8v or 16v Mark II?
Greg W.
#1
Will the carriers off a mk2 work for the Calipers. I bought the vented rotors and pads but I think the carriers are different. I don't want to put the 10.1.
Thanks for any info.![]()
#2
8v or 16v Mark II?
Greg W.
They have my car when they pry my dead cold fingers from the steering wheel.
#4
I think you have to use MK1 calipers & brackets. Been a long time since I did that mod on a fox.
2010 VW Touareg TDI
1998 Audi A4 Sport APR stage 2
1983 VW GTI 16v project
#5
I know for A2's, you can just swap the rotors and pads. Pads are thinner IIRC.
I really suck at smog.
#6
I realize this. I was asking the OP where he got his vented rotor from, an 8V or 16V. If he got it from a 8V, he needs to use the caliper from the 8V to go along with the smaller vented rotor. If he got 16V rotor he needs the Scirocco caliper.
He was not very clear in his original post.
Greg
#7
I'm pretty positive he's talking about the same 16v gti me and my buddy got some misc. parts out of
for his first car, a 86 jetta gl. Wassup Marcus![]()
2 foxers meet both after a junkyard fox. Small World![]()
#8
#9
#10
Browsing around for a set of mintex red box- Do the mk2 golf pads fit into the fox calipers? Or could someone provide a link to a set?
#11
hey themagellan, your pm box is full. but yes, the brake lining is the front pads.
http://www.worldimpex.com/parts/genu...et_167027.html
checked the part number
#12
They are not a direct swap. Different carrier as I thought.
I'm going to let BFI know about this so they can pull the numbers and correct this.
Thank you everyone for the help.
