Results 1 to 31 of 31
Thread: DV Failures and replacmeent solutions
  1. Member onevrsix's Avatar
    May 27th, 2010
    Philly Area
    2009 GLI, 01 "Thundercat"
    02-10-2012 10:31 AM #1
    Wanted to kick up a thread to see just how common OEM DV failures are for the TSI.
    Most TSI's should come with the Revision G or Revision D.
    Mine came with the Revision G; I had an issue where I was sporadically throwing EPC light. I had no idea what for but at some point I decided to replace DV out of preventative maintenance and it fixed my EPC issue. I replaced it with an OEM Rev. D and while the EPC was gone, car did feel a tad slower and less responsive. I ignored it until I recently had my clutch done and the guys over at APTuning said my DV isn't working properly. It hasn't failed, but they said it definitely wasn't working right.
    Here I was thinking these things were bullet proof; but even superman has his Kryptonite. I guess revision D's is Unitronic Stage II
    I wanted to hear from the crowd, what DV did you end up going with after yours failed/you decided to replace.
    I'm thinking AWE DV will be my next move simply because of the cost.
    Contact me for: FENDER ROLLING!!! also *Coilover & Exhaust install*brakes, maintenance & more*
  2. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    02-10-2012 11:32 AM #2
    My car had rev G.
    I had some intermittent boost issues when I went stage 2 so I snagged a rev D DV, when I pulled out the Rev G it fell out in 3 pieces lol. The rev D is holding up just fine now.
    I was origionally holding out for the BSH DV Relocation kit, but its been 2 years of waiting...
    :APR -stage 2 :BSH -Intake,Mounts,RSB,TB Pipe :Whiteline -A.L.K.,Endlinks
    :Devils Own -DVC-30+Direct Port Injection :BC Racing -BR Coilovers :Flik-FTD :OSIR
    :Neuspeed -Insert,Brake Lines:Eurojet -Ceramic Coated DP :DEFI :Unibrace :Tyrolsport :Bildon :Hawk
    TSI FAQ: http://forums.vwvortex.com/showthread.php?4042736
  3. Member Ricky Bobby's Avatar
    Sep 29th, 2005
    Martinsville, NJ
    2003 X5 3.0i 5SPD, 07 SV1Ks
    02-10-2012 04:02 PM #3
    Quote Originally Posted by ViRtUaLheretic View Post
    My car had rev G.
    Remember those days when we were all waiting for BSH to release one for us?
    I went Rev D myself about a year and a half ago, I don't even think about it anymore. Works great on big turbos too!
    Quote Originally Posted by Senor Pelligro
    It's a car for a fashion forward, style conscious guy that's always looking for the season's hottest accessory. A guy that watches Project Runway, reads TMZ, and drinks Cosmos.
    It's simply fabulous, sweetie.
  4. Member 01gtiaww's Avatar
    Jan 31st, 2006
    2001 GTI 1.8 BT, 2009 GTI 2.0 TSI
    02-10-2012 04:23 PM #4
    I never had issues with G. I went Rev. D as a preventive measure.
  5. Member BASE1375's Avatar
    Apr 22nd, 2011
    New York, Long Island
    2012 Gti K04 Autobahn 6MT
    02-10-2012 07:08 PM #5
    had mine swapped out for a forge DV relocation kit when i went K04.....i have the rev D i believe, its for sale if anyone wants it! came out of a 2012 gti with 4k miles on it
    2012 Autobahn GTi 6Mt
    Apr K04 Kit, APR 3' TBE, APR Stage 1&2 Intake, Forge Dv Relocation Kit, Peloquin LSD, Southbend Stage 2 Daily Silent Kit, Dieselgeek SS Kit.
  6. Member onevrsix's Avatar
    May 27th, 2010
    Philly Area
    02-13-2012 12:07 PM #6
    Interesting; I'm actually thinking about jacking her up tonight and putting my G back in to see/record the difference
    Aug 30th, 2009
    Santo André SP Brasil
    Passat Wagon 2.0 TSI 09; APR K04 ;carbonio; DP APR;cat 200 cels inox;paddle shifts; VCDS;
    02-13-2012 12:48 PM #7
    Quote Originally Posted by onevrsix View Post
  8. Member onevrsix's Avatar
    May 27th, 2010
    Philly Area
    02-13-2012 04:12 PM #8
    Quote Originally Posted by zucchini View Post
    I'm telling you, I noticed a big dip in power when I switched to the D. I plan on ordering the AWE Wednesday, but until then I'd like to run logs with the G and logs with the D.
    Plus when I went in to have my clutch done Thursday, APTuning guys mentioned that my DV wasn't working properly. I should throw this C I've had sitting on my desk for almost 10 months now in just to blow it out Bought a spacer back when I first picked up the car (sold it immediately) and the guy sent the DV with it...never even asked for it.
  9. Member Track5tar's Avatar
    Feb 16th, 2010
    Salt Lake City, UT and Las Vegas, NV
    Mine: 2010 Passat Hers: 2012 B8 A4
    02-13-2012 07:11 PM #9
    the awe is nice. I replaced my D with it. The D with my twintake had that weird spit noise but with the awe its more of a pssh sound(sounds smoother). I feel like awe's dv holds boost a little better than the D. I do feel that it isnt quick to get rid of boost as the rev d but at the same time it doesn't allow for any surging. its a great buy
    Unitronic > APR Switched from APR to UNI and never looking back
    CW '10 Passat 2.0TSI: UNI Stage 2 VMR V705 19x8.5 et45 Podi Boost gauge/pod AWE DV, Turbo Outlet Pipe BSH Boost Tap BillyBoat 3" TBE BFI Stg2 Dogbone/motor mount/trans. mount KW V2 coils Forge Twintake(1st on Passat/CC) JBL W12GTi MKII HEX+CAN vagcom, Podi.ca podi free ship code: NINOSHIP, VMR | Wheels velocitymotoring.com, VolksBHAN in September
  10. Member onevrsix's Avatar
    May 27th, 2010
    Philly Area
    02-16-2012 09:01 AM #10
    Ordered the AWE yesterday. We'll see if it changes the flutter issues I'm having.
    To recap, at time when I abruptly let off the throttle, the flutter changes to deep bassy 'boonnnnnn' vs the middle of the road pitch "schuuuuuu"
  11. Member onevrsix's Avatar
    May 27th, 2010
    Philly Area
    02-22-2012 12:10 PM #11
    Installed the AWE; power is back, car drives sooo much better; no more unnecessary intake noise but the damn thing brought the EPC problem back At least once a day I get the EPC light. Turn it off, reset the ecu and turn it back on and it generally goes out. It's driving me absolutely crazy !
  12. Member Ricky Bobby's Avatar
    Sep 29th, 2005
    Martinsville, NJ
    02-22-2012 12:28 PM #12
    you throwing any soft codes when you scan it? maybe you have intake manifold issues or a leak somewhere?
  13. Member onevrsix's Avatar
    May 27th, 2010
    Philly Area
    02-22-2012 12:37 PM #13
    Quote Originally Posted by Ricky Bobby View Post
    Replaced the manifold a few months back. I was epc free with rev d but the rev g and now awe are throwing the light. Only engine codes I throw are for my o2 sensor
    Sent from my Galaxy S while planking on a cop car using Tapatalk
  14. Member onevrsix's Avatar
    May 27th, 2010
    Philly Area
    02-23-2012 08:48 AM #14
    My issue I don't think is DV related, I'm still not sure while the EPC stopped with the Rev D and came back with the AWE but I'm throwing codes for Throttle body positioning sensor.
  15. 02-24-2012 10:07 AM #15
    It sounds like this may have been a preexisting condition. Your Rev D valve may have been leaking, and hiding the TB issue. Once the AWE Tuning DV was installed, like you mentioned, the power came back, and there was no more leak. With the initial DV leak fixed, the proper amount of pressure is now passing through the TB, and causing the codes, and EPC.
    Joe Tomaselli >Specialist, Online Marketing
    AWE-Tuning.com > 1.888.565.2257
    My Email > facebook > twitter > YouTube
  16. Member onevrsix's Avatar
    May 27th, 2010
    Philly Area
    02-24-2012 01:09 PM #16
    Quote Originally Posted by Joe/AWE View Post
    Correct; just yesterday I noticed fluctuations in the boost gauge; when I make it to 15psi boost will waiver between 13psi and 15psi a few times before heading all the way out to 18/19. Before the AWE DV I was maxed at 16psi, never held anything higher.
    So in fixing the DV leak, I've brought to light a preexisting issue that just wasn't noticeable before since I wasn't reaching my potential boost levels. I'll have to run some logs and figure out what exactly has gone south. I'm thinking it's an issue with the Throttle Body or the TB wire harness; gonna cave and take it to VW
    Thanks Joe
  17. 02-24-2012 01:17 PM #17
    Good deal. Let us know what happens!
  18. Member gb21914's Avatar
    Apr 6th, 2011
    Cambridge, ON
    2007 VW GLI
    03-14-2012 03:13 PM #18
    To those running the "d" version diverter valve...is there an audible difference between the "g" and "d" versions? Just curious as there IS a design change there.
    (thanks in advance)
    2007 GLI - APR Stage II+
    APR / Autotech / BSH / EBC / Forge / 42DD / Magnaflow / Neuspeed / Raceland
    Pending Installs
    Intercooler Sprayer / Ultimate Timing Belt Pulley
  19. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    03-14-2012 04:11 PM #19
    I noticed a change in sound, but when I pulled out my old DV it fell out in 3 pieces.
  20. Member Ricky Bobby's Avatar
    Sep 29th, 2005
    Martinsville, NJ
    03-15-2012 08:28 AM #20
    Quote Originally Posted by gb21914 View Post
    (thanks in advance)
    G sounds different than D, G is more of a longer whoosh in between gears, D is a bit "tighter" sounding and has a bit of a flutter to it, due to the piston vs. diaphragm design.
    at least thats how i describe it
  21. Member onevrsix's Avatar
    May 27th, 2010
    Philly Area
    03-15-2012 07:15 PM #21
    Well put; AWE DV sounds a lot like the G, a little more abrupt
  22. Member onevrsix's Avatar
    May 27th, 2010
    Philly Area
    04-26-2012 08:36 AM #22
    Thanks Joe
    Figured I'd stop by and note that fluctuation and EPC have all been sorted. I was finishing around the engine bay and found that the Throttle body plug, while it was plugged in, wasn't clipped. I'm assuming this caused a poor connection triggering epc's on first start.
    hesitation at 15 psi has smoothed out as well but I think that happened after the introduction of a proper full exhaust. Even with a wayne angle block, I'd still throw CEL's from time to time (catless 3" and oem exhaust on a GLI) Since I've moved to 3" catback, car has really opened up.
    just a follow up
  23. Junior Member darrinv8's Avatar
    Apr 4th, 2012
    Central Illinois
    2009 GTI TSI CBFA
    04-26-2012 11:15 AM #23
    Is there an easy way to tell which DV I have in my 09 besides pulling it out? I heard of some dealerships replacing it to the new "D" valve. I am going to the dealership on Saturday for my APR tune and figured if I had the old valve, I could just have them replace it while I'm there.
  24. Member onevrsix's Avatar
    May 27th, 2010
    Philly Area
    04-26-2012 11:30 AM #24
    Quote Originally Posted by darrinv8 View Post
    You most likely have the G, and to be honest, the G's were designed pretty well. There is no real way of telling without getting under your car and taking a good look at it. Depending on what stage you go with you should be fine with the G. My car responded better with the G on my unitronic stage II. I moved to the D and had a slight loss in boost, then I got tired of playing the guessing games and switched to the AWE which has been great. It's like a peace of mind, I shouldn't have to worry about this DV failing during the time I own this car.
  25. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    04-26-2012 11:57 AM #25
    That "great design" fell out in 3 pieces from my car.
    Rev D FTW.
  26. Junior Member darrinv8's Avatar
    Apr 4th, 2012
    Central Illinois
    2009 GTI TSI CBFA
    04-26-2012 12:49 PM #26
    I have no boost gauge to tell, but she sure does fall flat on here head around 5k. Is there a good(cheap) boost tap kit anyone recommends? I'm going Stage II APR tune BTW...I just wanna make sure all my basis are covered before I go through the tune
  27. Member onevrsix's Avatar
    May 27th, 2010
    Philly Area
    04-26-2012 01:10 PM #27
    Rev D FTW.
    They all disassemble easily , I pulled my d apart to see what made it so much different. Coming apart doesn't mean it failed, rips in the rubber means its failed.
    Sent from my SGH-T959 using Tapatalk 2
  28. Member
    Apr 24th, 1999
    09tfsi revo 2
    04-29-2012 10:59 PM #28
    Can you elaborate on where you saw the boost flux after switching to the d valve.
  29. Member ghotch's Avatar
    Apr 5th, 2010
    Austin, Texas
    2010 GTI 4 dr 6 spd; 2002 Mk4, 4 dr 5 spd
    05-29-2012 02:17 PM #29
    Any of you that had the G version fail did you notice any oil on the DV itself or around it....not leaking but oil film?
    2010 GTI CSG 6 Spd Autobahn | APR Stage 2 | Modshack Intake | SPM 3" Downpipe/ Magnaflow Exhaust | 18" fifteen52 Snowflakes | OEM LED Tails | H&R Sport Springs
  30. Member
    Feb 18th, 2012
    North Jersey
    2011 Audi A3
    05-29-2012 02:36 PM #30
    Thanks Joe
    This reminds me exactly of my current issue that I haven't been able to solve for either. APR stage 1 and same thing; I'll go WOT, get to about 15PSI and the gauge will bounce around between 12-15 before climbing to 16017 and dropping off. I have an audible whistle from the passenger side when in boost/at WOT which made me think the DV was failing.
    APR Stage 1 - aFe Dry S Drop In Filter
  31. Member onevrsix's Avatar
    May 27th, 2010
    Philly Area
    05-30-2012 08:24 AM #31
    Quote Originally Posted by sfdxsm View Post
    I occasionally get that whistle as well, but boost gauge reads pretty accurate in comparison to my friends so I've never been too concerned
