Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 106 to 140 of 172
Thread: A very technical build - PART II
  1. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    04-09-2012 12:34 AM #106
    Quote Originally Posted by Slamtastic View Post
    I'm sure it is! Get those summers on so we can take some pics, I gotta see those things in action.
    Getting them mounted this week, i will text you when i am ready
  2. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    04-09-2012 12:39 AM #107
    Quote Originally Posted by MechEngg View Post
    Yup all compressors running, but i can only run 2 of them at idle, i need to be revving 1500 to keep up the juice for the third one. Fill time is ridiculous
    are you going to keep it like this pr are you going to fix this somehow?
    Hella4¯\_(ツ)_/¯ My Flickr
  3. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    04-09-2012 12:55 AM #108
    Quote Originally Posted by Twilliams83 View Post
    I would love to get EA to tweak the current alternator a little bit by adding more amps at idle, they said they could get me up to 190A instead of the current 150A at idle. But I just don't have the funds at the current time. So I am probably just going to cycle 2 of the compressors most of the time and when I am actually driving and the compressors kick in ill just switch the third one on also. That's the plan for right now anyways
  4. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    04-16-2012 01:25 PM #109
    Looking into the very very small problem of the power draw still, might add an external regulator to crank the voltage up to 16V or 17V and a different regulator to keep the rest of the car at 13.8 while running the compressors, it might help to reduce the amperage draw by enough. The other option is sizing out a good size capacitor to hold the correct amount of power for one full 40 second compressor cycle so that the battery stays charged, essentially like adding another battery but i can easily hide it in the side of the trunk in the CD changer place
    In other news the trunk is ALMOST finished, just one more panel to make. I ran out of MDF yesterday
  5. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    '07 335i Sedan, '04 R32, '82 300D, '95 Jetta
    04-16-2012 01:39 PM #110
    Why not hide a deka or another similar small battery in the back somewhere? This would be an easy solution.
  6. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    04-20-2012 10:53 PM #111
  7. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    04-20-2012 11:56 PM #112
    damn, didn't know you had flakes on the way. They look great on pg.
    trunks looking great
  8. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    04-24-2012 01:21 AM #113
  9. Junior Member Lynch's Avatar
    Apr 24th, 2011
    Cambridge Ontario
    2004.5 VW Jetta GLI 1.8
    04-25-2012 06:13 AM #114
    looks great! nice build!
  10. Member BlackRadon's Avatar
    Sep 30th, 2006
    Banff, AB
    03 jetta wagon.
    04-25-2012 04:45 PM #115
    Looks get Sean! Really liking the fitment of the new wheels.
  11. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    05-04-2012 09:19 PM #116
    Figure out what the problem was with the compressors and why i couldn't run all 3 at idle.....
    - When i bought the car it had a big motomaster battery in it, too big for the box and very close to my retrofits
    - Did not like it so when i swapped out the alternator we swapped out the battery as well to my OEM battery from my old jetta (battery sitting on concrete garage floor for 8 months during winter without a charge)
    You kinda see what happened here....the old OEM battery **** the bed completely last week. Swapped out the battery to the motomaster one and all 3 comps can run at idle.
    I'm dumb
    But at least it is fixed
  12. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    05-05-2012 07:21 PM #117
    Emptied water traps and tanks today. Water results below
    Water trap 1: 1/2 full
    3 gallon tank: ~25 tbsp in the bottom (3 second flow through a 1/4" barb)
    Water trap 2: zero water
    5 gallon tank: zero water
    Water trap 3: zero water
    I think the combination will prevent any water from screwing up the system in the winters
  13. Member
    Nov 26th, 2004
    Burnley, Lancashire, UK
    92 UK Corrado G60, 83 Mk1 golf gti 16v
    05-05-2012 07:33 PM #118
    ^^ That's good/interesting to hear Great setup and superb looking bora/jetta btw
  14. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    05-14-2012 01:41 PM #119
    Sitting with exactly the same rim to fender gap on the fronts and the rears. Sounds good to me, unfortunately the lip is taking a beating and i am going to have to redo it this winter. Also thinking that a 4-mo lip might be a good bet for the winter
  15. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    05-30-2012 09:08 PM #120
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  16. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    05-30-2012 09:16 PM #121
    Guess i should post in this thread as well
  17. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    05-30-2012 09:40 PM #122
    that exhaust tip is bothering me but the car is looking stupid clean.
  18. Member Niagara_V_Dub's Avatar
    Sep 25th, 2007
    Las Vegas, NV / Lemoore, CA
    hoopty on air
    05-30-2012 09:47 PM #123
    any reason for one black carrier bar and one silver?
    Insert witty quote
  19. Member AndrewDaniels's Avatar
    Jul 2nd, 2011
    Annapolis, MD
    1991 GTI 2.0 16V, 1983 GTI 1.8 8V
    05-30-2012 09:54 PM #124
    Lookin' good
    16 with a bagged Mk2... Pretty sure I'm the only one at my school with bags...
  20. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    05-30-2012 10:21 PM #125
    Freaking me out. Very unanal engineer!
    Quote Originally Posted by Niagara_V_Dub View Post
  21. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    05-30-2012 11:22 PM #126
    Thanks, Exhaust tips have never really bothered me. Gotta get a new hanger one of these days but until it actually breaks i doubt it will bother me enough
    Ummm thats the way i bought them haha. It was a mix of two different sets. And i put it on like this to see which way i liked it better and just never took it off, again because it doesn't bother me.
    Quote Originally Posted by arethirdytwo View Post
    I'm not a super typical engineer i don't think. I have the knowledge but i can let things go, i'm pretty easy going in most things
  22. Member Niagara_V_Dub's Avatar
    Sep 25th, 2007
    hoopty on air
    05-30-2012 11:27 PM #127
    LOL, you can always electrical tape one
    And it is funny how stupid clean and nice the car is when the biggest criticism people can come up with is the exhaust hanger and carrier bar colors.
    Insert witty quote
  23. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    05-30-2012 11:30 PM #128
    Don't forget the tiny BagRiders sticker in the upper left hand corner of the rear window
  24. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    06-07-2012 11:12 AM #129
    Who has the best gf ever?
    GF creeped my car lately and got me this shirt to match my car
  25. Member rgarjr's Avatar
    May 19th, 2012
    Los Angeles area
    1998 Lexus GS300
    06-07-2012 10:12 PM #130
    nice shirt
  26. Member ericshell's Avatar
    Dec 22nd, 2011
    Lehigh University
    bagged 20th
    06-07-2012 10:22 PM #131
    looks great man!
    >>>>>>>>>ESHELLDESIGNS<<<<<<<<<
    >>>>>>>>>VIMEO | FLICKR<<<<<<<<<
  27. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    06-09-2012 02:49 AM #132
    Tuxedo shirt, looking spiffy for the roll in to Driven
  28. Member woodywoods86's Avatar
    Jul 28th, 2008
    Bay Area
    05 VW JETTA GLI
    06-17-2012 11:54 AM #133
    Boss status achieved!
    Buy My Wheels For Cheaper
    Constant, State of Change!
    "Too close for Guns Switch to Missiles"... but, SIR!
    Does anyone read these... I do.
  29. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    06-17-2012 08:29 PM #134
    Another of the show
  30. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    06-18-2012 09:35 PM #135
  31. Member oakdub's Avatar
    Feb 27th, 2011
    Oakville, Ontario
    99.5 flash red race car
    06-19-2012 01:45 AM #136
    Car looks great man, enjoyed reading through this thread.
    Lurking a lot more in the air forum, need to learn
  32. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    06-19-2012 01:51 AM #137
    Quote Originally Posted by oakdub View Post
    Hey buddy, thanks!
    If you have any questions you know you are always welcome to PM me
  33. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    06-28-2012 10:22 PM #138
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  34. Member President Lincoln's Avatar
    Jun 27th, 2005
    Kanosh
    83, 85 & 91 Jetta - 87 & 03 GTi - 13 Golf R
    06-28-2012 11:12 PM #139
    Sweet set up man. Looks great.
    1966 Beetle - 83 Jetta Deluxe - 87 VR GTi - 20th AE GTi - 2012 Tiguan (hers)
  35. Junior Member 2.0Pride's Avatar
    Jan 22nd, 2010
    boyertown PA
    2000 GTI VR6....RIP 1997,Jetta,Gls
    07-03-2012 07:00 AM #140
    ahh seeing all these electrical graphs hurt my head no wonder i failed basic and advance electric at uti but awsome ride
