looks awesome, what did you change to get it to work with the sri?
#1
On Sale Here for only $139.00
Add Install Kit For Only $69.95 More $208.95 Total!
Want to dress up your engine bay, or need a large rail to feed your thirsty 2.5L? Then you need this billet aluminum fuel rail for 2.5L 5 cylinder engines. These are made from a solid piece of 6061 aircraft aluminum, to provide a beautiful, high flowing piece. These rails have mount tabs that use factory screws to attach to your intake manifold. These feature -8an O-ring boss ports, which will be enough flow for even the most wild setups. There is no need to worry about injectors coming out either, as these rails retain the factory injector clips for added safety. The clips install at the same angle as the factory fuel rail, to maintain the factory injector angle.
These fit all 2.5L 20V 5 cylinder engines.
Features:
Made in house from 6061 aircraft aluminum
Retains factory injector clips
Available in IE RED or raw finish
Includes mounting tabs and bolts
#2
#4
#8
#10
link o the supplier?
#11
Im trollin the tex today on my phone. I'll find the link later on my computer. As far as I'm aware as long as the plugs are the same any of them will work as long as they arent too long.
There are also ones where the plug OS angled down instead of outward like the oem one.
It was like a VW parts warehouse site.
#14
Wondering if I could buy just the rail, and the part that allows an fittings to attach to the OEM fuel line... This way I can tuck the actual fuel line... Would you guys sell that part separately?
god i love my car. it may not be fast, but it's crazy fun!
C2 stage 2 TURBO!!! ACHTUNG!!! 2.5liter 5cylinder contents under pressure!!!
#23
Damn you IE for coming out with such gorgeous sh*t....
This is on my 'to-do' list. Would look great with my IE Valve Cover!
#24
They definitely look awesome side by side.![]()
.:IntEngineering.com:. .:Facebook:.
Check out some cutting edge R&D Work on our blog! IE Behind the scenes Blog!
#25
@SimpleStaple Yes it would look amazing next to an IE Valve cover!!
#27
For non turbos, this doesn't do a thing right? Just looks pretty?
2007 Bagged and Shaved MK5 Golf. -Daily Dirt-
#28
#31
Gabe,
Do you guys plan on offering this rail in black like you do IE's valve cover? I want both..
Black Forest Industries /// 919.468.5400 ext. 7014
PM, Facebook, E-mail, or call us with any questions
#32
#33
#35
