VWVortex.com - 2.5L IE Billet Fuel Rails On Sale at Bluewater Performance
    Page 3 of 5 FirstFirst 12345 LastLast
    Results 51 to 75 of 106
    Thread: 2.5L IE Billet Fuel Rails On Sale at Bluewater Performance
    1. Forum Sponsor pete@integrated's Avatar
      Jan 1st, 2009
      Salt Lake City, UT
      '92 Gti 20v, '96 M3, '10 Shop Van :)
      05-19-2012 12:46 PM #51
      We already have the notch which is necessary drawn up, and we're going to mod some rails here in not too long... Our CNC's have been really backed up, but we are getting another one in the next few weeks which should open up our schedule.
      .:IntEngineering.com:. .:Facebook:.
      Check out some cutting edge R&D Work on our blog! IE Behind the scenes Blog!
    2. Banned SimpleStaple's Avatar
      Sep 15th, 2011
      Villanova, PA
      Jetta VI 2.5L
      05-21-2012 02:03 PM #52
      Ordered my fuel rail and oil cooler from Gabe about 5 minutes ago!
      Any chance their are DIY's/Guides/Instructions for install for both oil cooler and the fuel rail? If not, I will just d!ck around with it and figure both out.
    3. 05-22-2012 03:27 PM #53
      No diys as of yet but you can give me a call if you get stumped. We are hoping to make a full installation instruction link on the website next time we do one locally.
    4. Former Advertiser
      Apr 4th, 2012
      Denver, CO
      05-23-2012 08:15 PM #54
      Happy hump day!!
    5. Member TylerO28's Avatar
      Jul 7th, 2008
      Mill Creek, WA
      '08 2.5Turbo Rabbit
      05-25-2012 05:28 PM #57
      Quote Originally Posted by SimpleStaple View Post
      Fuel rail is incredibly easy to do.its 2 torx and it pops out. Lay a rag down to catch the fuel after you remove your injector clips pull them out. Then the fuel line by the passenger side firewall is a simple clip you push in and it'll release..
      Oil cooler is more difficult, take off your front end and take the lower rad hose off it'll rotate forward and then you'll be able to get at it easily. I replaced all the bolts for the oil filter housing as well while I was in there with stainless numbers.
      Its not too difficult, but get ready to remove your manifold bracket,I even used this opportunity to delete my sai pump in there.cleared up tons of room
      Sent from the bottomless pits of HELL!
    6. Former Advertiser
      Apr 4th, 2012
      Denver, CO
      05-25-2012 09:50 PM #58
      Quote Originally Posted by TylerO28 View Post
      So glad to hear!! Thank for the post!!
    7. Former Advertiser
      Apr 4th, 2012
      Denver, CO
      05-26-2012 12:56 PM #59
      Happy Saturday!!
    8. Former Advertiser
      Apr 4th, 2012
      Denver, CO
      05-28-2012 12:24 PM #60
      Happy Memorial Day!
    9. Banned SimpleStaple's Avatar
      Sep 15th, 2011
      Villanova, PA
      Jetta VI 2.5L
      05-28-2012 09:09 PM #61
      Welp, found the little black thingy along with the blue adapter rolling around in the bottom of the box...
      There was a hole/tear in the packaging that held the install kit?
      Now, once I unclipped the old, I hoped it was just easy sailing from there....
      Nope. Motherf*cker doesn't fit onto the god damn blue clip/attachment thingy!
      Could there be a difference in the 2012's via the length of the factory outlet thing?
    10. Banned SimpleStaple's Avatar
      Sep 15th, 2011
      Villanova, PA
      Jetta VI 2.5L
      05-28-2012 11:13 PM #62
      With the factory clip thingy removed....
      Sent from my DROID BIONIC using Tapatalk 2
    11. Former Advertiser
      Apr 4th, 2012
      Denver, CO
      05-30-2012 01:17 PM #63
      Hows everyone's Wednesday going?? Who's coming to Wuste??
    12. Member chadone's Avatar
      Apr 26th, 2010
      Buffalo NY
      2007 VW Golf
      06-02-2012 11:24 AM #64
      When are these going on another crazy sale?
      2007 Bagged and Shaved MK5 Golf. -Daily Dirt-
    13. Member chadone's Avatar
      Apr 26th, 2010
      Buffalo NY
      2007 VW Golf
      06-03-2012 04:47 PM #65
      Is it possible to install without the install kit? Like using the stock part? And if not is it possible to order the install kit later?
    14. Former Advertiser
      Apr 4th, 2012
      Denver, CO
      06-04-2012 12:10 PM #66
      Quote Originally Posted by chadone View Post
      Good morning! The fuel rail needs the install kit as the stock parts will not work. You can always make your own install kit, but we do recommend purchasing the install kit at the same time as the fuel rail. Thanks! 😊
    15. Member chadone's Avatar
      Apr 26th, 2010
      Buffalo NY
      2007 VW Golf
      06-04-2012 01:06 PM #67
      Quote Originally Posted by hollywood@bwperformance View Post
      Thanks. I sent U a PM
      Ordering it today.
    16. Member chadone's Avatar
      Apr 26th, 2010
      Buffalo NY
      2007 VW Golf
      06-04-2012 05:09 PM #68
      Joined the Rail club today.
    17. 06-05-2012 04:37 PM #69
      Were you able to get it installed? It should clip right on. The 2012 ones are the exact same as the previous years. Might just need to lube it with some oil first and then a firm push and it should clip just fine.
    18. Banned SimpleStaple's Avatar
      Sep 15th, 2011
      Villanova, PA
      Jetta VI 2.5L
      06-05-2012 04:44 PM #70
      Quote Originally Posted by gabe@bwperformance View Post
      Nope -- wouldn't fit. The inside of the replacement adapter is too tight/narrow for it to fit. I would force it from underneath, too, and no luck. It literally had scrapes/scratches from the edges it couldn't/wouldn't clear.
      I'm just having Mike and Eric @ Eurowerks throw it on while I have some other things taken care of.
    19. Banned SimpleStaple's Avatar
      Sep 15th, 2011
      Villanova, PA
      Jetta VI 2.5L
      06-05-2012 04:46 PM #71
      It shoulda been black but turned silver
    20. 06-06-2012 12:18 PM #72
      Very strange. We have installed one already on a 2012 with no issues. Let me know what you ultimately find out and if we can do anything to help.
    21. Member chadone's Avatar
      Apr 26th, 2010
      Buffalo NY
      2007 VW Golf
      06-08-2012 11:30 AM #74
      Bump for a great Company!!!
    22. Former Advertiser
      Apr 4th, 2012
      Denver, CO
      06-08-2012 05:40 PM #75
    « Back
