Results 1 to 14 of 14
Thread: Rare 1991 Galant VR4 (DSM 1g) Fully built motor 30rDBB & much more.... - $7900 (RI)
    Oct 9th, 2010
    Rhode Island
    02-08-2012 01:14 PM #1
    Posting for a friend:
    Up for sale is my beloved 4yr project. I bought this car to replace my 04 WRX and be car payment free. That quickly got out of control and it become a toy only. I have a folder FILLED with receipts(90% of items) totalling $12000. This does not include the car, the time and things like tuning.
    I'm firm at $7900 which is a steal for what you are getting. I am 100% confident this car can be driven ANYWHERE in the conutry without a hiccup! I also will entertain offers with some parts removed to reduce cost....
    PM or text/call cell:401-932-8528 .
    She does have som small body items that if the car is kept, will be addressed in the spring.
    -2 small rust spots around windshield quarter and dime size
    -Rear quarter infront of the p/s taillight has a smal scrap/dent
    -d/s rear door has a 10" crease
    Bought:11/07
    Year:1991
    Number:381/2000
    Current Mileage:100,400 and counting..... as of rt now.
    Mileage on build:7,220
    1/4 time: TBD
    WHP: 430awhp
    Members rides PICS: http://www.galantvr4.org/ubbthreads/...page=1&fpart=1
    BUILD THREAD: http://www.galantvr4.org/ubbthreads/...page=1&fpart=1
    Engine: click
    Built bottom end
    -Wiesco 9.0:1 .20 over pistons
    -Eagle rods
    -Polished unground crank
    -B/S eliminated
    -Balanced to 10K
    -Fluidamper balancer
    Built Head
    -Mildly ported head by myself
    -Manley springs/retainers/keepers
    -Ferrea valves with 3-angle
    -BC272's
    -3g lifters
    -Mitsu MLS headgasket
    -Hondata intake gasket($.99 on epay)
    -ARP Mains, headstuds, crank bolt, exhaust studs, rod bolts, turbo bolts
    -New Mitsu oil pump/cover, mitsu waterpump, new mitsu tensioner, idle pulleys, new waterpump/oil pump cover/tensionor hardware click
    -90' OFH, -8an lines, B&M 11x6 cooler
    -New oilpan, knock sensor, ALL GASKETS/SEALS
    -Drilled and filled motor mounts
    -NGK spark plugs
    -NGK spark plug wires
    -New oem 1g dipstick with modified tube with spring
    Turbo:
    -Garrett GT3076R in EVOIII exhaust housing
    -35mm internal wastgate
    -Stainless braided oil feed from head
    -Stock oil return
    -Custom -6AN ss water feed line and return
    Intake:
    -Rebuilt VR4 throttle body
    -2g t/b elbow
    -2g MAF
    -4" FP recirc intake pipe
    -K&N filter
    -Custom short route Aluminum 2.5" intercooler piping.
    -Spearco intercooler with custom endtanks (core size - 24 x 9 x 4)
    -Oil catchcan
    -Crushed oem NIB BOV
    Exhaust:
    -2g ported exhaust manifold
    -2g manifold heat shield and modified o2 shield
    -ARP Stainless exhaust manifold studs
    -2.5" to 3" mild steel downpipe
    -3" mild steel bent catback with Borla single tip muffler click
    -Catco 3" high flow cat
    -EvoIII ported o2 housing
    -RRE/Indy Race Cores Aluminum Radiator GVR4 specific
    Electronics:
    -Evo8 ecu
    -Black Top CAS
    -Greddy electronic Boost, EGT and memory/warning oil pressure
    -NIB Greddy Profec B spec (original from 95)
    -Dual stage turbo timer
    -NEW Bosch 90amp alternator(original receipt with lifetime warranty)
    Fuel system:
    -Rewired Supra TT fuel pump
    -Aeromotive AFPR
    -SS -6an lines from filter to rail, from rail to afpr and from fpr to return.
    -750cc FIC injectors
    Drivetrain:
    -Rebuilt TRE trans dual syncs in 2-3, filter, new forks, bearings, seals, rails
    -Redline MT-90
    -New front axles
    -2g shift fork and throwout bearing upgrade
    -ACT 2600
    -ACT Flywheel
    -Stainless braided clutch line
    -DSM 5-lug conversion with all new bearing, seals and dust shields
    -4bolt LSD rear end w/ AWS click
    -Restored rear subframe. Complete sandblast and Eastwood products click
    -Restored lines, rear rack, rear pump, dist block
    -Rebuilt driveshaft with FM u-joints and new carrier
    Suspension:
    -Tein HR coilovers with front camber/pillow and rear pillow mounts
    -Ingalls adjustable rear upper control arms
    -DSM front and rear adjustable strut tower bars
    -New rear sway bar end
    Brakes:
    -Front- 94+ 3kgt 4 pot calipers with 12.65" dual vented rotors, stock pads
    -TunerNation(GW) caliper brackets
    -Rear - Stock calipers on DSM 5 lug rotor
    -Complete ABS removed and swapped for 1g non abs lines and proportioning valve
    -SS brake lines
    Wheels/tires:
    - 17" EVO 9 Enkei Wheels
    - 235/40/17 Azenis
    Interior:
    -EVO MR SE gas, clutch and brake pedals with WRX dead pedal
    click
    -1989 Light weight underdash with pocket
    -Starion OPEN headrests in black leather click
    -Sony Explod Black out CD player
    -Double DIN carbon fiber plate for radio, Greddy oil pressure, boost and egt gauges
    -"MITSU" 1g leather steering wheel
    -2g DSM shift knob
    click
    -Leather shift boot
    -1g DSM EXTREME PSI short shifter
    -Paint removed from cluster needles, repainted red on tach and temp gauge
    -Moroso NHRA legal sealed battery box click
    -Custom TURBOFLANAGAN numbered floor mats click
    Exterior:
    -JDM vented RS hood
    -Eterna grill
    -MMC VR4 trunk badges(removed Galant, DOHC and MITSUBISHI emblems) click
    -OEM Mudflaps click
    -JDM Eterna Grill
    -93 crystal headlights
    -Amber corners with signal and parking light
    -Tinted tail lights
    -Complete Rubberized undercoating to entire underside including under skitrs, doglegs and wheel wells click click
    Again, I'm in no rush but would like to payoff a CC before I dive back into the car payment world!
    Thanks, Russ. Text:401-932-8528 or email ston2099@yahoo.com replies plz
    Aug 21st, 2005
    Manchester NH
    92 bucketVR 03variantYAWN
    02-08-2012 08:43 PM #2
    OH MAN!
    i love these cars!
    good luck with the sale! i wish i was buying it
    Oct 9th, 2010
    Rhode Island
    02-10-2012 07:11 AM #3
    Oct 9th, 2010
    Rhode Island
    02-12-2012 07:33 PM #4
    You buy now!
  5. Member themagellan's Avatar
    Mar 30th, 2007
    NorthShore, MA
    1991 Audi 200 20vt Quattro
    02-12-2012 07:45 PM #5
    Cool car man, a friend up here is almost done building his. He has slowly made me appreciate all things mitsu....
    Oct 9th, 2010
    Rhode Island
    02-14-2012 09:48 PM #6
    Yea, these cars are pretty cool. This car in particular handles amazing!!!!
    Oct 9th, 2010
    Rhode Island
    02-16-2012 09:35 AM #7
    Oct 9th, 2010
    Rhode Island
    02-17-2012 02:48 PM #8
  9. Geriatric Member Chapel's Avatar
    Jun 23rd, 1999
    New England
    '97 BMW 328i | '10 Mazda5
    02-20-2012 09:50 PM #9
    jeez, that's a fantastic price
    Oct 9th, 2010
    Rhode Island
    02-23-2012 05:16 PM #10
    Oct 9th, 2010
    Rhode Island
    03-10-2012 06:27 PM #11
  12. Member DieGTi's Avatar
    Jun 19th, 2001
    Manchester, NH
    1990 Jetta 12v VR6T; 98 Audi A4 30v QS, 74 911
    03-12-2012 09:45 PM #12
    You buy this from a guy in CT? Sold mine in 2004 to a college buddy who was an engineer and sunk a pile of cash into before selling it himself. Can't remember what # it was off the top of my head.
  13. Member
    Oct 9th, 2010
    Rhode Island
    03-12-2012 10:20 PM #13
    I honestly don't know much about since i'm posting for a friend. He is from CT and he did throw tons of money on it. fully built motor and all with a buddy of his who owned momentum tuning? in CT.
  14. Member
    Oct 9th, 2010
    Rhode Island
    04-05-2012 11:14 AM #14
    SOLD
