VWVortex.com - abs light
    Results 1 to 9 of 9
    Thread: abs light
    1. 02-12-2012 01:03 AM #1
      why my abs light its always on? i dont have any problem with my brake system but i dont know why the light its on.
    2. 02-12-2012 01:19 AM #2
      I would start with the ABS sensors, they might just need to be cleaned... plus if they havent been changed (EVER) it would be a good place to start.
      Good luck with the car....
      Easier to delete the ABS, but unless you are on a track it doesnt help in any way... LOL.....
      Thank god for he Nurburg Ring here...
      Originally Posted by Tk2g60
      The style of ones car reflects ones self.
    3. 02-18-2012 10:36 PM #3
      ok thank you i will start doing some cleaning or replacing those sensors
    4. Member DUBZAK's Avatar
      Oct 26th, 2009
      Doin' W3rk at the Shop or my House
      Corrado SLC, Audi A8 QUATTRO, B6 ULTRASPORT MT6
      02-20-2012 01:25 PM #4
      Quote Originally Posted by Kubanbee View Post
      How about Scanning the car before throwing parts at it.
      And also, check to see that the rear brakes have the ABS rings in them. Forgetting to re-install those has seen more ABS lights than anything else.
      |Corrado SLC 2.9LVR6|Corrado Keyless Entry | A8 "Grape Ape" | SPOONFEDTUNING |FOURSEASONTUNING|DUBNUTZ|
      Quote Originally Posted by pileofredparts View Post
      Do you guys remember the time that Ryan kid started mixing and matching rods and end caps and then his motor wouldnt turn over? I do
      Jan 9th, 2012
      Ontario Can
      95 VR6 Corrado Storm
      02-20-2012 02:10 PM #5
      In my car, the light can be turned on and off with the key. I need a new switch. When the car is on, try wiggling the key a bit from left to right but not turning the car off. Works on my car.
    6. Member
      Jul 31st, 2011
      Jaffrey, NH
      '92 VW Corrado SLC
      02-20-2012 04:55 PM #6
      You mean the abs light isnt supose to always be on??? jk jk
      Jan 9th, 2012
      Ontario Can
      02-21-2012 11:55 AM #7
      Quote Originally Posted by smawgunner45 View Post
      These people try and act like the local school yard bully. Just look at his signature...he even tries to let you know he's a "tough guy". In reality mommy probably didn't give him enough attention. I've got no use for fools who take up space on here just to try to raise their pecking order somehow. If you post, have something constructive to say. Grow up or shut up.
      Very true, My original post was a constructive attempt at helping with the ABS light. In my car, I need a new switch and spent a long time figuring that out. But someone decided to hack on what I said by calling me cheap for not fixing it YET.
      But yes the switch is one of the last things to check in the list but its an easy one to do and takes no time at all to look at. And I got that off of an old VW magazine that had list of known problems with VR's
    8. Member vwflygti's Avatar
      Sep 10th, 2002
      Pennsburg, Pa
      2000 audi s4, 1990 corrado aba/16vt, 2004 audi A6, 2008 Aprillia 450svx, 2003 Kawasaki Z1000
      02-21-2012 01:09 PM #8
      Quote Originally Posted by DUBZAK View Post
      X2
      CHECK OUT MY BUILDS AT WWW.BUILDMYS4.COM
      2000 AUDI S4 RS6/54MM BILLET WHEELS
      1990 VW CORRADO ABA/16VT PRECISION 5857 .63 A/RCORRADO BUILD THREAD
    9. Moderator Krazee's Avatar
      Jan 25th, 2003
      En Why Sea
      Blog Entries
      12
      Corrado
      02-21-2012 03:35 PM #9
      ABS light also comes on if you are low on brake fluid. Best move is to scan before replacing any parts.
      Enough with the personal attacks.
      Project Corrado RS: Keep Up
