VWVortex.com - My Mark 4 Airride Build...
    Page 3 of 18 FirstFirst 123456713 ... LastLast
    Results 51 to 75 of 445
    Thread: My Mark 4 Airride Build...
    1. Member Chaoz's Avatar
      May 30th, 2008
      READING,PA
      SLAM.TUCK.POKE.DOPE.
      02-09-2012 04:34 PM #51
      Quote Originally Posted by Twilliams83 View Post
      You will be fine. You will get used to the noise. If you can afford it though it will be better. My dual 380's take about 2 and a half minutes to fill up from when they kick on.
      Hmm yea I think I may upgrade in a few months
      Swagga so nice i should notorize it
      instagram: @chaoz_
    2. Member _Dirty_'s Avatar
      Sep 30th, 2009
      Burlington, VT
      Pan Scraper
      02-09-2012 04:54 PM #52
      Quote Originally Posted by MechEngg View Post
      Personally I would go for the 3/8" SMC one. Just get the 3/8" and use a reducer coupling to mount it directly off the side of the tank.
      X2
      Exactly what I did without having mounted on the tank
    3. Banned
      Jan 18th, 2012
      CT
      bagged red ford lightening
      02-09-2012 05:11 PM #53
      5:11 compressor turned on from 0. One 400c filling a 5gallon tank to 175psi
    4. Banned
      Jan 18th, 2012
      CT
      02-09-2012 05:19 PM #54
      Hit 100 psi at 5:14. Filled by 5:18
    5. Member MechEngg's Avatar
      Jan 12th, 2009
      Calgary, AB
      02-09-2012 05:45 PM #55
      Sorry I don't know why you just didn't grab a stopwatch and time it. Timing it the way you did gives a super high variance of up to almost 2 minutes so its not that accurate.
    6. Banned
      Jan 18th, 2012
      CT
      02-09-2012 05:50 PM #56
      Oh I know. Just giving a general idea of how long it takes. Rather listen to music than fiddle with a stop watch on my phone.
    7. Member martin13's Avatar
      Apr 20th, 2010
      Calgary Alberta
      MK5 GTI, 73' 280SE
      02-09-2012 11:06 PM #57
      this also seems to be fairly accurate...
      http://www.landisusa.com/calculator.html
    8. Member Slamtastic's Avatar
      Jul 24th, 2010
      Calgary, Alberta
      02-09-2012 11:13 PM #58
      Quote Originally Posted by Shoopz View Post
      400c's are only rated for a max pressure of 150 psi. You might want to get a different pressure switch as it'll be putting excess wear on the compressor.
    9. Member MechEngg's Avatar
      Jan 12th, 2009
      Calgary, AB
      02-10-2012 02:05 AM #59
      If you are going to do something at all do it the right way, don't half a$$ it........
      Btw 3 Calgary posts in a row!
    10. Member martin13's Avatar
      Apr 20th, 2010
      Calgary Alberta
      MK5 GTI, 73' 280SE
      02-10-2012 03:43 AM #60
      Quote Originally Posted by dubbin18 View Post
      i ran my 400c no problems to 175 psi all last year
    11. Banned
      Jan 18th, 2012
      CT
      02-10-2012 09:09 AM #61
      Yeah next time I'm in the lab I'll do that.
      And as for running a 400c to 175. Almost everyone I know with air ride does this with no problems
    12. Banned jettaaddictionII's Avatar
      Sep 3rd, 2011
      MI
      2.0 twin turbo 9 speed jetta
      02-10-2012 12:22 PM #62
      my tank should be here today, and then once my check goes through, i ordering the rest!!
    13. Banned jettaaddictionII's Avatar
      Sep 3rd, 2011
      MI
      02-10-2012 01:06 PM #63
      pretty much the moment i typed that the ups guy showed up! what luck. got some pics, im officially pumped. The rest should be ordered on monday like i said above.
      pics.
      dont mind the dirty trunk, before now it didnt matter
      and im going to wait to build the frame and setup until my compressors and WTs come in, now that i decided to do dual compressors, the fitment is going to be real tight it looks like. Might have to bring it forward some, or possibly have it going vertical.
    14. Member Twilliams83's Avatar
      Jan 24th, 2011
      Wildomar, CA
      02-10-2012 07:58 PM #64
      are you keeping the spare? i kept my spare with dual compas and that was a challenge haha it should get interesting when i switch to v2 and have to put a manifold somewhere in there.
      ¯\_(ツ)_/¯
      My Flickr
      Instagram: @twilliams83
    15. Banned jettaaddictionII's Avatar
      Sep 3rd, 2011
      MI
      02-10-2012 08:34 PM #65
      idk, probably not. but we will see what room i have when done!
    16. Member Twilliams83's Avatar
      Jan 24th, 2011
      Wildomar, CA
      02-10-2012 09:54 PM #66
      Yeah jettas have big spare well's so you chould be able to keep it pretty easy. **steve** has his manifolds and ecu in the spare well behind the spare, but im not sure if the wagons have a bigger spare well.
      ¯\_(ツ)_/¯
      My Flickr
    17. Member ericshell's Avatar
      Dec 22nd, 2011
      SLO, CA
      20th, Golf R
      02-11-2012 08:34 PM #67
      whoa whoa whoa dean i didn't know you were bagging the jetta!! good luck man, ill be watching
    18. Banned jettaaddictionII's Avatar
      Sep 3rd, 2011
      MI
      02-12-2012 12:30 PM #68
      Quote Originally Posted by ericshell View Post
      eric. i have to, rs' and bags go together like pb and jelly
      and am ordering everything else tomorrow, pretty much.
      -bags
      -management
      -Wts
      -other fittings and drains
      and then ill order the comps. next week, sense i decided to go duals
    19. Member ericshell's Avatar
      Dec 22nd, 2011
      SLO, CA
      20th, Golf R
      02-12-2012 01:23 PM #69
      Nice! what management are you planning on going with? (sorry im too lazy to look up and read haha) Definitely 2 compressors are the way to go. It's so much more convenient and so much less of a hassle. Definitely worth the extra few bucks.
    20. Member Kiddie Rimzo's Avatar
      Feb 20th, 2008
      MD
      AP1
      02-12-2012 01:34 PM #70
      Quote Originally Posted by Chaoz View Post
      Yea but do you usually go from 0? I'll be running a 444
      id still definitely add another down the road. i hated the sound of my compressor
      the 444 is 100% duty cycle tho, so it doesnt really need time to cool down between use. if you got a compressor with a 33% duty cycle or something like that id be worried about only having 1
      I'm not a star. Somebody lied.
    21. Member Chaoz's Avatar
      May 30th, 2008
      READING,PA
      02-12-2012 01:46 PM #71
      Quote Originally Posted by Kiddie Rose View Post
      yea im still learning about all this lol but, yea i think ill start with just the one to see how it goes thanks sir.
      instagram: @chaoz_
    22. Banned jettaaddictionII's Avatar
      Sep 3rd, 2011
      MI
      02-12-2012 02:14 PM #72
      just good ol' basic manual management with paddle valaves. nothin to fancy
      yea, im probably going to go with either 2 400c's or 2 380c's. the price for them are practically the same.
    23. Member eastcoaststeeze's Avatar
      Jul 20th, 2009
      DE/CT
      XS650 Bobber, Dodge Ram 1500
      02-12-2012 06:40 PM #73
      Floss Filthy x Team Big Shark x Gengstout x VIP Modular
    24. Member MechEngg's Avatar
      Jan 12th, 2009
      Calgary, AB
      02-12-2012 06:55 PM #74
      Quote Originally Posted by jettaaddictionII View Post
      May i suggest 1 ob2 instead of a dual 400 or dual 380 setup?
    25. Member Twilliams83's Avatar
      Jan 24th, 2011
      Wildomar, CA
      02-12-2012 09:13 PM #75
      between 380's or 400's i would go with the 380's because of the duty cycle, 380's dont need cool down time. But like MechEng said about the ob2, i kinda wish i would have know better and got one.
      ¯\_(ツ)_/¯
      My Flickr
