stage 3 software. I'm having no issues. Others are putting down more than me on software and stock packs alone.
    11.53@121.18
  13. Junior Member theharleyquin's Avatar
    Mar 15th, 2011
    Orlando, FL
    '10 GTI DSG
    03-17-2012 10:36 AM #153
    That's a heartbreaker. Keep us up on what the issue was? Is it in the shop now?
  14. Member
    Mar 26th, 2008
    Fredericksburg, VA
    03-17-2012 10:51 AM #154
    Not in the shop now. After doing some research I'm thinking it is spark knock. I'm going to throw some race gas in it today and do some logging.
    11.53@121.18
  15. Member
    Mar 26th, 2008
    Fredericksburg, VA
    03-18-2012 08:06 AM #155
    On the way home from the bar yesterday the throttle body decided to take a ****. I haven't run meth since last Sunday at the track. So much for the dual nozzle setup. UFB.
    11.53@121.18
  16. Member VaGPuncher's Avatar
    Jul 22nd, 2006
    Queens, NY
    03-18-2012 08:51 AM #156
    wow that sucks...do you have that post throttle body plate with the meth bung?
  17. Member
    Mar 26th, 2008
    Fredericksburg, VA
    03-18-2012 09:06 AM #157
    Quote Originally Posted by VaGPuncher View Post
    I do but I also had a 175 post FMIC. That one was the culprit.
    11.53@121.18
  18. Member VaGPuncher's Avatar
    Jul 22nd, 2006
    Queens, NY
    03-18-2012 09:13 AM #158
    yea if i ever do a meth setup again i will just get the post TB plate..
  19. Member
    Mar 26th, 2008
    Fredericksburg, VA
    03-18-2012 09:43 AM #159
    Me too. I'm done spending money on these damn TBs.
    11.53@121.18
  20. Member
    Mar 26th, 2008
    Fredericksburg, VA
    03-19-2012 10:12 PM #160
    I removed the TB this evening. New one should be here tomorrow or Wed. Discovered a small air leak around the throttle body spacer evident by the blow-by residue on the back of the spacer.
    I also tested my methanol pump pressure yesterday with USRT's pressure gauge to discover absolutely no reading from the dial and every fitting was leaking. I had plenty of pressure coming from the pump to at least get a reading despite the leaking.
    I called them today and was told they only hand tighten the fittings. Guess they don't bench test it nor calibrate either. Or it's just .
    During a previous conversation, they took great pride in bad mouthing another well know tuner while trying to play up themselves. Needless to say I am not impressed with their customer service, sh!tty attitude and will never do business with them again. They can keep their $30. It's worth $30 too me to give them bad publicity. It's typically not my style to publicly bash another company, but given the above, I will take great pride in sharing my opinion of how unprofessional they really are. F'in ass clowns.
    11.53@121.18
  21. Member BMP_3918's Avatar
    Jun 21st, 2011
    Springfield, VA
    2012 VW Jetta SE, 1988 VW Cabby
    03-21-2012 11:10 AM #161
    Which company did you go with to get your STG3+ installed? I've been wanting to go STG3+ but I don't know where to bring my car to.
    2005 BLITZ COROLLA - 2001 AUDI A4 QUATTRO - 2003 BMP GTI #3918 - 2008 FORD FOCUS - 2010 BAGGED CW GTI - 1995 370 WHP VRT GTI -2012 BAGGED CW JETTA - 1988 VW CABBY
  22. Member DRedman45's Avatar
    Aug 7th, 2009
    NOVA
    07 SB Rabbit(sold), 10 UG 4dr GTI(sold), e86 //M coupe
    03-21-2012 11:14 AM #162
    NGP...but I'm no sure that's the post to quote when you asked haha
  23. Member pattrick02's Avatar
    Jun 9th, 2009
    South Florida
    03-21-2012 11:34 AM #163
    sorry to hear all the trouble. hope you get it all fixed out man..
  24. Member BMP_3918's Avatar
    Jun 21st, 2011
    Springfield, VA
    03-21-2012 11:49 AM #164
    Quote Originally Posted by DRedman45 View Post
    I've heard mixed reviews with NGP, some have good stories to tell and some have stories like this one. I didn't mean to put them under the spotlight lol
  25. Member DRedman45's Avatar
    Aug 7th, 2009
    NOVA
    03-21-2012 11:56 AM #165
    Every shop will get a small mistake now and then...but whenever you have an issue at NGP they will make it right...they are good guys
  26. Member
    Mar 26th, 2008
    Fredericksburg, VA
    03-21-2012 11:58 AM #166
    Quote Originally Posted by BMP_3918 View Post
    My post wasn't bashing NGP. They've been great. The leak was coming from the gasket provided with the spacer. None of this was NGP's fault.
    11.53@121.18
  27. Member BMP_3918's Avatar
    Jun 21st, 2011
    Springfield, VA
    03-21-2012 01:10 PM #167
    That's good to know, I hope you get everything fixed soon!
    That's good to hear since they're the closest shop to me.
  28. Member
    Mar 26th, 2008
    Fredericksburg, VA
    03-21-2012 09:04 PM #168
    I'm happy to report that all issues have been resolved. I replaced the TB today and left off the spacer so the leaking gasket wouldn't be an issue. To be honest I'm done with meth for now. After doing some spray testing thru the nozzle/spacer I am convinced that meth has dripped from the nozzle into the TB causing it to fail I just can't prove that. I even had the solenoid but meh.
    No more engine noise when lugging it.
    I still have some timing pull but that is just gas related. I drained the tank logging today and put some 104 octane and ran logs on 93 tune and 100 tune. 0 pull.
    Dyno has been rescheduled for Sat @ 9:30. Stay tuned!
    11.53@121.18
  29. Member VaGPuncher's Avatar
    Jul 22nd, 2006
    Queens, NY
    03-21-2012 09:19 PM #169
    good stuff..can't wait to hear numbers..
  30. Junior Member theharleyquin's Avatar
    Mar 15th, 2011
    Orlando, FL
    '10 GTI DSG
    03-22-2012 06:56 PM #170
    Awesome. *staying tuned*
  31. Member
    Mar 26th, 2008
    Fredericksburg, VA
    03-23-2012 10:10 PM #171
    Tomorrow's the big day. I'm shooting for 3 pulls on 93 tune and 3 on 100. You'all know the drill. Lol.
    11.53@121.18
  32. Member DRedman45's Avatar
    Aug 7th, 2009
    NOVA
    03-23-2012 10:23 PM #172
    Where are you dynoing?
  33. Member
    Mar 26th, 2008
    Fredericksburg, VA
    03-23-2012 10:37 PM #173
    HP Works in Colonial Beach,VA.
    http://hpworks.com/
    11.53@121.18
  34. Member DRedman45's Avatar
    Aug 7th, 2009
    NOVA
    03-23-2012 11:58 PM #174
    Nice you told me about them...I am thinking of hoping on their dyno myself one weekend soon...what do they charge for 3 pulls?
  35. Member
    Mar 26th, 2008
    Fredericksburg, VA
    03-24-2012 01:12 PM #175
    $70 for 3 pulls.
    Results are in:
    396 whp / 385 wtq on 100 tune.
    373 whp / 382 wtq on 93 tune.
    Both runs were with a blend of 2.5 gallons Sunoco 93 and 3 gallons on Sunoco 260GT+. No meth. The 100 tune was the last pull with 30 minutes of cool down. I'm happy. Crank figures come to 495hp. APR advertises 501. It was humid and raining and could I had better air flow. Winpep files will be posted later.
    11.53@121.18
