Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 35 of 172
Thread: A very technical build - PART II
  1. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    02-12-2012 08:33 PM #1
    I'm back! Here is my second technical build, aptly named "A very technical build - PART II"
    I kept the naming the same because i am keeping almost the same basic concept of a trunk layout, just adding a few tweaks here and there based on stuff i liked and didn't like from the first setup; and yes there were a few things that i didn't like.....
    First build for the new guys reading: http://forums.vwvortex.com/showthrea...echnical-build
    Problems with the first build:
    - Hard to get at relays
    - Wasn't very "showy"
    - didn't actually get around to the subwoofer & amp install so it will be documented here
    - Tight for wiring
    - Lines under car need to be protected a bit more for my liking in these Canadian winters
    What I wanted to add/change:
    - Change location of water trap (1)
    - Add water trap before the buffer tank (3)
    - Add another OB2 compressor (2)
    - Move the compressors closer to the tank (4)
    - Add more storage room for air tools, spare parts and on the road fix it solutions for ease of road trips (6)
    - Make it so that i can drain the water traps and tank without having to air out at all
    So to resolve all of the above issues/wants i devised a plan (as usual )
    Framing system
    - Change frame mounting for compressors
    - Lower 3 gallon buffer tank and compressors enough so that i could fit a 3” tall floor compartment for storage right above the tank and compressors
    - Move the compressors forward on the frame a bit
    - Install shut off valve between tanks where the original water trap was located (1)
    5 Gallon airtank box
    - Add water trap between tank and manifold (7)
    - Make false floor to hide all wiring and plumbing for showing off the tank from back seats (keep in mind that there is a false wall hiding the 5 gallon tank from the trunk)
    - Add inflation valve to tank just incase something happens
    Electrical Connection Box
    - Add extensions for compressor relays, cutout through wall so they are accessible from the trunk electrical box instead of below the false floor behind the air tank
    - Add amplifier for sub
    Okay so here is where the fun begins......
    Installed removable connection points (will be moved to the bottom of the frame) so that they can be easily replaced. Needed for the increased weight of all the compressors. They are probably 100lbs for all 3 of them with the frame, good thing i have e-level!
    Drain valve on the bottom of the tank with ball valve – easy to drain and will be routed directly out of the trunk through the bottom
    Compressors and tank closer together and top at around the same height
    Frame redesigned, built, but not fitted in the car yet
    Keep looking for updates!
  2. Member Slamtastic's Avatar
    Jul 24th, 2010
    Calgary, Alberta
    02-12-2012 09:49 PM #2
    Can't wait to see it done!
  3. Banned jettaaddictionII's Avatar
    Sep 3rd, 2011
    MI
    2.0 twin turbo 9 speed jetta
    02-13-2012 12:13 AM #3
    wow! you are running 3 ob2s :bow:
  4. Member ericshell's Avatar
    Dec 22nd, 2011
    Lehigh University
    bagged 20th
    02-13-2012 12:16 AM #4
    can't wait to see the outcome this time! I know Ben from RI had some trouble battery/alternator wise when he ran 3 vlairs, is the power used by these more efficient or do you have plans to support the power consumption. I never thought it would be a problem, but maybe its just a myth / weird coincidence.
    >>>>>>>>>ESHELLDESIGNS<<<<<<<<<
    >>>>>>>>>VIMEO | FLICKR<<<<<<<<<
  5. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    02-13-2012 12:21 AM #5
    Quote Originally Posted by ericshell View Post
    200A alternator from EA
    It is a DEFINITE if you are going to be running more than 1 of them since the amp draw on each is 35A
  6. Member ericshell's Avatar
    Dec 22nd, 2011
    Lehigh University
    bagged 20th
    02-13-2012 12:26 AM #6
    Quote Originally Posted by MechEngg View Post
    thats great info to know . Does that alternator swap right in as well?
  7. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    02-13-2012 12:27 AM #7
    Yeah it is a direct bolt on replacement, he makes them custom for what you want. This one i have is 200A @1200rpm and 150A at idle (750rpm)
  8. Member ericshell's Avatar
    Dec 22nd, 2011
    Lehigh University
    bagged 20th
    02-13-2012 12:31 AM #8
    I just posted this in dean's thread as well but you should definitely take a video for the refill cycle from low and from empty. I'm curious to see how insanely fast it will be haha.
  9. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    02-13-2012 12:33 AM #9
    yes i your builds. Could you share how your wiring the three comps? everywhere i looked i have only seen dual diagrams, just curious.
    Hella4¯\_(ツ)_/¯ My Flickr
  10. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    02-13-2012 12:48 AM #10
    Quote Originally Posted by Twilliams83 View Post
    i will do up complete plumbing and wiring diagrams including my self latching automatic resetting relays and turn off switches for the compressors
  11. Member Niagara_V_Dub's Avatar
    Sep 25th, 2007
    Las Vegas, NV / Lemoore, CA
    hoopty on air
    02-13-2012 03:04 AM #11
    how much did that alt run you if you don't mind me asking.
    Insert witty quote
  12. Member baggedug's Avatar
    Apr 28th, 2011
    Boulder, CO
    2013 Candy White CC
    02-13-2012 03:39 AM #12
    love that this is back
  13. Member joebags's Avatar
    Jun 14th, 2007
    NEPA
    ByMe4Me
    02-13-2012 08:48 AM #13
    can't wait to see more
    #SliceOfLowLife/ Bill F*cking Murray
  14. Member BlackRadon's Avatar
    Sep 30th, 2006
    Banff, AB
    03 jetta wagon.
    02-13-2012 04:31 PM #14
    sweet! I really wanna redo my trunk. Looks ****ing horrid! Can't wait to see yours
  15. 02-13-2012 04:45 PM #15
    Hey, Mech, I'd also like to know where you got that alt from (Excessive Amperage?), since I want to go bigger than stock at some point.
    Glad to see you're back in the trenches, BTW.
    EDIT, nevermid, I just saw the Excessive AMperage sticker on the pic of the alt you took. Duh.
  16. Member
    Sep 10th, 2010
    Westchester, NY
    2011 VW GTI
    02-13-2012 05:37 PM #16
    Super nice build! Really like the noise isolation setup.
  17. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    02-13-2012 07:51 PM #17
    Quote Originally Posted by Niagara_V_Dub View Post
    Give EA a call and they will give you a quote
    Quote Originally Posted by baggedug View Post
    Me tooooooooooooooooooooooo
    Quote Originally Posted by joebags View Post
    Quote Originally Posted by BlackRadon View Post
    Let me know and i might be able to help you out if you are ever in Calgary
    Quote Originally Posted by John Reid View Post
    Quote Originally Posted by aVWGTIguy View Post
  18. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    02-13-2012 08:17 PM #18
    As promised a full plumbing and wiring schematic, any questions just ask.
    WIRING
    Okay i have decided to do some funky unnecessary wiring here to gain what i feel is a freakin fantastic functionality. Functionality goes as such:
    - Turn on car
    - Car will raise automatically due to e-level
    - Press kill switch to shut off each compressor individually (or maybe all 3, haven't decided yet)
    - Compressor will stay off until button is pressed or car is turned off
    - If button is in the ON position (working/not lit up) when the car is turned off the switch remains in the same position
    - If the button is in the OFF position (not working/yellow light showing) when the car is turned off it automatically resets itself so that when you start the car the compressors will turn on again.
    This auto-resetting is fantastic for if you have just a plain toggle switch and forget to switch it back on and all of a sudden you have zero pressure in your tank. The buttons are OEM Euro switches just like the following "funk" switches found on graeme86's webpage http://www.users.on.net/~graeme86/funk/funk.html
    They have a brilliant mounting spot that is out of the way and will look extremely OEM.
    The wiring diagram is entirely complete except for the wiring of the actual button which is just three lines on my schematic. Here is the internal schematic, just connect 4 and 6 to grounds, 3 to your dimmer switch, 1 and 2 to splice between your line that you want to activate, and 5 from the SPDT relay NO port (87a). This SPDT relay is used purely to get the yellow light to activate when the compressors are in the OFF position and not working, which is the way i want it
  19. Member tonyb2580's Avatar
    Jun 22nd, 2006
    Lauderdale approved
    02-14-2012 09:20 AM #19
    you are one serious dude im in
    For HIDS/LEDS PM Me
    If you're thinking of doing a ZKW projector retrofit, you're on heroin. If you're thinking of bolting BMW lights up to where your GTI lights sit now, you're on poor quality heroin.
  20. 02-14-2012 09:28 AM #20
    Ahh, it's so nice to see someone doing an install that actually PLANS AHEAD as opposed to winging it, like many of the build threads on the Vortex seem to imply (I could be wrong, just an observation via the internet).
    Yeah, making diagrams/CAD drawings can take longer, but it also causes less headaches or rebuilds.
    Well done, sir.
  21. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    '07 335i Sedan, '04 R32, '82 300D, '95 Jetta
    02-14-2012 09:37 AM #21
    Looking good! When can we expect SS hardlines?
  22. Member martin13's Avatar
    Apr 20th, 2010
    Calgary Alberta
    Beater MK4, big old Benz on air
    02-14-2012 10:44 PM #22
    Quote Originally Posted by arethirdytwo View Post
    when he buys the stainless, i will lend him my bender
  23. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    02-15-2012 12:14 AM #23
    Quote Originally Posted by tonyb2580 View Post
    Glad i impressed you
    Well done, sir.
    I totally agree, planning is one of my favorite parts, the other favorite part is building it
    Honestly i don't think i will ever do hardlines on this setup, just with the way it is designed flexible lines are much better because of the vibrations. The vibration frame will be moving slightly so hardlines to my completely stationary tank might not be the best idea, but you never know in the future
    Quote Originally Posted by martin13 View Post
    No deal, you will be enlisted to do the actual bending
  24. Member President Lincoln's Avatar
    Jun 27th, 2005
    Kanosh
    83, 85 & 91 Jetta - 87 & 03 GTi - 13 Golf R
    02-15-2012 10:49 AM #24
    Well this is great! IN
    1966 Beetle - 83 Jetta Deluxe - 87 VR GTi - 20th AE GTi - 2012 Tiguan (hers)
  25. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    02-15-2012 12:20 PM #25
    I gotta ask about the three comps though... I know why... but why?
  26. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    02-15-2012 12:55 PM #26
    Well here were the reasons behind getting another:
    - Never heard of anybody with a VW having 3 OB2's so i wanted to be unique
    - I had the extra room in my trunk if i redesigned my frame
    - I had some extra amperage to play with seeing as i had an upgraded alternator already (150A at idle, so say 130 to play with so we don't run full tilt, ~20A for car functions at any one given time, that leaves 110A for compressors. 35A * 3 = 105A so it is just enough). I would need to upgrade my alternator even further to a 250A/190A idle to accomodate another compressor so it just isn't worth it.
    - This way my fill time is virtually non-existent
    - With this proven silencing method the compressors are silent while running so i can run as many as i want without negative side effects
    - The faster the fill time the less it will start to kill my battery actually, this way my alternator can keep up to the filling and it won't start deep cycling my OEM battery, which it would if i was running it for 5 minutes or so
    - Plus it fills up the trunk space nicely
  27. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    02-15-2012 01:17 PM #27
    LOL. I mean I would take three but I have a show car
    Any in car audio? I'd love to hear how quiet these are, I think I may run isolators and move my comps into the interior.
  28. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    02-15-2012 01:46 PM #28
    You don't want to have three beautiful compressors showing in a show car??
    I am just putting a simple head unit in to wire up to the monsoon speakers and amp and put in a small 10" directed audio 300W rms sub and amp in a nice sealed box for a bit of crisp bass. Will run off the other fuse I have in the trunk distribution block. The amp fits in the electrical box section of the build
  29. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    02-15-2012 07:56 PM #29
    I think he was talking about audio clips of the comps running from inside the cabin
  30. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    02-15-2012 08:12 PM #30
    Bingo. All the work on my car and ICE is all factory. Ended up growing out of that phase. I'd just love to hear in-car noise level.
  31. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    02-15-2012 08:50 PM #31
    LOVE LOVE the FUNK button idea, i need this in my life, I hate when the compressor kicks in while waiting for the glow to warm up and then turn off and on when firing the engine
    Let me know how it goes and I'll most likely do the same
    EDIT: that guy is asking for $45 shipped for the FUNK button
    BIODiesel Powered | MKx Channel VW/Audi Videos United
    MKIV Forum User Guide | Forum Rules
    Quote Originally Posted by dele
    The guys on coils can pull off their own Airless pride thread cos they clearly are the underdogs in the air/static debate, kinda like the equality movement for women.
  32. Member Niagara_V_Dub's Avatar
    Sep 25th, 2007
    hoopty on air
    02-15-2012 10:34 PM #32
    I was going to run the mini funk button with a relay. I am still trying to decide on the fine details of it though. I am gonna have to step my game up though after seeing how you throw down.
    Insert witty quote
  33. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    02-16-2012 12:25 AM #33
    Ah gotcha. I must have totally read it wrong.
    I don't think that the compressors would be great for inside the cabin, they would be noisy for that. But with the vibration dampening and double layers of airborne sound absorber it is quiet in the cabin with the comps mounted in the spare wheel well.
    Quote Originally Posted by kilimats View Post
    Yeah thats what i got from him too.....BUT screw it i am going to do it anyways
    You can actually use any momentary push button with the wiring diagram that i gave you and just wire in an LED for an on or off indicator
    It's not a competition, it's always nice to have something unique though
    Even if you do the same thing not very many people have done it at all so it will still be really unique especially at local shows
  34. Member BlackRadon's Avatar
    Sep 30th, 2006
    Banff, AB
    03 jetta wagon.
    02-16-2012 01:20 AM #34
    I must admit when it comes to wiring/electronic' i just almost freeze up and don't even know where to start. Its kinda hard to explain the feeling but its so damn stupid! That funk button idea is great! Can't wait for some more progress
  35. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    South Burlington, VT
    335i
    02-16-2012 02:04 PM #35
    Looking good
    - Call us at: 802 . 735 . 2574 - Email us at: sales@bagriders.com - - // - - We're open: Monday - Friday 9:00 - 5:00 Eastern -
