Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 71 to 105 of 145
Thread: Fresh VRT - Working out the kinks
  1. Banned dubinsincuwereindiapers's Avatar
    Jan 16th, 2008
    InYourMom
    Bugatti Veyron
    04-12-2012 08:37 PM #71
    Quote Originally Posted by Capt.Dreadz View Post
    thank you....even though it took me 5 min. just to figure out what you changed
    LOL! I was gonna bold it, but meh. FWIW some 1.8t guys are changing over to GM ls coils for a more powerful spark, wider plug gap, and smoother idle, etc.
    Gotta change the stock dwell in the ecu to gain full benefits tho.
  2. Member mike minnillo's Avatar
    Sep 23rd, 2007
    Colorado Springs, CO
    MKIV 12v VRT GTI, B5 Passat Wagon
    04-12-2012 09:01 PM #72
    Here's another idea, and actually a couple issues that I faced too. First, is your bov/dv venting to atmosphere or recirculated? These maf based cars like to be recirculated back in the intake after the Max, but before the Turbo. Also, what size maf housing do you have? I'm not sure about the 30# software that you have, but I know that a lot of the c2 software calls for a 4" housing. Just some food for thought.
    Jack of all trades.
  3. Senior Member Capt.Dreadz's Avatar
    Jun 3rd, 2003
    Long Island, NY
    VRT's & 2.7T's
    04-12-2012 09:13 PM #73
    Non recirc BOV wouldn't cause the issues he's having. My car is not recirc & i rarely have issues.
    Chosen Life Clothing. Streetwear for the car culture. Launch Party coming very soon!!
    Meet Long Island The place if you're looking for a euro GTG in the Long Isl./New York City area.
    FaceBook: Carlitus Christensen Sr. - Instagram: @ThatDreadLife - Twitter: @ThatDreadLife
    Kicks...Clothes...Cars...Ho's...THINGS I DO BEST!
  4. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    98 GTI Vr6-T (Project) | 96 GTI Vr6 (SOLD) | 97 Passat Wagon Vr6 (Daily)
    04-12-2012 10:15 PM #74
    Quote Originally Posted by mike minnillo View Post
    BOV is recirculating...I think. I have a vac line going from the top of the bov back into the intake...I have a 4" MAF.
    Ok I'm gonna regap the plugs tomorrow hopefully and come back with results. Would a leak in the intake cause the issues I'm having? THE ONLY possible leak I can think of is the IAT in the back of my manifold doesn't sit tight, I think the threads are f'd up...my CEL is on for 'reading too high' or something like that from the IAT...
  5. Member masterqaz's Avatar
    Oct 4th, 2007
    Oakville Ont
    94 JTI Vrt 60-1 .58ar exh obd2 440 racefile 20psi/meth
    04-12-2012 10:37 PM #75
    Quote Originally Posted by Insan3Vr6 View Post
    Usually the answers we're looking for are right in front of us and we already know, but for some reason we over think it and move on to try and fix something else.
    I'd start with what you know. If it isnt right fix it!
    Forced convection.... Now we grillin.
    Some times she goes, some times she doesn't.... Way of the road
    Rem 870 super mag in max 4 camo for sale. Pm me
  6. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    04-13-2012 12:36 AM #76
    Quote Originally Posted by masterqaz View Post
    True, I do over think issues sometimes and usually it's the dumbest thing ever, but it'd rather be cautious and ask first in an area I'm not familiar with (forced induction). I'll post an update tomorrow.
  7. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    04-14-2012 12:18 PM #77
    Regapped all the plugs to about .025. Idle smoothed a bit I guess, but I'm still having the same issue under throttle and when it first starts. Idle is super crappy, almost like the motor is about to die (I hear like a quick "SHACK" I think is coming from the passenger side when the idle is bogging).
    When coming out of throttle, idle bounces and then it dies and the battery light turns on. I'm thinking a vac leak, but I have to take my SRI off to inspect it, and I just put a fresh gasket on there...not sure if I can get away with re-using it or once it's sealed that's it...
  8. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    04-14-2012 12:32 PM #78
    This was when i was test fitting the front end. You can see the BOV...if that matters. The vac line isn't routed through there anymore FYI...so it's not pinched.
  9. Senior Member Capt.Dreadz's Avatar
    Jun 3rd, 2003
    Long Island, NY
    VRT's & 2.7T's
    04-14-2012 03:02 PM #79
    Timing off maybe? Did you take the head off?
  10. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    04-14-2012 03:12 PM #80
    Timing is def perfect. Chains were done when I removed the head to install the spacer + ARP studs.
  11. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    04-14-2012 05:22 PM #81
    May have found the problem. The TB seems to have separated (again) from the intake manifold. Definitely a huge issue. Going to remove the intake and see if I can make a better seal...clearly it backed out under pressure.
  12. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    04-18-2012 10:59 PM #82
    Removed intake...got a fresh gasket and made the TB fit much better...now I KNOW it's tight. Car does the same thing....I don't really smell gas that much anymore so I think I may have fixed something....
    BUT. IDK why the car won't stay on unless persuaded and why it dies after throttle. I'm noticing now it just falls on it's face once I hit the gas.
    Could this be an ignition problem? If so I'm chucking the MSD out the window and going back to stock.
  13. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    04-19-2012 10:24 PM #83
    Changed back to stock ignition. No dice.
    Car will turn over without a problem, but it won't stay on even if I hit the gas. I'm now getting throttlebody codes. I checked the plugs and the engine is not flooding or anything.
  14. Member masterqaz's Avatar
    Oct 4th, 2007
    Oakville Ont
    04-19-2012 10:55 PM #84
    I would invest in a boost leak tester, its just nice to have and you never know. You could be having a fueling issue. I had a buddy with a gauge inline to the rail under his hood for fuel pressure, it was a nice touch and can prove handy on the fly when sorting issues.
    Two great options which are both relatively cheap.
  15. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    04-20-2012 12:43 AM #85
    True. But none of these things were happening at first, which is why it's blowing my mind right now. This is the worst the car has run since I first put it together....and I've been 'fixing' things as I go along.
    I can hear the fuel pump priming, and it starts without any hesitation every time. It just never stays on, and I can't give it gas it just dies. I had a buddy adapt my throttlebody with VAG-COM and it did the same thing.
    I unplugged the battery for a few to reset the computer, then I wanted him to do the tb adapt again and no matter what we did he couldn't get a response from the controller anymore . No fuses are blown or anything. Clearly I am getting fuel / spark / air...otherwise it wouldn't start...
    HALP
  16. Member GinsterMan98's Avatar
    May 19th, 2008
    Panama City FL
    96 GTI VR6 08 Hyundai Santa Fe SE
    04-21-2012 02:19 PM #86
    HALP
    Chip tune? Make sure the chip did not fall out of the ecu, trust me.
    Wait, it runs? TB wont adapt?
    Where did you relocate the grounds from the intake manifold? Are they in good shape?
    98 GTI - Mustard Mayhem - 1/4 - 11.679@117.58mph - .8 bar - parted Timeslip
    96 GTI - Turbo Panda - 1/8 - 7.63@97mph - 1.1 bar of turbo fun!
    89 325is - New turbo project
    www.lugtronic.com
  17. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    04-21-2012 02:52 PM #87
    Quote Originally Posted by GinsterMan98 View Post
    I adapted it once, but that didn't change anything. Ground from the intake manifold are on the timing chain cover now, seems to be fine. And yeah, the car ran 'ok' besides the random stalling after hitting throttle, and before I was able to ONLY keep the car on by tapping the gas first, otherwise it would stall. After that the car idled high, but it stayed on.
    I ruled that issue down to a leak between the tb and intake manifold, so I fixed that up and here we are, except now I get nothing when I hit the gas...doesn't rev or anything.
    Haha I did not check to see if the chip fell out, though that seems pretty unlikely...
  18. Member cstanley19's Avatar
    Sep 23rd, 2006
    Las Vegas, NV
    92 Corrado 07 Mercedes e350 04 Touareg
    04-22-2012 02:26 PM #88
    Did you make sure that the MAF sensor is on correct? I had it on backwards and was getting the same symptoms. Sometimes it's just the stupid things, ya know?
  19. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    04-22-2012 03:51 PM #89
    Quote Originally Posted by cstanley19 View Post
    Yup yup. MAF sensor is on right, I even threw in a spare sensor and got the same results. Gotta be the TB....
  20. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    04-28-2012 06:36 PM #90
    Gotta be the TB....
    I wish. I just replaced the TB with a good one...same result.
  21. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    04-28-2012 07:51 PM #91
    This is what it does.
    Just starting the car - not hitting the gas.
    Hitting the gas before it stalls out, and it 'idles' (if you can call it that) and it sounds like ****.
  22. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    04-30-2012 10:57 AM #92
  23. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    Mk3 VRT, Mk4 VRT, Mk4 VR
    04-30-2012 01:19 PM #93
    That is running like azz. And not for nothing what's with the popping/backfiring?
    Here is my suggestion list.
    Get a pressure tester as already suggested by someone else.
    Check the chip is seated properly/swap with a friend as already suggested by someone else.
    Put a stock/unmolested throttle body on,
    Put a stock/unmolested intake manifold on,
    Put a stock/unmolested coilpack on
    I had a poorly made SRI once cause all that backfiring etc as per your video. In my case the vac gauge still read correctly, the leak though minimal was enough to prevent the engine running unlessyou gave it gas.
    "OP sounds like a MKIV guy"
  24. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    04-30-2012 09:53 PM #94
    Quote Originally Posted by V-dubbulyuh View Post
    NO IDEA
    I'll check that the chip is still sitting correctly, I don't know anyone with turbo software sooo I don't think that's an option. I changed to another throttle body and swapped back to the stock coilpack, everything is in working order.
    Yeah my SRI sucks. Poorly put together. But from what I can tell it's not leaking anymore, but I'm not doubting much anymore. I would have to change a good amount to go back to the stock intake mani, so if anything I'll get a better SRI.
    Answered in BOLD.
  25. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    05-01-2012 06:47 AM #95
    You can run the stock manifold and eliminate the intercooler to simplify your piping. I want to see if your popping is as a result of the manifold itself. I'm assuming you have easier access to a stock mani than having to source another SRI (especially if it turns out not to be the SRI). Your issue is at idle so you don't even have to drive it or boost to see if there is an improvement.
  26. Member
    May 12th, 2010
    Mk3 VrT Gti
    05-01-2012 11:28 AM #96
    When you are cranking it sounds like you have no compression.
    OBD1, Mk3 12v, 3L, HG, 8.5, JE, stock rods, 263, 3"DP to 3" MBS, Kinetic Mani, t3/t4 .63ar, Intercooled, PW39, C2 36# 4 bar, IE 044 surge, Stock intake, Peloquin, AEM truboost/uego/fp, Mocal OC
  27. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    05-01-2012 06:28 PM #97
    I suppose, but I had the car running ok with this intake before...and I sold my stock intake
    And I have compression..I can rev the piss out of it and it never stumbles or anything....just won't idle right
  28. Member GinsterMan98's Avatar
    May 19th, 2008
    Panama City FL
    05-01-2012 06:34 PM #98
    Try resetting the fuel trims.
    1. Delete any codes, even if there are none.
    2. Adapt the TB
    3. Start the car and let it warm up at idle for 20 min, don't rev it.
    4. Watch your short term fuel trim and see if it settles less than + or - 10% from 0.
    5. If the short term trims out and stays above 10, your O2 is not working correctly, the MAF is bad or you have a vac leak.
    6. Next drive the car at highway speed at varying loads until the long term fuel trim settles, same as idle trim.
    You monitor O2 regulation via the OBD screen on Vag Com. BS1 is your main O2 sensor
    www.lugtronic.com
  29. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    05-01-2012 06:55 PM #99
    2. Adapt the TB
    The problem there is I can only keep the car on if I hit the pedal a few times after ignition (second video). I will NOT stay on unless I do that...just turns right off (first video).
  30. Member GinsterMan98's Avatar
    May 19th, 2008
    Panama City FL
    05-01-2012 07:05 PM #100
    You didin't leave a rag in a pipe somewhere did you? I did it once, lol.
    www.lugtronic.com
  31. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    05-01-2012 07:14 PM #101
    Haha no, definately not. I don't know how many times I've gone over the piping / vac lines. Everything is tight.
    I thought I saw some smoke coming from near my 02 sensor though? I don't have alot of time to run to the front of the car after it's on...I dont' like letting it run like that to risk damage.
  32. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    05-01-2012 10:10 PM #102
    I swapped my ECU back to the stock one (stock chip), and I thought I figured it out because the car didn't shut off right away and it idled alot higher at first, but smooth. Then it slowly made it's way back down and idled like crap again (me figuring because it was a stock chip)
    I put my chipped ECU in and I started it and it didn't turn off, but idled like super ****. Put the stock ECU back in again to confirm, and it just shut right off again like it always has.
    WHATTHE****
  33. Member GinsterMan98's Avatar
    May 19th, 2008
    Panama City FL
    05-01-2012 10:19 PM #103
    Man, I just sounds like you got a big vac leak. I popped a coupler off on time and it acted like this.
    www.lugtronic.com
  34. Banned dubinsincuwereindiapers's Avatar
    Jan 16th, 2008
    InYourMom
    Bugatti Veyron
    05-01-2012 10:33 PM #104
    This..
    Why haven't you pressure tested yet? Its standard procedure, and you can't properly diagnose a damn thing on a Turbo car if you haven't first ruled out any and all leaks (even pinhole leaks) in the entire intake tract; including but not limited to...
    All intake plumbing
    EVERY vacuum line
    Intake manifold
    Injector seals
    Etc.. etc..
    http://forums.vwvortex.com/showthread.php?t=2692757
    From the 1.8t technical forum, but applicable to ALL Turbo cars.
  35. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    05-02-2012 12:12 AM #105
    Quote Originally Posted by dubinsincuwereindiapers View Post
    This..
    All intake plumbing
    EVERY vacuum line
    Intake manifold
    Injector seals
    Etc.. etc..
    My tester thing hasn't come in yet, I ordered one from turboboostleaktesters.com I don't know where else it could leak, but I will obviously make good use of the tool.
    When the car idle's like that the vac bounces between 2-1...lol Then obv when it stalls it hits 0. I don't know how many times I have to check all the couplers and pipes / lines...because I put the car together and it was all good.
