VWVortex.com - 2009 cc fuel issues
    Results 1 to 18 of 18
    Thread: 2009 cc fuel issues
    1. 02-04-2012 07:48 PM #1
      i have a 2009 cc with 56k and i recently was driving the car and it completly shut off. i tried to start it and the car was acting like it had no gas. finally 10 mins later it turned on and ran. the check engine light came on and the codes where
      12355 fuel pump mechanical malfunction p3043 intermittent
      00135 fuel rail/system pressure too low p0087 intermittent
      12356 fuel pump short circuit p3044 intermittent
      i replaced the fuel pump located under the back seat and im still having the same issue. what is it??
      Dec 1st, 2009
      2012 CC DSG, 2001 Corvette 6MT Z51, 2010 Audi S4 6MT
      02-04-2012 09:18 PM #2
      It sounds like you have a problem with the mechanical high presure fuel pump, which is mounted on the engine, on the end of the head, near the battery. Or the pressure sensor on the high pressure fuel rail is defective.
    3. 02-05-2012 01:43 PM #3
      thanks. i will try both of those tomorrow and let you know.
    4. Member EngTech1's Avatar
      Nov 30th, 2008
      Easten - TN
      2015 CC, V50 Volvo , T-Bird - Gone , MG - Gone , Volvo 122s , Volvo 144 , Volvo 242 , 245 GL
      02-05-2012 03:11 PM #4
      It's the sensor on High pressure fuel rail is Going .
      Also don't start wit the $1800.00 worth of High Pressure Fuel Pump : OMG
      I'll do My Best to Help You: ** Fall Sale is On ! ** -
    5. Member Tucci's Avatar
      Feb 2nd, 2005
      Oakwood GA
      TDI Golf
      02-05-2012 03:58 PM #5
      You have a 5 year or 60k miles Powertrain Warranty from VW.
      Fuel system should be considered part of the Powertrain as its Chain Driven on the CC. call you local VW dealer.
    6. 02-07-2012 08:59 PM #6
      i replaced the sensor on the high presure fuel line and still the car wont start. what now??
      Dec 1st, 2009
      02-08-2012 11:24 AM #7
      Check the connector and wiring to the fuel pressure control solinoid (part of the high presure fuel pump). If the connector and wires seem OK, pull the connector off and measure the resistance of the two pins on the pump. It should measure somewhere between 25 and 35 ohms. The solinoid might be open or shorted.
    8. 02-08-2012 06:27 PM #8
      Samething happened to me they ended up replacing the entire fuel pump. Problems was solved
    9. 08-06-2012 12:38 PM #9
      Quote Originally Posted by wcp12 View Post
      I have the same model as yours with the same problem same fault codes, the Authorized Dealer can't seem to figure out whats causing it, they opened up a case help tech line with volkswagen and submitted all the data to Volkswagen Tech Support and so far nothing, not even Volkswagen can't figure it out, I was wondering did you get a solution for your problem?
      DirecTech
    10. n00b
      Feb 23rd, 2012
      San Francisco, CA
      08-06-2012 01:28 PM #10
      I had the same issue. The dealer replaced the fuel pump and that didn't fix it. They figured out it was the fuel pump relay.
    11. Member sdezego's Avatar
      Apr 23rd, 2004
      Hurricane Central FL
      '90 Corrado | '62 Harley Panhead
      06-25-2013 10:16 PM #11
      Back from the dead... Same codes on my wife's CC that left her stranded today. 86k on the clock.
      The other code that I had in addition to what was posted is:
      004506 - Fuel Pressure Sensor (G247)
      P119a - Malfunctions - Intermittent
      Fault Frequency = 1
      on P3043 Fault Freq = 5 as well as P0087 (Rail Pressure)
      ..sigh ...Time to Start digging
    12. 09-26-2013 10:53 PM #12
      What the heck is going on with these codes, I have the same codes on my 09 VW CC P3043: Fuel Pump Mechanical Failure, P0087 : Fuel Rail Pressure Too Low, P3044: Fuel Pump Short Circuit, My car looks like its on the showroom floor, but id rather be driving it than it sitting in the garage , its over an $800.00 repair job that should not be, I traded in a 98 Honda Accord with way more mileage that this and it drove like a charm, I want back my Honda,or VW needs to recall and repair this lemon cause I cant make lemon aide!!!!!!!
    13. Member piperpilot964's Avatar
      Aug 24th, 2009
      CT, USA
      2009 CC Sport, Candy White
      09-27-2013 01:22 PM #13
      I'd swap the relay first since it is easy (may be able to swap with a know good one on the panel to test), then the sensor, then the pump. Pump is about a $300 part and maybe an hour to replace.
    14. 11-04-2013 11:48 PM #14
      I will start the trouble shooting now that I know where to start, My CC has been in the Garage for over 2 months,will the Relay give all the P-codes ?
    15. 11-04-2013 11:49 PM #15
    16. 10-08-2015 03:14 PM #16
      how did you fix the problem ?
      relay , sensor or fuel pump ?
      what did you change ?
      thanks
    17. Member kbad's Avatar
      May 26th, 2007
      southlake, TX
      2010 CC 2.0T DSG Sport - Past VWs: 06 Passat 2.0T, 95 GLI, 87 Jetta Cpe, 80 Golf Cpe
      10-09-2015 09:47 AM #17
      Hey Milefff .. Most often, if it's not the hpfp/module (mounted on the engine), then it's the lpfp/module (mounted under rear seat behind driver) .. Supposedly, if the lpfp gets too hot, because the fuel is below 1/4 tank and/or hot outside, it fries the sensor module - initially acting quirky and eventually frying out .. Good luck!
    18. Member
      Dec 1st, 2009
      10-09-2015 12:47 PM #18
      Very likely is the Control Module for the Low Pressure Fuel Pump. $125 and 30 minutes of your time to plug a new one in. I don't think the HPFP (High Pressure Fuel Pump) fails that often (it did on the old Gen-1 (EA113) FSI engine).
      http://shopdap.com/2-0t-fsi-vw-and-a...ontrol-module/
