Results 1 to 7 of 7
Thread: AMP: You get what you pay for?
  1. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    02-13-2012 12:36 PM #1
    I am confused, need a little help
    I recently replaced my old amp JBL BP150.1 Mono Channel with a cheap $70 FLI Audio FL1200M-F2 (apparently a reputable brand in Europe). The spec on that new amp is 3x more than my old one yet the subwoofer bass output decreased just a bit, how could that be? should i not trust product spec anymore and only focus on brand like Alpine/JL/JVC/etc... and pay 3x more $$$ ?
    I thought maybe the new amp had a bad ground but i tried connecting it to the battery ground directly with no improvement. The gain and bass boost knobs were set to max.
    Here is a recap of the specs for the old/new amp and sub i use
    NEW AMP: FLI FL1200M-F2
    RMS Power Rating:
    4 ohms: 400 watts x 1 chan.
    2 ohms: 600 watts x 1 chan.
    OLD AMP:
    RMS Power Rating:
    4 ohms: 75 watts x 1 chan.
    2 ohms: 150 watts x 1 chan.
    manual: http://www.jbl.com/resources/Brands/...nual/bp_om.pdf
    FLI Audio Frequency 10 (FF10-F4)
    10" Single 4 Ohm Frequency Series Subwoofer
    Power Handling:
    Peak: 1000 watts
    RMS: 300 watts
    Minimum input: 150 watts
    BIODiesel Powered | MKx Channel VW/Audi Videos United
    MKIV Forum User Guide | Forum Rules
    Quote Originally Posted by dele
    The guys on coils can pull off their own Airless pride thread cos they clearly are the underdogs in the air/static debate, kinda like the equality movement for women.
  2. Member NFrazier's Avatar
    Jul 22nd, 2006
    Massachusetts
    2004.5 VW GLi 1.8T
    02-13-2012 03:01 PM #2
    CEA-2006 compliant, nuff said.
    CEA has a list of standards that require the amplifier, wiring, speakers, headunits, etc. to meet certain standards in order to advertise that it does X, Y, and/or Z.
    The JBL amplifier, and most large name brands are CEA compliant. Knowing it's CEA compliant means you know the power it's advertising to produce, it does produce.
    Besides that, make sure the amplifier is tuned correctly, and if nothing else in the audio system has changed, then you can probably contribute it to the amplifier.
    Not to mention seeing a singular 40A fuse on a class A/B amp that supposedly produces 600 RMS tells me it doesn't even come close to the 600W RMS.
    For the most part you ALWAYS get what you pay for in one way or another.
    12v Installation Services: Audio, Alarms/Remote Starts, OEM Integration, etc.
    Pioneer, Kenwood, Hertz, Audison, Rockford Fosgate
  3. Moderator kilimats's Avatar
    Mar 5th, 2006
    Vancouver, BC
    MK4 Golf TDI
    02-13-2012 04:09 PM #3
    ^ thanks for clarifying, didnt kno about this standard.
    I'll resale this POS amp and get an Alpine Monoblock 500 Watt RMS MRX-M50 instead, more money but worth it i'm sure
  4. Member NFrazier's Avatar
    Jul 22nd, 2006
    Massachusetts
    2004.5 VW GLi 1.8T
    02-13-2012 04:54 PM #4
    Quote Originally Posted by kilimats View Post
    great amp
  5. 02-14-2012 10:00 AM #5
    It all depends on the quality of amp like for instance I own a j2 jl 500.1 amp and if I bought the XD or hd version the bass response would be way more clear with less distortion but the same out put that's what happening you downgraded amps its not that anything is wrong it just has to with the quality of the amp. That's all
  6. Member hfiles2011's Avatar
    Dec 5th, 2011
    MD
    00 VW Jetta 2.0L AEG
    04-10-2012 03:58 PM #6
    amp looks like it can only fit 8 maybe 4 gauge wiring for ground &power
  7. Member NFrazier's Avatar
    Jul 22nd, 2006
    Massachusetts
    2004.5 VW GLi 1.8T
    04-10-2012 05:45 PM #7
    Quote Originally Posted by hfiles2011 View Post
    Haha, that's like true 10AWG maybe 8.
    Bringing an old thread back from the dead?
