VWVortex.com - Disabling the Haldex - MK5 R32 DSG
    Results 1 to 4 of 4
    Thread: Disabling the Haldex - MK5 R32 DSG
    1. Member sixteen10's Avatar
      Nov 16th, 2008
      South Africa
      2007 Audi 8P S3
      02-06-2012 05:59 AM #1
      Hi All
      Is there anyway I can disable the Haldex on my mk5 R32 to run it on a FWD dyno?
      I have heard that the mk4's were as easy as removing a fuse , could the mk5 be the same?
      If so could you please refer me to the right fuse?
      TIA
      Grant
    2. Senior Member TBT-Syncro's Avatar
      Apr 28th, 2001
      Vancouver
      92 VR-T syncro GTI, 2011 husaberg FS570, 2014 Aprilia Tuono V4 APRC
      02-09-2012 10:12 PM #2
      pull e-brake or fuse worked on mk4. I'd assume same on mk5. easy enough to test.
    3. Junior Member matteeee's Avatar
      Feb 8th, 2010
      Sweden
      2010 VW Scirocco 1.4TSI 160bhp DSG7
      03-05-2012 02:40 PM #3
      Pulling e-brake and fuse works well enough, but the Haldex will rotate at full speed disengaged, making the oil overheat. Might not be any problems, but I wouldnt risk it..
      Only really good way to do it is to remove the cardan axle or find a 4wd dyno...
    4. Member 2fast4you2's Avatar
      Feb 21st, 2009
      Skopje Macedonia
      Audi A3 8L 3.2 DSG, Golf rallye, golf 6 TFSI
      04-22-2012 05:15 PM #4
      Pull out Fuse 31 I think
      TUNINGGARAGE
      REVO TECHNIK
