VWVortex.com - My Mark 4 Airride Build...
    Page 4 of 18 FirstFirst 1234567814 ... LastLast
    Results 76 to 100 of 445
    Thread: My Mark 4 Airride Build...
    1. Banned jettaaddictionII's Avatar
      Sep 3rd, 2011
      MI
      2.0 twin turbo 9 speed jetta
      02-12-2012 09:29 PM #76
      Quote Originally Posted by eastcoaststeeze View Post
      hey sir
      Quote Originally Posted by MechEngg View Post
      May i suggest 1 ob2 instead of a dual 400 or dual 380 setup?
      one of those is more expensive then 2 of the other ones, either the 380s or 400s, and the the backup of the second will be alright.
      Quote Originally Posted by Twilliams83 View Post
      between 380's or 400's i would go with the 380's because of the duty cycle, 380's dont need cool down time. But like MechEng said about the ob2, i kinda wish i would have know better and got one.
      oh alright. i didnt know that, i just assumed the higher number, meant that it would be better, even though the 380 is 100% duty cycle, and the 400 is 33% duty cycle. Didnt kiddie rose say it would be better to run two of the 33% rather then one of the 100%??
    2. Member MechEngg's Avatar
      Jan 12th, 2009
      Calgary, AB
      02-12-2012 09:39 PM #77
      Just so everybody is aware here......
      Dual 380's
      Duty cycle: 100% @ 100psi
      Max pressure rating: 200psi
      CFM @ 100psi: 1.77
      CFM @ 150psi: 1.41
      CFM @ 200psi: 1.02
      Dual 400's
      Duty cycle: 33% @ 100psi
      Max pressure rating: 150psi
      CFM @ 100psi: 2.47
      CFM @ 150psi: 1.48
      CFM @ 200psi: NONE
      Dual 444's
      CFM @ 100psi: 2.12
      CFM @ 150psi: 1.62
      CFM @ 200psi: 1.13
      Dual 480's
      CFM @ 100psi: 2.08
      CFM @ 150psi: 1.55
      CFM @ 200psi: 1.17
      Single Air Zenith OB2
      Duty cycle: 100% @ 200psi
      CFM @ 100psi: 2.47
      CFM @ 150psi: 1.83
      CFM @ 200psi: 1.46
      Don't get deceived into thinking that a 444 has a 100% duty cycle at the pressures you will be running, it is only 100% duty cycle UP TO 100psi, after that it starts to drop off. The only compressor that is 100% duty cycle for our pressures that we are running (145, 175 or 200) is the OB2. Plus it only costs $50 more than a dual pack of anything else and is very similar in amperage draw compared to a dual pack and fills quicker and runs cooler. Zero downsides
    3. Member MechEngg's Avatar
      Jan 12th, 2009
      Calgary, AB
      02-12-2012 09:42 PM #78
      Quote Originally Posted by jettaaddictionII View Post
      I have never even heard of a failure on an ob2, but if it does fail the compressors are fully rebuildable piece by piece for a very reasonable price, compared to just throwing a viair away. Check above for more arguements
      And yes it is your vehicle, your choice completely
    4. Moderator kilimats's Avatar
      Mar 5th, 2006
      Vancouver, BC
      07 Passat Wagon 2.0T + 05 Jetta Wagon TDI
      02-12-2012 10:17 PM #79
      ^ damn this compressor looks amazing !
      I'll prob get that one when my VIAR 444c dies, wonder how much faster it will be, hopefully not louder !
      BIODiesel Powered | MKx Channel VW/Audi Videos United
      MKIV Forum User Guide | Forum Rules
      Quote Originally Posted by dele
      The guys on coils can pull off their own Airless pride thread cos they clearly are the underdogs in the air/static debate, kinda like the equality movement for women.
    5. Member Kiddie Rimzo's Avatar
      Feb 20th, 2008
      MD
      AP1
      02-12-2012 10:17 PM #80
      noooooooo. 100% duty all the way!
      I'm not a star. Somebody lied.
    6. Banned jettaaddictionII's Avatar
      Sep 3rd, 2011
      MI
      02-12-2012 10:23 PM #81
      Quote Originally Posted by Kiddie Rose View Post
      ok cool.i must have mis-understood what you wrote. my bad
    7. Banned jettaaddictionII's Avatar
      Sep 3rd, 2011
      MI
      02-12-2012 10:36 PM #82
      Quote Originally Posted by kilimats View Post
      it defiantly does, ill have to keep that in mind when im ready to get one hopefully next week. And that, the OB2 , id only have to run one of them, correct. rather then two of the 400c's?
      and.... everything ordered, other then the comps. which obviously im still deciding on.
      and, it would be soo cool if it came o tuesday, that being my birthday
    8. Member ericshell's Avatar
      Dec 22nd, 2011
      SLO, CA
      20th, Golf R
      02-12-2012 10:40 PM #83
      BOOMjohnson
      yes zeniths are the ****. I already had a vlair die out on me. When I get around to having a real job Ill upgrade to zeniths
    9. Banned jettaaddictionII's Avatar
      Sep 3rd, 2011
      MI
      02-12-2012 10:48 PM #84
      Quote Originally Posted by ericshell View Post
      BOOMjohnson
      oh really? thats good to know. Are you running dual comps?
    10. Member MechEngg's Avatar
      Jan 12th, 2009
      Calgary, AB
      02-12-2012 10:53 PM #85
      Yup you would only have to run 1 of those OB2's and they outperform ALL of the dual viair compressor packs by far and probably be more reliable also with a 2 year warranty
    11. Banned jettaaddictionII's Avatar
      Sep 3rd, 2011
      MI
      02-12-2012 11:00 PM #86
      that sounds like a plan.
    12. Moderator kilimats's Avatar
      Mar 5th, 2006
      Vancouver, BC
      02-13-2012 12:02 AM #87
      I don't understand how 1xOB2 could be faster than 2x444c, the CFM is almost the same
      Dual 444's
      CFM @ 100psi: 2.12
      CFM @ 150psi: 1.62
      CFM @ 200psi: 1.13
      CFM @ 100psi: 2.47
      CFM @ 150psi: 1.83
      CFM @ 200psi: 1.46
    13. Member ericshell's Avatar
      Dec 22nd, 2011
      SLO, CA
      20th, Golf R
      02-13-2012 12:08 AM #88
      I am running dual 400's right now. that was drastically better than the single on. I can't imagine what dual zeniths would be like.
    14. Member MechEngg's Avatar
      Jan 12th, 2009
      Calgary, AB
      02-13-2012 12:12 AM #89
      I had dual last summer, ill let you know how triple goes
    15. Banned jettaaddictionII's Avatar
      Sep 3rd, 2011
      MI
      02-13-2012 12:13 AM #90
      i just commented on your thread
    16. Member ericshell's Avatar
      Dec 22nd, 2011
      SLO, CA
      20th, Golf R
      02-13-2012 12:18 AM #91
      same haha! And yes! you should take a video for the fill cycle from empty and low with those!
    17. Member YNO WGN's Avatar
      May 27th, 2005
      Wine Country SoCal
      3x mk3, 2x mk2, 1x mk1, 1x mk4, 1x mk6, 1x e30
      02-13-2012 12:47 AM #92
      Parts4VW
      Instagram: @ynowgn
      My Timeline Thingy
    18. Banned jettaaddictionII's Avatar
      Sep 3rd, 2011
      MI
      02-13-2012 03:18 PM #93
    19. Member Chaoz's Avatar
      May 30th, 2008
      READING,PA
      SLAM.TUCK.POKE.DOPE.
      02-14-2012 09:32 PM #94
      i think we will be gettin our setups at the same time lol but, i keep hearin that im goin to need to run dual 444c's im lookin for another already lol
      Swagga so nice i should notorize it
      instagram: @chaoz_
    20. Member Twilliams83's Avatar
      Jan 24th, 2011
      Wildomar, CA
      02-14-2012 09:34 PM #95
      Quote Originally Posted by Chaoz View Post
      you dont "need" it. will it be a quicker fill, yeah but you will live with one.
      ¯\_(ツ)_/¯
      My Flickr
      Instagram: @twilliams83
    21. Member Chaoz's Avatar
      May 30th, 2008
      READING,PA
      02-14-2012 09:51 PM #96
      haha sorry yea thats what i meant. lol
      instagram: @chaoz_
    22. Member Twilliams83's Avatar
      Jan 24th, 2011
      Wildomar, CA
      02-14-2012 09:51 PM #97
      if i were you and you i would just get one ob2.
      ¯\_(ツ)_/¯
      My Flickr
    23. Member Chaoz's Avatar
      May 30th, 2008
      READING,PA
      02-14-2012 09:55 PM #98
      one ob2 is better than dual 444c's?
      instagram: @chaoz_
    24. Member Twilliams83's Avatar
      Jan 24th, 2011
      Wildomar, CA
      02-14-2012 10:05 PM #99
      i dont quite understand all the numbers that go into it, but from what i take from mecheng, yes.
      ¯\_(ツ)_/¯
      My Flickr
    25. Member Chaoz's Avatar
      May 30th, 2008
      READING,PA
      02-14-2012 10:36 PM #100
      ahhh well i wanna see how the 444c holds up for me at first. lol
      instagram: @chaoz_
