Results 1 to 13 of 13
Thread: maybe this is dumb question...alot of toe out wen aired out
  1. Member bsA41.8T's Avatar
    Feb 15th, 2004
    harrisburg, PA
    mk4 Jetta wagon on grids~08 GLI DSG on flakes
    02-06-2012 12:07 AM #1
    is there any way correcting this some? wen im aired out the front toe out alot and the front fenders rite by the fender basically sit on the tires while the top of the tires tuck...is it just nature of the beast or is there a fix for this?
    Barry
    From a bagged and boosted 550hp to a Jetta wagon 2.0...sucks growing up
  2. Member VEE-DUBBER's Avatar
    Nov 22nd, 2000
    Renton, WA
    91 Turbo Miata, 95 GTI VR6, 96 Jetta VR6
    02-06-2012 12:12 AM #2
    Get an alignment at a lower regular drive height. That's all you can do
  3. Member bsA41.8T's Avatar
    Feb 15th, 2004
    harrisburg, PA
    02-06-2012 12:22 AM #3
    ok thanx...dont know why i didnt think of that to help it..hahah
    Barry
  4. 02-06-2012 08:20 AM #4
    Quote Originally Posted by bsA41.8T View Post
    That's because when you air out, you angle the lower control arms way past their design range and the bump steer (toe pattern) goes to toe out as the wheels move back to positive camber.
    Just make sure you align the car at your chosen drive height. The slammed alignment is irrelevant as you can't even roll there!
    Brian@AirLift
    Engineer Dude
    http://airliftperformance.com/
  5. Member bsA41.8T's Avatar
    Feb 15th, 2004
    harrisburg, PA
    02-06-2012 08:50 AM #5
    ok thats wut i figured but i thought it couldnt hurt to ask
    another question....on the a-arms where the ball joint slots are...is it better to have them all the way out or all the way in???
    this is mk4 btw
    Barry
  6. 02-06-2012 08:53 AM #6
    this is mk4 btw
    You lose negative camber after a certain point of lowering so with the Slam kit, pull them out al teh way for maximum negative camber and set toe at your ride height.
    Brian@AirLift
    Engineer Dude
  7. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    South Burlington, VT
    335i
    02-06-2012 10:18 AM #7
    Quote Originally Posted by VEE-DUBBER View Post
    Exactly, if your aligned height is lower, you won't have as much toe out when you air it out .
    - Call us at: 802 . 735 . 2574 - Email us at: sales@bagriders.com - - // - - We're open: Monday - Friday 9:00 - 5:00 Eastern -
  8. Member 20thGTI12's Avatar
    Feb 17th, 2005
    Chicago, IL
    03' VW 20th AE GTI
    02-06-2012 09:25 PM #8
    Quote Originally Posted by Brian@AirLift View Post
    How do you set the toe on front r32 suspension?
  9. 05-09-2012 12:30 AM #9
    Quote Originally Posted by 20thGTI12 View Post
    2x
    Quote, originally posted by GrayGTI05 »
    the R is probably the best sounding 6cyl car out there...and the e46 m3 sounds like a wookie getting raped inside of a tin can...
    STAY CLASSY...
  10. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    05-09-2012 01:11 AM #10
    Adjust the tie rods like any regular mk4?
  11. Member Lawn_Mower's Avatar
    Jul 15th, 2008
    Mooresville, NC
    06 GTI
    05-09-2012 04:44 PM #11
    Quote Originally Posted by MechEngg View Post
    Adjust the tie rods like any regular car?
    fixed that for you.
    Lower-IT
    // DROP // DRAG // DESTROY
    OpenRoadTuning
  12. Member bboy_jon's Avatar
    Jan 19th, 2010
    Columbia, MO
    2002 1.8t GTI
    05-10-2012 08:03 PM #12
    lol, I was wondering the same thing. I got an alignment at my ride height but dam, it toes out quite a bit
  13. 05-10-2012 08:46 PM #13
    well my question is what can you do when ur running a -5.5 camber in the back on an .:R when ur on ur lower drive height and ur fkn toe in the rear is at +1.. lol I have lower camber arms and just orderd upper ones to get my toe as close as possible to zero.. will c if that helps..
    STAY CLASSY...
