#36
NICE..i wanted to do them myself but i didn't get enough info on it in time..i like to save money and get the experience out of it..if i had the time i would have tried to watch a lot of the process while RSW is doing the work..but i have some other things to do on the car while the motor is out..
#38
more progress today..Little by little it will all come together..
#39
pulled the ECU today so i can take it and get flashed at RSW when i pick up the motor..thats about all though..decided to take a little break today..have to run around and pick up a couple of last minute things tomorrow..as much as i love working on it i can't wait until its done..want to see what the car transforms into, kinda forgot the power of an upgraded turbo kit..
on another note, got a ride in my friends TT-RS yesterday..ithat car...tune, intake and exhaust and that car would be beast..i just wish our cars would have the same type of intake manifold it has..i really don't like the plastic one..
#40
Can't wait for this monster to be done...thanks for all the time and work you're putting into this![]()
09 CW GTI - APR Stage III, APR FMIC, APR RSC Exhaust, APR Carbonio Intake, BFI Mounts
#42
VagPuncher, are you a trained mechanic or mechanical engineer.
Just asking because this is some extreme work for a home garage.![]()
#44
██████████████████Originally Posted by Jeremy Clarkson
#45
#46
#50
11.53@121.18
#53
got my motor back tonight..only rods as pistons couldn't happen at this time..i will be working hard tomorrow to try and have her running by the night time...will update tomorrow..
#55
#56
11.53@121.18
#57
i have a motor again..didn't work on it for as long as i would have liked today but i got a hell of a lot accomplished in the time that i did...
#60
#63
she's running..just need to finish up the exhaust and rear suspension then put her front bumper for test drives...only problem is i have a party to go to in a couple of hours..looks like tomorrow will be 100%...
#64
#66
#67
#68
11.53@121.18
#69
2011 GTI / APR K04-Carbonio stg1/2 intake-APR catted dp-Magnaflow catback-APR intercooler-Audi S3 shifter-Podi boost tap/boost gauge-034 Motorsports engine/trans mounts (street density)-DXD stg2 daily-H&R coilovers-APR 27mm rear swaybar/Whiteline adj. end links-vcds coding tweeks-Tinted oem tails-HPA 6 piston bbk/80a subframe mount
Follow on instagram @glfsprtct1
#70
A turbo with 3100 miles on it had bent rotor fins?
In any case, damn guys you are brave for tearing apart a brand new car.![]()
