Results 1 to 8 of 8
Thread: 02C short shifter options?
  1. Member 92VW's Avatar
    Nov 25th, 2005
    fairfax
    04 TDI Jetta, 08 V8 Touareg, 86 Syncro Golf
    02-07-2012 03:34 PM #1
    the entire gear selector shaft needs replacement. anyone know of a short shifter option? or do i need to visit the dealer?
  2. Member polov8's Avatar
    Apr 14th, 2004
    United kingdom of Awesomecestershire
    '80 Scirocco Storm, '79 Scirocco, '01 BMW E39 530D
    02-08-2012 05:53 PM #2
    Can't help you with specific parts, but in shifter terms, what fits 02A fits 02C
  3. Member efritsch's Avatar
    Aug 21st, 2002
    Kitchener
    1992 Passat Syncro Wagon, 1987 Fox Wagon (Project)
    03-08-2012 11:19 PM #3
    Quote Originally Posted by polov8 View Post
    Not true!
    The differentials are different, the right side axles are different and the shift towers on the transmissions are different. The internal selectors are the same in the transmissions and I would assume (but don't know for sure) that the box in the car is same.
    TMTuning.com sells a short shifter kit for a B3/35i but I don't know if it will adapt to a 02C transmission.
    Quote Originally Posted by 90quattrocoupe
    I am old enough that I only have to be nice when I want to.
  4. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    03-10-2012 03:40 AM #4
    Quote Originally Posted by efritsch View Post
    Not true!
    there is nothing unique about the 02c shift tower. it's just a regular 02a/02j one.
    (i'm currently running a new revision o2j one on my 02c)
  5. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    03-10-2012 03:41 AM #5
    as for short shifter. most 02a ones wont work, as the shift box in the passat is shallower to allow for the elevated tunnel). although i'm sure you could make one work by modifying the shift box.
  6. Member
    May 26th, 2007
    Kelowna Britsh Columbia
    03-11-2012 12:44 PM #6
    Just converted my syncro rabbit to the newer o2j shifter feels so much better now then the o2a/02c setup.
  7. Member turbomustang's Avatar
    May 22nd, 2004
    Regina Saskatchewan Canada
    02 S4, 97 A4, 88 T76 Mustang
    03-22-2012 11:54 PM #7
    Dude he said in shifter terms. Not running gear. Chill.
  8. Member d-bot's Avatar
    Sep 6th, 2004
    Par 5 from the Space Needle, PNW.
    80 Storm 20vSC Syncro, 93 Corrado VR6
    04-05-2012 01:27 PM #8
    Also running an 02J shift box and tower in the 02C here as well. Diesel Geek makes a great short shift kit for this tower.
