Results 1 to 17 of 17
Thread: engine knocking/tapping?
  1. Member DumpdDirTEEDubZ's Avatar
    Sep 28th, 2006
    RDG, pa
    ~95vrWagen~90 2dr vr~
    02-10-2012 04:51 PM #1
    Have a 95 Vr. Just did mk4 headgasket, car ran fine have about 450 miles and goto start and motor is knocking/tapping fairly loud. Swapped ecu to check if chipped(giac) ecu was adjusting timing to far. Still knocking so swapped back and wouldn't start with either ecu plugged in. Pulled intake Mani/valve cover and spark plugs everything looks good no noticeable bent valves or damage to pistons. Checked oil and no metal pieces. Im completely lost. Chains are new looking with good tension.... any advice or ideas what could be problem?
    DGAF DUBZ
    www.CBtuning.net
    RDG/PREMIUM euros
  2. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    Mk2 GTI VR6... .......................Mk5 Rabbit 2.5
    02-10-2012 09:18 PM #2
    What all was done exactly? Did you replace the lifters? And if not, how long was the engine down/apart for? I suspect it's just the lifters being full of air. When I went to start my engine after the rebuild, it was knocking/tapping very loudly but slowly began to quite down and eventually went away as the lifters bled themselves and filled completely with oil.
    Air in the liftes does little to dampen the noise, it's the oil inside that acts like a shock absorber and keeps them quite.
    /// VRSociety Member #298 /// Mk2 Milita-VR6 Battalion-2dr Regiment /// Instagram @scottyvr6 ///
    My 2.9L BVH build and the machine shop #%@- up that almost ruined it all.
  3. Member DumpdDirTEEDubZ's Avatar
    Sep 28th, 2006
    RDG, pa
    02-10-2012 11:19 PM #3
    Head was off for maybe hr to clean inspect etc. But just to replace headgasket because it was leaking below by freeze out plug. Ran decent except for low idle which I suspect is dirty isv. I drove the car for 450 miles without a problem went to start other morning to warm up my normal 5-10 mins and right when I went to turn over it started and was making the noise. Not sure if crank or knock sensors could have failed n causing this? Im fairly new to the vr6 game.
    DGAF DUBZ
    www.CBtuning.net
    RDG/PREMIUM euros
  4. Member mk4vrjtta's Avatar
    Feb 3rd, 2007
    Rockford IL
    2000 Jetta vr6S
    02-11-2012 06:25 PM #4
    sounds like lifters...is it coming from the top of the motor or the bottom?
    VRalliance#35 308whp/248ftlb --vortech v9 f-trim w/single idler 10psi, forge 007 DV, 262 cams, dual nozzle devils own water/meth, ported stock ex manis, tt downpipe, custom 3in exhaust, Autotech 10lb flywheel, sachs oem vr clutch, 034 motor mounts,ecs lightweight crank/power steering pulleys, vmaxx, R32 control arm bushings, 18x8.5 flik arctics
    Aug 26th, 2007
    '08 touareg, '97 jb de x2, '86 vr6 Rocco, '84 8v Rocco, '95 Vr cabby "hers"
    02-11-2012 11:22 PM #5
    so now it wont start at all? ill be out there sun ill have a look hooker!
  6. Member DumpdDirTEEDubZ's Avatar
    Sep 28th, 2006
    RDG, pa
    02-14-2012 07:23 PM #6
    K davey.... but its hard to tell if its from top or bottom. I finially got my phone back from verizon damn thiefs... n ill post link to video.
    DGAF DUBZ
    www.CBtuning.net
    RDG/PREMIUM euros
    Oct 18th, 2001
    CT
    '90 Corrado vr
    02-15-2012 12:48 PM #7
    where are people getting there info these days
    why would you think the ecu has anything to do with lifter noise? dumb question but are you low on oil? what weight are you running? you most likely caused another issue by messing with the ecu, its probably not seated correctly or if you swapped em with the battery connected it may be toast. also even though i cant understand why people dont soak new lifters after 450 miles it wouldnt make a difference. and there is no way to visually see a bent valve by just taking the intake/ valve cover off....
  8. Member DumpdDirTEEDubZ's Avatar
    Sep 28th, 2006
    RDG, pa
    02-16-2012 06:29 PM #8
    Disconnected battery ecu is in correctly. I ran 10w30 full synthetic. Same as my other vr. Well visually u cant by just looking at them but i have a little camera that use to insert into motor etc. Dip stick shows oil is good n looks fresh. Motor almost sounded like it was missing at same time as knocking sound. About to drain oil and see if a bearing spun or pump screen is clogged.
    DGAF DUBZ
    www.CBtuning.net
    RDG/PREMIUM euros
  9. Member JonLott's Avatar
    Apr 24th, 2010
    Homestead, Fl
    2011 VW CC LUX
    05-30-2012 11:06 AM #9
    What did you find? I am having a similar issue. My motor ran fine for around 300 miles. Then mine did the same thing as yours.....any information would be greatly appreciated!!!!
    Drive that **** like you stole it!!
  10. 05-30-2012 12:49 PM #10
    Check plugs and wires for failed parts/loose connection or maybe you can isolate an area of concern based on plug condition or if you see fuel on top of one of the slugs or something. You might think about getting it running again if you think it won't hurt it and use a mechanics stethoscope to isolate the noise before taking it apart any more. Those things are cheap and really work well. You can listen to individual things rotating and moving around in there, and it's surprising how moving it just a little bit can really change what you hear. It will probably help out a lot because a lot of times bottom end noise sounds like it's coming from the head when you are just standing there, or you have a trans noise that sounds like it's coming from the block, etc.
    LUK VR6 CLUTCH AND PRESSURE PLATE FOR SALE PLUS MORE!!!>>>
    http://forums.vwvortex.com/showthrea...t-inserts-9346!
  11. Member JonLott's Avatar
    Apr 24th, 2010
    Homestead, Fl
    2011 VW CC LUX
    05-31-2012 02:23 AM #11
    Well, did a compresstion test yesterday....here are the numbers
    1 140psi
    2 160psi
    3 140psi
    4 140psi
    5 125psi << Noisey area
    6 140psi
    So, I live in Germany, a good VW mechanic and friend of mine who has a VRT in his MK2. Said he thinks it's the lifters. So he is gonna bring me a set to try this Saturday. I will also ask him if he has any extra wires. May as well try it. When it runs, it doesn't sound like it is running on five cylinders. It idles smooth and revs smooth, just has an awful tapping. Thanks for the response. Everything helps, I hadn't thought about the wires. They were pulled of my old motor and work fine there......Thanks again!!
  12. Member JonLott's Avatar
    Apr 24th, 2010
    Homestead, Fl
    2011 VW CC LUX
    05-31-2012 02:33 AM #12
    Quote Originally Posted by 'dubber View Post
    When I ran the compression test, I did it with the motor cold. Didn't want to warm it up in fear of damaging anything. I cranked it over 5-7 times and only pulled one plug at a time. Everytime I pulled another plug, it had fuel on it. They are all fresh plugs and all still looked fresh. Only other thing I can think of is wires, but they are getting spark from pack to wires and out the other side.....S
  13. Member
    Aug 26th, 2007
    05-31-2012 05:08 PM #13
    His car jumped a tooth and bent a valve running fine other than a bad valve stem seal
  14. Member JonLott's Avatar
    Apr 24th, 2010
    Homestead, Fl
    2011 VW CC LUX
    06-01-2012 02:14 AM #14
    Quote Originally Posted by sweetrocco420 View Post
    This is what I am starting to think is wrong with mine.....guess I will find out tomorrow!
  15. Member
    Aug 26th, 2007
    06-01-2012 02:42 AM #15
    His tensioner was shot and broke... We ended up pulling one of a spare head at our shopand putting it in... Shoulda poped a new seal in as well I think it tweaked it when it bent the valve but it's his daily and was just a quick fix
  16. 06-01-2012 01:03 PM #16
    Did it really skip a tooth or did it just lash up on decel?
  17. Member tomslik's Avatar
    Nov 1st, 2006
    Richmond Hill, ONT
    1984 Jetta, 1992 Golf, 1992 Passat, 1996 Golf, 2007 City Golf
    08-28-2012 03:05 AM #17
    That's a great question. Well , did it actually jump a tooth?
