VWVortex.com - V6 timing belt
    Results 1 to 23 of 23
    Thread: V6 timing belt
    1. Junior Member
      Dec 24th, 2011
      Milford Ct
      01 4motion v6 passat wagon auto
      02-11-2012 02:33 PM #1
      My indie says he can change the timing belt without removing the front of the car. Is this possible . If so can the seals etc also be replaced this way. He wants $800 for the job seems high to me.
      Any thoughts
    2. n00b
      Jan 1st, 2012
      croatia
      vw passat 1.9TDI PD
      02-11-2012 07:23 PM #2
      LOOOOOOOOOL that's not possible
    3. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      02-11-2012 07:38 PM #3
      If you've got reeeally skinny arms, I suppose it could be done... Or maybe he means he'll just slide it out instead of fully removing it. That's common. And BTW, $800 isn't a bad price for a proper timing belt job on a V6. It's more work than a 1.8T.
    4. Member passatv6AF's Avatar
      Nov 4th, 2011
      Chicago
      B5 5MT UNITRONIC TUNED, B7 6MT STAGE 1.5 TDI
      02-11-2012 08:21 PM #4
      Lol he must be a miracle worker!
    5. Senior Member Mk1Racer's Avatar
      Apr 16th, 1999
      NJ
      '01 B5.5 wagon, '81 Scirocco, '04 FXDWG and too many A1,2, & 3 cars to remember. '93 Miata for S&G
      02-12-2012 07:52 AM #5
      I guess it's possible, if he likes making it harder on himself. And $800 is about the going indy rate for a B5 t-belt job (and that's w/ removing the front end).
      Quote Originally Posted by vwtool View Post
      I went to a karaoke night with a mixed-age group earlier this week and sang "Little Red Corvette" when it was my turn. Half the group had never heard of Prince.
    6. Member passatv6AF's Avatar
      Nov 4th, 2011
      Chicago
      02-12-2012 07:56 AM #6
      I'm pretty sure theres someone around ur area that can do it cheaper than $800. I got mine done at a steal price for $300
    7. Junior Member
      Dec 24th, 2011
      Milford Ct
      02-12-2012 10:31 AM #7
      Anybody in Ct that can change a timing belt on a 01 V6 passat at a reasonable price.
      Thanks
    8. Junior Member
      Dec 24th, 2011
      Milford Ct
      02-12-2012 10:32 AM #8
      What do you mean by sliding out ?
    9. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      02-12-2012 10:39 AM #9
      Quote Originally Posted by tr6g View Post
      The "front of the car" is supposed to move out of the way for service - in fact, this is called "service position". There's two ways to do this: You can insert a special VW rig (or a couple of long bolts) and literally slide the part of the car ahead of the engine several inches forward. This lets you do most things without disconnecting the various hoses and wires, or draining anything.
      Or, for more ambitious repairs, you can take the section off entirely and set it aside for better access to components. Clear?
    10. Member passatv6AF's Avatar
      Nov 4th, 2011
      Chicago
      02-12-2012 11:53 AM #10
      Why don't u take some time drive around and go to 10-15 shops and ask for an estimate? Thats what I did, I did actually get one idiot that said $1500 and it would take 14hrs of labor. I wanted to literally slap him lol
    11. Semi-n00b
      Aug 6th, 2011
      Altamonte Spgs, Florida
      2001 VW Passat Blue Anthracite Pearl code LC7V
      02-12-2012 06:01 PM #11
      Any thoughts
      Here is my car just after getting the bumper off. I needed more room than just putting the bumper in the service mode. This did just fine, and without disconnecting the air conditioner lines too. You just have to be careful not to bend or stress the lines too much
      Watch this youtube video. It's on the 2001 Audi A4, but the Audi is identical to our B5 Passat's You'll see why it's required to remove the front.
      Notice he says "it's a little more interesting than your typical timing belt/water pump job" LOL
    12. Senior Member Mk1Racer's Avatar
      Apr 16th, 1999
      NJ
      02-12-2012 07:32 PM #12
      Quote Originally Posted by passatv6AF View Post
      Including parts? That's about what the parts cost, wholesale. And if you didn't do the water pump while they had it apart, it was silly.
    13. Member passatv6AF's Avatar
      Nov 4th, 2011
      Chicago
      02-12-2012 08:03 PM #13
      I bought the parts for $285 from ecstuning, which included, timing belt, serpentine belt, tensioner, idle roller, water pump, thermostat, g12 coolant and the seals (might be missing something). COMPARED PRICES FROM EVERYWHERE AND ECSTUNING BY FAR HAD BEST PRICE THAT I FOUND THAT PRICE. Labor cost me $300 which came out too $585 all together. I got a bad as deal!
    14. Member
      Feb 4th, 2007
      Norther VA
      2000 Passat B5 V6 5sp
      02-12-2012 09:36 PM #14
      after watching that video I am fully ready to to do the job my self. I ahve been sitting on the parts for over two years. Should be a no brainer now.
    15. Senior Member Mk1Racer's Avatar
      Apr 16th, 1999
      NJ
      02-12-2012 09:57 PM #15
      So you didn't get it done for $300, you got it done for almost $600. Not really that far off from the $800 the OP posted, if it includes parts. Shops are entitled to make money on parts, and $300 labor for a B5 or B5.5 V6 t-belt is CHEAP. I'm guessing it was a deal from a friend, as a lot of shops will supply both the parts and the labor.
    16. Senior Member Mk1Racer's Avatar
      Apr 16th, 1999
      NJ
      02-12-2012 09:58 PM #16
      Quote Originally Posted by The Captin View Post
      And it should take you
    17. Member
      Feb 4th, 2007
      Norther VA
      02-12-2012 10:22 PM #17
      I bought the parts as well from ECS tunning, should have mentioned that above sorry, Best deal by far. My local shaddy tree wrench want 450 to install. he wont do it the way in the movie above but he still remove the front of the car mosly by keeps the AC hooked up. Its a manly a time intensive job. I would take it on my self, just dont have the time.
      Nate
    18. Semi-n00b
      Aug 6th, 2011
      02-13-2012 01:46 PM #18
      I got most everything I needed from rockauto.com It's more expensive kit's out there you can buy with everything included, but being on a budget I found it more economical to research on all the parts needed and order them separately.
      It took me 4 full 12hr days to do the job. My car had the dreaded oil leak for some time, so I spent 20 minutes on every part as I dismantled them off the car. The grime build up was so bad. So I spent quite some time just cleaning. Plus not really being a mechanic I was always second guessing my work. I was always checking and rechecking everything as I put it all back together. The manual that I was working with was the Haynes manual. It had most the main torque specs but not on things like the mounting bolts for the mechanical fan pully to engine block. It was a few other specs that I can remember off the top of my head. But the next big job that I do I'll definitely invest on a Bentley manual. BTW can anyone here that has the Bentley look up the specs on the pulley mount bolts for the mechanical fan? I'd like to make sure their snug.
      But now that Im all finished, I have a good mechanically sound car. The engine front and top half is clean as a whistle. But I still have to have the back lower half degreased and pressure washed sometime soon. Anyone know of some good degreasers that can cut through the toughest grime build up?
    19. Senior Member Mk1Racer's Avatar
      Apr 16th, 1999
      NJ
      02-14-2012 12:06 PM #19
      Per the Bentley on page D19-3, you torque the three pulley bolts to 22 ft-lb (30Nm). It says the torque for the viscous coupling is 30 ft-lb (40Nm), but only when used w/ a VW SST open-jaw spanner. I have no idea what it would convert to if you use a socket.
    20. Semi-n00b
      Aug 6th, 2011
      02-16-2012 05:49 PM #20
      Quote Originally Posted by Mk1Racer View Post
      Thanks. I'll be sure to re-torque them to the specs you given me
    21. Junior Member
      Mar 26th, 2009
      quebec,canada
      2001 B5 passat wagon glx 4 motion
      02-17-2012 10:52 PM #21
      I got my kit from Blauparts, bought the tools from ZD mak and I did the job in one big day, the kit from blauparts is incredibile, it has a step by step homemade instruction manual that tell you all the special care you need to watch out for, it gives you also all the torque specs and bolts size,it has spare bolts that they know they can break off, all kind of good stuff overall. I think that while you are changing the belt you should change all the stuff around it and that's what this kit is.They will rent you the tools if you live in the U.S. I did put the car in the service position, it takes 30 minutes and give you so much more access so you can see what you are doing. Let me know if you need any clues,I was pretty proud of doing this myself. I had gotten an estimate from a local VW shop at 1700.00$ so I had a few spare dollars in case of a glitch.
    22. Member bert06040's Avatar
      Feb 9th, 2011
      hartford, connecticut
      2005 passat wagon GLX 4motion 2.8 V6
      02-18-2012 05:35 PM #22
      Hey whats up. I own an '05 Passat V6 wagon and recently had my TB done. I don't know how close you are to Glastonbury, but I called Montessi in Meriden, the Hartford VW, and Langan in Glastonbury. Out of the three, after asking all the right questions, Langan was the only one that didn't seem to be blowing smoke up my @$$. The price was the cheapest, and the service guy explained everything about the job to me. I ended up paying $1,100 for the job, but I needed to get it done; that's my only car, and I was at 75k. I wasn't taking any chances. Anyways, call them up 860-633-0261. I am in no way affiliated with any of these dealers.
    23. Junior Member
      Dec 24th, 2011
      Milford Ct
      02-24-2012 09:47 AM #23
      Did you do the whole job while in service postion. Seal, water pump etc.
      Thanks
      Dave
