Results 1 to 3 of 3
Thread: WM injection def helps.
  1. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
    02-06-2012 01:55 AM #1
    82*F, 93 octane tune selected, 93 in the tank. Mod list in sig.
    I see a normal boost spike, but then it dips... odd. Tune related? My fuel rail looks great, timing looks great with WM... everything looks to be healthy, except the boost and timing without WM.
    Anyways, Ill be doing some dyno time in the next week or so, with updated logs comprising of different mixes used for injection, including something a little special.
    2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
  2. Junior Member
    Apr 22nd, 2010
    UK
    2001 Audi TT Quattro
    02-15-2012 02:52 PM #2
    Hey Krieger
    Always love graphs n stuff. I take it the boost graphs are from the MAP sensor, so you're running about 1.3 bar peak. What sort of power does that translate to?
  3. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    02-15-2012 07:16 PM #3
    sorry, i didnt bother to translate the boost. pretty much my tune is requesting like 15 psi peak, 10psi at redline, I spike like 17 and follow requested till redline.
