Results 1 to 21 of 21
Thread: AFP (MK4 VR6) intake manifold swap/info/pics/DIY/ect?
  1. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    :faceplam: :beer: :thumbup:
    buncha junk
    02-06-2012 09:29 PM #1
    I am looking for more information on the MK4 AFP VR6 intake manifold swap on a MK3 AAA motor using MK3 wiring/ECU. I've been searching around for a while, and havent come across too much beside a bunch of bickering about how its a waste of time and money & ive only found a few decent pics of it....
    From the looks of it, an OBD2 throttle body fits (upside down) if you run a cable guide.
    as for the "shifter" in the manifold, it appears to be vacuum controlled via the same line as the FPR and it operates the same way as a Schrick VGI manifold.
    Schrick -
    vs.
    AFP -
    #6 - flap acutator
    #27 - solenoid
    #23 - vacuum reservoir
    and use an RPM switch as the control device to control the solenoid.
    Something like this -
    http://www.summitracing.com/parts/SUM-830449-1/?rtype=1
    I was wondering if anybody in MK3 land has done this beside the one car I've seen?
    Crooked Euros | Low is NOT a lifestyle | Slow & Quiet
    WTB - 04.5 GLI REAR VALANCE
    Pennsylvania Volkswagen Owners & Enthusiasts Page
    O/R/T
    We Do It Big In PA
  2. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    Mk2 GTI VR6... .......................Mk5 Rabbit 2.5
    02-06-2012 10:47 PM #2
    In for answers although I have no real interest in swapping myself
    /// VRSociety Member #298 /// Mk2 Milita-VR6 Battalion-2dr Regiment /// Instagram @scottyvr6 ///
    My 2.9L BVH build and the machine shop #%@- up that almost ruined it all.
    Jul 9th, 2009
    Dirty jerz
    looking
    02-06-2012 11:07 PM #3
    reason to swapping to a mk4 mani? i would think for the cost/effort it would be easier to go SRI or 2.9 clone
    Quote Originally Posted by Down_N_Out View Post
    I see OEM+ in your future
    I felt a disturbance in the force, and I'm here.
    VRalliance #6
  4. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    02-07-2012 01:11 AM #4
    Cheaper to do the AFP manifold.
    TTT
    O/R/T
    We Do It Big In PA
  5. 02-07-2012 03:57 AM #5
    Hi,
    AFP manifold has equal runner lenghts. This is because VR runner lenght compensation is build/made in the camshafts design, i.e rear and front cams have different (actually opposite symetrical ) phases and valve strokes. AAA engine cams have similar cam profiles but different inlet runner lenghts(compensated). So, the conclusion is AFP manifold should go with AFP cams.
    Just FYI
  6. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    02-07-2012 11:39 AM #6
    I understand that. I plan on swapping in a complete AFP motor into my car to replace the current AAA motor with 2 spun rod bearings.
    I have the opportunity to purchase a complete motor for next to nothing.
    O/R/T
    We Do It Big In PA
  7. Member Grabbit's Avatar
    Apr 27th, 2001
    SEA128021
    Mk1, Mk2
    02-08-2012 04:09 AM #7
    Bump for steveo, I'm looking to do this, It seems like a complete manifold swap, cams and even a head gasket/ valve job would be as much as a used shrick manifold.
    for more torque and streetability
  8. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    02-08-2012 12:57 PM #8
    O/R/T
    We Do It Big In PA
  9. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    02-09-2012 02:35 AM #9
    anyone else?
    AAA dyno curve -
    AFP dyno curve (stock in blue. catback exhaust in red) -
    the AFP produces more low end torque, but how much of this is attributed to the manifold/cams vs MK4 ECU?
    O/R/T
    We Do It Big In PA
  10. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    02-13-2012 02:25 AM #10
    O/R/T
    We Do It Big In PA
  11. Member Ultramagnus0001's Avatar
    Jun 21st, 2006
    Allentown, PA
    2001 Gti VR6
    02-13-2012 01:32 PM #11
    When the change over flap in the manifold stopped working on my AFP, it felt like I loaded the car up with fat people and then it would come back on like a turbo after 4000 so RPMs.
    You can get a smooth, quiet, floaty car and fall asleep waiting to get from point A to B, or enjoy getting there.
    To be good at racing, you have to change your name to Sebastien.
  12. Member GTIVRon's Avatar
    Jul 24th, 2009
    Keller, Texas
    92 Corrado SLC, '12 Golf R
    02-13-2012 02:01 PM #12
    You can clearly see the effect it has a 4200 RPM. Notice how the Torque curve seems to start plummeting at 4K then levels back out again before dipping around 4200.
    Coming from a 24v to my dizzy VR6 that loss is terribly noticeable. I'm also interested in this. Except I won't be doing an engine swap or OBD2 conversion.
    2002.5 Jetta 1.8T - TOTALED (dodging deer)
    2002.5 24v GTI - TOTALED (rear-ended by a Jeep)
    1992 Corrado SLC - The toy & DD
    2012 Golf R - The weekender
  13. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    02-13-2012 03:45 PM #13
    funny you mention dizzy VR.. that is what is currently in my MK4 that i plan on changin out..
    O/R/T
    We Do It Big In PA
  14. Member Grabbit's Avatar
    Apr 27th, 2001
    SEA128021
    Mk1, Mk2
    02-15-2012 11:16 AM #14
    anyone know if a mk3 OBDII TB will work or if not if a MK4 TB will plug in/adapt/work with OBDII?
  15. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    02-15-2012 12:21 PM #15
    The first 2 pictures posted looks to be a MK3 OBD2 throttle body
    O/R/T
    We Do It Big In PA
  16. Member GTIVRon's Avatar
    Jul 24th, 2009
    Keller, Texas
    03-16-2012 09:12 AM #16
    Any updates on this? Have you taken a crack at it?
  17. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    03-17-2012 10:38 AM #17
    Nothing yet. Been WAY too busy with work and other stuff.
    O/R/T
    We Do It Big In PA
  18. Member 93wolfsburg's Avatar
    Feb 22nd, 2003
    1992 Corrado SLC, 2001 Jetta VR6, 2011 LEAF SL, 2012 Titan PRO4X
    04-08-2013 12:13 PM #18
    I am working on doing this same thing on my corrado, for me its more about aesthetics and the fact that i'm going vrt it would be easier for me to have the inlet on the drivers side.
    I have concerns about the fuel injection. I dont really know a whole lot about injectors that fit in a stock mk4 manifold other than they look much different than the bosch style ones from the AAA motor.
    Does anyone know if they will work with a mk3 obd2 ecu? If not will the bosch style fit in their place?
  19. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    buncha junk
    04-08-2013 01:00 PM #19
    Nothing. Sorry, never went through with this as I got bored with the car.
    The research I did pointed me towards swapping all the MK4 stuff in and using the MK4 ECU
    O/R/T
    We Do It Big In PA
  20. Member 93wolfsburg's Avatar
    Feb 22nd, 2003
    04-08-2013 02:02 PM #20
    Interesting. I'll have to check tonight to see if the mk4 injectors are high or low impedance. I would imagine as long as both are the same impedance and flow the same rate it wouldnt matter what engine management.
    Just curious how were you planning on sealing off what i guess is air injection on the lower half of the intake manfiold? Just a plug and a clamp?
  21. Member 93wolfsburg's Avatar
    Feb 22nd, 2003
    04-08-2013 09:19 PM #21
    so i ohm'ed out the mk4 and mk3 injectors they were 15.5 and 15 respectively. I think its safe to say we can interchange them i'm not sure about the flow rate though does anyone know the flow rates on stock injectors?
    I guess in my case i'll just get whatever (mk4) injectors my software requires
