Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 71 to 105 of 146
Thread: Mobil 1 0w-40 or 5w-40
    Mar 24th, 2012
    Wappingers Falls NY
    2008 Passat 2.0, 2012 Golf TDi
    04-25-2012 12:15 PM #71
    ...a 10W40 is heavier than a 5W40? Although my question is general, I cannot help but think that the thickness of one similar grade oil isn't necessarily the same as another...?
  2. 04-25-2012 12:38 PM #72
    Quote Originally Posted by Broke Status View Post
    Best oil I have seen for the 2.0t that had little oil consumptions and came out clean every 5000 KM was Lubro Moly... http://www.germanautoparts.com/Volks.../Engine/513/12 FOR FSI and http://www.germanautoparts.com/Volks.../Engine/513/13 FOR TSI take your pick by far one of the best oils out there and test proven in extreme hot and cold weather to have little oil consumption at my shop.
    I second LM, but any 502 oil will work. You can get it at NAPA here in Michigan, but it goes by the name Liqui-Moly. But I caution that there are several types of LM, but only one is fully synthetic. They also changed the fully synthetic to 0w-40 (from 5w-40). When I first purchased my 08 WE, I used M1 0w-40. I found I was using about 1/2 quart per 5000 miles. LM cut that down to about 1/4 quart per 5000 miles.
    Nov 10th, 2010
    mid hudson valley
    02 jetta wagon 1.8t, 03 passat 1.8,06 jetta 20t
    04-25-2012 02:09 PM #73
    Quote Originally Posted by Apexxx View Post
    Haha, we're not open overnight.
    Can't you get anything right?
    so you work 3 to 11 so what
  4. Member
    Mar 24th, 2012
    Wappingers Falls NY
    04-25-2012 03:56 PM #74
    I've been using M1 5W40 TDT for 5 years and I change the oil approximately every 3,000 miles. I've never had to top off the oil...Though I find that this car is rare in this regard. ...but, 3,000 miles doesn't really give the oil a chance to burn-off. We were very careful about engine break-in too.
    Quote Originally Posted by cmosentine View Post
  5. 04-26-2012 02:06 PM #75
    Quote Originally Posted by meboice View Post
    Depends on the temp. At operating temp they are the same. This temp is where the visc is measured for the labeled grade, in this case a 40 weight, the visc at +100c is a range from 12.5cSt to near 15cSt. The W-rating is simply a cold cranking test at progressively colder temps (-20f, -25f, etc) and is separately determined.
    http://www.widman.biz/English/Calculators/Graph.html
    A 5w-40 is thinner at all temps below +100c than a 10w-40 or 15w-40. That doesn't mean a 5w-40 is thinner than a 10w-30 though. Every visc and every product needs to be analyzed specifically to compare their viscs.
    As you can see, 5w-40 isn't drastically better than a 10w-40 in cold, esp when compared to a 5w-30.
  6. Member
    Nov 10th, 2010
    mid hudson valley
    04-26-2012 08:07 PM #76
    keep useing it, you're fine. it's no where near as complicated as apeshirt makes it.
  7. 04-27-2012 01:27 AM #77
    Too complicated for some people.
  8. 05-19-2012 09:17 AM #78
    Motor oil threads on Vortex make me giggle. They always start off with someone asking an innocent question (In this case, Mobil 1 0w-40 or 5w-40), and devolve into arguments similar to gay vs. straight, Coke vs. Pepsi, carnivore vs. vegan, or 1911 vs. Glock.
    Great fun for those of us that simply change our oil at the specified interval with VW 502 spec oil.
    Please, by all means, carry on...
    Nov 10th, 2010
    mid hudson valley
    05-19-2012 11:06 AM #79
    Quote Originally Posted by camjr View Post
  10. 05-19-2012 11:26 AM #80
    Well, it is a technical forum afterall.
  11. Member
    Nov 10th, 2010
    mid hudson valley
    05-19-2012 05:51 PM #81
    use an approved earl and all will be fine.
  12. 05-21-2012 03:40 AM #82
    yeah, because vag never ever had an oil related issue.
    no way either could there ever be a better oil than oem oil.
    see, if you have zero clue, oem oil is a good way to go.
    the rest of us are here for more information, and most everyone has heard about VW 502, believe it or not. if that's all you have to offer, you should maybe find a new hobby, like beanie babies. it suits your comprehension level.
  13. Member
    Nov 10th, 2010
    mid hudson valley
    05-21-2012 07:16 AM #83
    you would be lost if you could not tell us how smart you think you are and how stupid we are. somebody needs a new hobby for sure.
    vag had an oil sludge problem in the longitudinal 1.8t. however they addressed it with the larger oil filter ( not for more filtration but rather to increase capacity) and requiring synthetic oil. not perfect for sure, but i've got an 03 passat 1.8 with 150000 mikes on it without any problems using whats recommended. i've got a couple of friends with well over 240000 miles and no problems. no uoa's either, just regular service.
  14. 05-21-2012 10:17 AM #84
    Point proven...
  15. 05-21-2012 02:11 PM #85
    The best part, 'changing at the specified interval'. Uhh, is that 10k or 5k, like when the 2.0t was first introduced, before inclusive service? Are we going to take into account 'severe operating conditions' or not?
    Wait, maybe just get a UOA? Oh, I did.
    I see a lot of gums flapping, nothing but frothy poop coming out.
  16. Member
    Nov 10th, 2010
    mid hudson valley
    05-21-2012 02:59 PM #86
  17. Member
    May 10th, 2010
    North Jersey
    08 Passat wagon 2.0T 6MT (current). Past: 02 Golf TDI, Dark Beige 88.5 Camry V6 5MT, AE82 Corolla
    05-22-2012 04:17 PM #87
    2.0T's with VW502.00 oil have always been specified at 10k OCI.
    VW502.00 is the severe operating conditions oil.
    2008 Passat wagon, 2.0T 6MT with mods
    Other Rides:
    - 2013 Cannondale CAADX-6
    - 2010 Specialized Secteur Elite
    - 2009 Specialized Rockhopper Comp 29-er
  18. 05-22-2012 05:10 PM #88
    Umm, nope. 1st change at 5k prior to inclusive service.
  19. Member
    May 10th, 2010
    North Jersey
    05-22-2012 05:35 PM #89
    Vw = 5k, then another 5k, and then every 10k thereafter
    Audi = 5k, then every 10k thereafter
    from the 2008 manual, prior to the CareFREE service:
    ... after the initial oil change(s)... 10k OCI's, just as I stated earlier.
    Other Rides:
  20. 05-23-2012 01:50 AM #90
    Quote Originally Posted by BsickPassat View Post
    oh?
  21. Member
    May 10th, 2010
    North Jersey
    05-23-2012 06:04 AM #91
    if it was 5k oci's, then the service intervals would be 5k, 10k, 15k, etc
    Other Rides:
  22. 05-23-2012 01:42 PM #92
    And your point is....?
  23. Junior Member
    May 1st, 2009
    San Diego, CA
    CC 2010
    05-25-2012 12:06 AM #93
    OMG!
    Ok, in a country where speed limit is in some extreme cases 75 miles per hour there are people so obsessed with oils that my question is: do you have a life?
    This obsession would be justifiable in Germany where cars can use their fullpotential and where you need best tires, best brakes and best oils.
    So, to make life easier: Use Castrol 0W30 or M1 0W40.
    Why using Rotella? Why usinf TDT? What is a point? Price? UOA?
    If VW says that M1 0W40 is good for the car or GC or whatever oil meets 502.00, why reinventing the wheel?
    10' CC 2.0T DSG
  24. Member
    Nov 10th, 2010
    mid hudson valley
    05-25-2012 06:25 AM #94
  25. 05-25-2012 12:58 PM #95
    Quote Originally Posted by gmikel View Post
    I have no objections to 502 oil, but we do have better alternatives.
    502 fanbois should bear in mind how poorly it faired in:
    1.8t
    3.2 VR6
    2.0 FSI
    4.2 FSI
    and 3.0 AVK.
    I guess it's easier to theorize than to actually examine facts.
    Otherwise, just follow the manual and don't think for yourself.
  26. Junior Member
    May 1st, 2009
    San Diego, CA
    CC 2010
    05-25-2012 02:44 PM #96
    I do not have a clue what you talking about!
    I used in my 1.8T GC all the time and engine was clean like new!!!
    10' CC 2.0T DSG
  27. 05-26-2012 01:58 AM #97
    Ok, stick your head in the sand.
  28. Member
    Nov 10th, 2010
    mid hudson valley
    05-26-2012 10:25 AM #98
    1.8t
    3.2 VR6
    2.0 FSI
    4.2 FSI
    and 3.0 AVK.
    how many miles on the engine and was the oil even changed. their is nothing to validate that oil was a problem, more likely it was a lack of timely maintainance.
  29. 05-26-2012 12:13 PM #99
    So, you're saying that, without a full explanation, you're lost.
    Sorry, some people here will get left behind.
  30. Junior Member
    May 1st, 2009
    San Diego, CA
    CC 2010
    05-26-2012 02:55 PM #100
    I am coming from Europe. In Europe all 5W40 or 5W30 or 0W30 meet 502.00.
    For sludge problems I heard first time when i moved to the US! My friend actually screwed up his A4 bcs he was thinking that $19.99 oil changes are OK with these cars. In EU $19,99 oil change does not exists! You go with synthetics and you pay for them, trust me. So there was no sludge issues!
    Now, I always used GC, changed oil every 7,000 miles, and engine was like a brend new inside!
    Now, you are showing us pictures that means what?
    Oil in those engines could be any oil, it could be 502.00 that was changed like every 40,000 miles.
    Means nothing!
    I have never heard from friends who owned 1.8T and used 502.00 that they had ANY problems!
    10' CC 2.0T DSG
  31. 05-26-2012 05:51 PM #101
    Europe has different, more highly refined, fuels, for starters.
    GC is actually a 503.01 oil, which is a different beast. It's the long-life spec, that exceeds 502.
    If you range over to the FSI Forums, you'll see failure after failure on spec oil. People using HD or high zink oils had essentially no failures.
    Blaming owner neglect on 1.8t sludge, and "all" the other instances I cited is outright arrogant.
    Remember, VAG speced a larger capacity filter to solve the sludging oil problem, which has nothing to do with oil quality issues. People who did 5k changes over the "official" 10k changes were well-served. You can't BS me, I was there in 2002 when Audi went to 10k. I had a new B6 1.8t, so **** it.
    VAG also updated the 502 spec in 2004, with sludge resistance as a priority.
    Welcome to reality.
    If you're happy with your fanboi oil, that's ~totally awesome~ (pun intended)
  32. 05-26-2012 06:06 PM #102
    Don't forget people, spec oil is the ONLY way to go...
    Surely an error. Dozens of samples must be wrong.
    Everyone wants to play with fire, but no one likes getting burned.
  33. Member
    Nov 10th, 2010
    mid hudson valley
    05-26-2012 07:01 PM #103
    whatever
  34. Junior Member
    May 1st, 2009
    San Diego, CA
    CC 2010
    05-27-2012 03:35 PM #104
    Well, there is first problem of the fact that Synthetic oils in the US are by far Group III oils (except few like GC). They are mainly lower quality than European oils (which you said are not having bragging rights).
    Also, not all European countries have low sulphur fuels. Go to Ukraine, Serbia, Macedonia, Bulgaria etc and you will see content of sulphur in the fuels.
    I was changing GC every 7,000 not 5,000 as VW said, and no issues at all.
    I agree with you that SOME 502.00 oils could be a problem, but by far, big majority is not!
    10' CC 2.0T DSG
  35. 05-28-2012 02:06 AM #105
    BZZT, they're all Gruppe III now.
    PAO base oil?
    What is this, 2003?
