Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 102
Thread: New build adding FT04 etc. to my 1.8t powered Porsche 356 replica!
  1. 02-08-2012 03:30 PM #1
    Finally taking the plunge and upgrading my turbo to an FT04T setup. I will post progress here.
    Plans:
    Bug Doug at FT endlessly until I understand just what to get. Done.
    Order FT04 setup. Done.
    Order some Green Giants. Not done.
    Order an AWIC system. Done, got a 350HP kit from Frozen Boost on the way. It should fit.
    Decide on a local fabricator to redo some piping. Not found, any suggestions for the Olympia, WA area would be appreciated.
    Decide on how to tune and with what ECU. Choices in hand are the Bosch 3.8.3 already working in the car and supplied lightly chipped by Eurospec with the engine build in 2008, a spare ME7 box I have or a Megasquirt 2e system I have with a wideband innovate O2 sensor.
    more to come as I progress.
    Tomm
    Intermeccanica Porsche Convertible Roadster D replica built in 2008 with 911 suspension, brakes and transmission coupled to an AGU 1.8t with K03. Single side mount Audi S4 IC, 15PSI boost, DIY MBC, Forge DV, Perrin catch can. Corner balanced and dynoed by 034 Motorsports. 167 WHP / 170 TQ / 2300 lbs. Upgrade to T3 super60 turbo in process.
  2. Banned dubinsincuwereindiapers's Avatar
    Jan 16th, 2008
    InYourMom
    Bugatti Veyron
    02-08-2012 06:49 PM #2
    Go wideband me7
    Subscribed
  3. Member iTech's Avatar
    Dec 28th, 2008
    Here there and every where
    Satin Silver Turbo Vespa, Candy White 4 Door Whore
    02-08-2012 09:38 PM #3
    Exactly what he said.....we've done roughly 6 or 7 and also done them Mafless....really makes a fun little turbo set up.
    And please...feel free to pester Doug I do it weekly just to keep him on his toes.
    www.oeperftuning.com
    Eurodyne Software
    PAG parts turbo kits
    42DD Exhaust systems
  4. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    02-08-2012 09:49 PM #4
    Quote Originally Posted by iTech View Post
    LOL
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
  5. 02-09-2012 12:34 AM #5
    ordered green giants. Now the parts just have to arrive!
  6. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    1989 Helios GLI 1997 Mk3 ****box
    02-09-2012 03:20 AM #6
    Post some pics up of the car/swap when you get a chance.
  7. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    02-09-2012 08:11 AM #7
    Quote Originally Posted by Dave926 View Post
    this
  8. Member MrAkalin's Avatar
    Jan 3rd, 2011
    Ohio
    2002 VW GTI 1.8T
    02-09-2012 12:13 PM #8
    FrankenTurbo F21, CTS Frount mount, Genesis 550cc, Bosch 044, Wiseco pistons, IE Rods, all held together with ARP, 3" 42DD TBE, 2 quarts of my blood, Southbend Stage II, Peloquin LSD, taken care of with Eurodyne ME7.
    Contact Mike P. @ Stevebilt for anything you need.
    Quote Originally Posted by joemiller1989 View Post
    I was pooping when I read this I laughed so hard I couldn't stop pooping
  9. Member Zneith's Avatar
    Jan 4th, 2010
    East Greenville, Pennsylvania
    2001 Jetta 1.8 BT
    02-09-2012 12:50 PM #9
    Should be interesting. +2 for pix!!!
    GT3071r w/ Eurodyne 630cc Mafless File / Siemens 630cc Injectors / Inline Walbro Fuel Pump / Port and Polished AWP Head w/ exhaust valves / IE Rods / VDO Boost+Vac Gauge / WideBand A/F Gauge / 3" Down pipe / Boostvalve MBC / 38mm EWG / Custom Intake Side / VF FMIC / 3" Eurojet Catback Exhaust / HKS SSQV / ECS Stage 2 Clutch, W/ Light Weight Flywheel**Vag Com - East Greenville, Pennsylvania** Pagparts/Eurodyne
  10. 02-09-2012 03:32 PM #10
    when I try to imbed links to my picasa photos they do not work and when I try to attach pics I get a message that I do not have the permissions to do so. FAQ is no help as it references creating albums with a menu I don't think exists. I used to be able to post pics.
    Tomm
    Last edited by 1.8t_356; 02-09-2012 at 09:01 PM. Reason: try to imbed pic link properly now
  11. 02-09-2012 08:15 PM #11
  12. 02-09-2012 08:17 PM #12
    Received the AWIC stuff today and it exceeds my expectations in terms of mechanical quality. Frozen Boost does a nice job sourcing the AWIC itself and the Shaman radiator and Bosch pump are solid. Can't wait to pipe it in place.
    Going to get a Moroso 2Q reservoir (Aluminum) with fill cap and sight tube to add to the AWIC system. Anyone got something similar they want to sell or donate(?) to the project? Also going to relocate the round overflow tank and may just go with two of the same cans. I don't use the in tank temp sensor so this will be easy-peasy.
  13. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    02-09-2012 08:23 PM #13
  14. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    02-09-2012 08:24 PM #14
    car looks so slick!
  15. 02-09-2012 08:32 PM #15
    Quote Originally Posted by Big_Tom View Post
    car looks so slick!
    Thanks much!
    Now, how can I get permissions to attach pics?
    Tomm
  16. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    02-09-2012 08:34 PM #16
    ^^^ you just have to put the direct url between image tags. the direct URL
  17. Member mk4boost's Avatar
    Jul 31st, 2010
    Long Island, NY
    BT Prius
    02-09-2012 08:37 PM #17
    o this is cool
    F23 Frankenturbo ll Bosch 550cc ll Eurodyne Maestro ll 034 Motorsports High Flow Exhaust Manifold ll Eurojet street FMIC ll Cooling Mist Dual Nozzle W/M ll 287whp, 290ft/lbs (18psi) ll stock bottom end ll
    http://www.frankenturbo.com/
    http://www.usrallyteam.com
  18. 02-09-2012 09:04 PM #18
    Thanks, now works! I was being an idiot.
  19. Member Levi20AE's Avatar
    Feb 15th, 2005
    Las Vegas, NV
    20th AE GTI 1982 Diesel Rabbit Pickup 1973 Westfalia Bus 1970 Beetle
    02-09-2012 09:47 PM #19
    let see pics of the radiator setup
    Will MIG or TIG for $$$, , or trade.
    "What good is a beautiful dame with a Rolls-Royce frame and Volkswagen brain?"
  20. Member All_Euro's Avatar
    Jul 19th, 2008
    Calgary, AB
    05' VW GLI
    02-09-2012 10:28 PM #20
    Quote Originally Posted by 1.8t_356 View Post
    Nice - I've been seriously considering one of their AWIC kits. Thanks for the info. Sweet car BTW
    KO3 @ 30psi...
  21. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    02-09-2012 11:00 PM #21
    Quote Originally Posted by All_Euro View Post
    Pretty sure Aaron runs a setup from them
  22. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    02-10-2012 03:25 AM #22
    Gawd... I love it.
    Can you please please post a link to an album with LOTS of pics of that?
    My all time dream car is a beige 1954 356 with white interior and Porsche crest moon caps....
    I will likely never own an original, but there are some awesome tube frame replicas out there. Id love to slip a 1.8 in one!
    I'm guessing it's running every delete under the sun to stuff it in there
    My Build
    FS: New in box, primer'd 20AE body kit (front+rear valences and side skirts) -- PM me for details
    FS: Fiberglass 20AE replica spoiler. No scratches. Reflex Silver.
  23. Member Zneith's Avatar
    Jan 4th, 2010
    2001 Jetta 1.8 BT
    02-10-2012 10:11 AM #23
    Tomm
    Very nice!
  24. 02-10-2012 10:44 AM #24
    Thanks! A link to a few more pics is here: http://forums.vwvortex.com/showthrea...ed-356-Porsche
    Lots of deletes of course and the car has no instrument cluster or real VAG ignition key so the ECU was a challenge.
    Tomm
    Quote Originally Posted by groggory View Post
    Gawd... I love it.
  25. 02-10-2012 11:53 AM #25
    Here is the bag of parts for my AWIC install. Missing the pump bracket and the remote fill cap which are both on order. Decided not to go with a reservoir as this holds plenty of liquid and is always low pressure so expansion is not an issue. Have to decide now on pump control sense point and wether it will be proportional (PWM) or on-off. Simple is good and I will probably just switch it on with ignition.
    The cooler and fan will probably replace the existing S4 IC that is currently behind the RHS rear wheel.
    Tomm
  26. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    02-10-2012 02:03 PM #26
    no doubt man, it's all good
    Tomm
    thread is sick!
    Tomm
    simple is usually the route i take as well when it comes to cars. keep up the good work, the car is SO CLASSY
  27. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    02-10-2012 05:03 PM #27
    I'd like to request more pics under the boot please.
    My Build
  28. Member All_Euro's Avatar
    Jul 19th, 2008
    Calgary, AB
    05' VW GLI
    02-10-2012 05:29 PM #28
    ^^^ I'll second that!!!
    KO3 @ 30psi...
  29. 02-11-2012 11:00 AM #29
    Dyno done in April 2009 at 034. This is my starting point.
  30. 02-11-2012 09:50 PM #30
    Since some of you requested, here are some engine bay pics:
    Overall view of the business end of the car:
    Looking up at the turbo:
    Intercooler in RHS wheel well, soon to be replaced by my AWIC radiator:
    Detail of LHS of engine bay:
    Detail of RHS of engine bay:
  31. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    02-11-2012 10:31 PM #31
    To say... Do a timing belt change can you pull the whole rear clip off?
    My Build
  32. 02-11-2012 11:25 PM #32
    Nope, no rear clip, this glass body is all one piece bonded to the main frame rails with aerospace adhesives and big headed aircraft rivets. I have not thought about a timing belt change but suspect the easiest is to lift the car up, drop the engine out the bottom, change the belt and reverse the process to reinstall. One could support the engine on a jack and remove the tail mount and all exhaust and IC crossover plumbing and maybe do a TB change but it would be in a very tight space and from under the car.
  33. 02-13-2012 10:33 AM #33
    Drove up to meet Jake, owner of a fabrication and tuning business here in WA yesterday. Other than scratching the sh*t out of the side of the car in my garage, it was a very good trip. Nice day for a tops down cruise with heat blasting and a wooly cap.
    Jake looked over the project, suggested a few possible changes, test drove the car and came back with a big SEG on his face. Said, 'the steering is responsive, isn't it.' Glad I stayed at the shop.
    Anyway, as soon as the turbo parts get here, Jake will start on the install and fabrication then on to the tuning with the MS I have. Did I mention he has 5 years of MS under his belt? I saw several of his MS installs and they (1) worked well, and (2) the attention to detail in the wiring was superb.
    If you are in western Washington, and need fabrication or MS tuning, you might want to check out Jake. His website is http://www.jrmfabrication.com/
  34. 02-13-2012 07:44 PM #34
    In discussing the mounting of the frozen boost AWIC in my car, Jake, the fab man, brought up the always interesting question of using Laminova cores in a custom intake manifold. I was holding the FB AWIC and an idea started percolating:
    Why not slice of one end cap, which is on the long dimension and TIG weld it directly to a similarly butchered intake manifold? The throttle body would be mounted on the remaining AWIC inlet and you would have a low flow resistance 'poor man's Laminova!'
    I'm ready to start cutting and welding, what do you think?
  35. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    02-13-2012 08:12 PM #35
    I'm wondering if this will be good for equal flow characteristics to each cylinder..
    Awesome idea though
    My Build
