You have a pm about the Sunroof and headliner sir
I had some parts from my old Audi that i thought I'd get rid of. The sunroof has NO dents and has great white paint. I cleaned it up quite a bit. I'm located in Pasadena, CA.
Cover is $15 shipped -Motor is $35 shipped
^^The Screw hole that bolts the cover to the roof is broken but, as you can see, a bigger washer will fix it
Sunroof and headliner piece are $70 shipped
^^There's a spring missing from the passenger side that pulls the small door open but i didn't notice it until it was disassembled
Ill let the hole lot go for $100 shippedIf your trying to do a tilt and slide mod on you mk2 VW then this is the motor and cover you'll need but not the sunroof (Mk2's are about 4 inches wider).
